Northern California NorCal
Old 05-04-2014, 12:24 AM   #1513
OmarYasin
OmarYasin's Avatar
Originally Posted by garfull View Post
Tow eye happen to be rear driverside?
Sent from my SGH-T599N using Tapatalk
OmarYasin is offline   Reply With Quote
Old 05-04-2014, 02:27 PM   #1514
brz408
Manny
brz408's Avatar
Drives: 13 WRB Brz
WTB:
-smoked side markers
-sti style front lip (think thats the one where the side edges curve up) in polyurethane material
-borrow/rent oem tail lights for a couple of weeks while I smoke mine out
brz408 is offline   Reply With Quote
Old 05-06-2014, 10:33 AM   #1515
Bones36
Bones36's Avatar
Drives: 13 Brz Jrsc
Bayson R cs style front lip. $60
Bones36 is offline   Reply With Quote
Old 05-06-2014, 01:12 PM   #1516
OmarYasin
OmarYasin's Avatar
Size:  96.1 KB anyone need heat wrap for headers or oil pan? @BigFatFlip
Old 05-06-2014, 01:13 PM   #1517
OmarYasin
OmarYasin's Avatar
Attachment 77598 anyone need heat wrap for headers or oil pan? @BigFatFlip
Old 05-06-2014, 03:58 PM   #1518
azngolfur
azngolfur's Avatar
Drives: DGM BRZ
Selling:
3 Stock Michelin Primacy HP Tires
7/32 tread left
$100 obo. Located in San Ramon.
azngolfur is offline   Reply With Quote
Old 05-06-2014, 09:36 PM   #1519
garfull
garfull's Avatar
Drives: FRS(sold), AP2, R35, FJC, ED9
I might. How much? Temp specs?
garfull is offline   Reply With Quote
Old 05-06-2014, 09:39 PM   #1520
garfull
garfull's Avatar
How much for the license plate?? Awesome plate.
Old 05-06-2014, 09:58 PM   #1521
OmarYasin
OmarYasin's Avatar
Ill look tomaro. I quoted bryan.16.88 taxfree
Old 05-07-2014, 05:35 PM   #1522
Hmongfrs
Drives: Red
FS: j2 exhaust flange scrape, scratches here and there $250obo, and i also have borla el headers for $250obo...located in stockton..
Hmongfrs is offline   Reply With Quote
Old 05-07-2014, 05:36 PM   #1523
tigermack
STX 188
tigermack's Avatar
Drives: STX BRZ
Send a message via AIM to tigermack
I have an used GoPro HD Hero 2, outdoor edition, it's in great shape for how much usage it's been through. I've only used it for autocross pretty much, never been under water or anything. I drilled a hole on the side of the case to fit a mic through it.
I upgraded to the 3+ black so I no longer need this.
I have an additional GoPro battery that comes with the purchase at asking price, $150. I also have an used LCD BacPac for $40. Works with the Original HD and HERO2.
Outdoor edition comes with a vented helmet strap, head strap, 2 curved and 2 flat surface adhesive mounts and a 3-way pivot arm.
Camera Optics
Lens Type: Fixed Focus (2ft/0.6m - ∞), glass
Aperture: f/2.8 (high performance in low-light situations)
Angle of View: 170° wide angle available in all modes
Angle of View: 127° medium angle in 1080p, 720P, or WVGA mode
Angle of View: 90° narrow angle in 1080p or 720P mode
Video
HD Video Resolution Modes:
1080p = 1920x1080 pixels (16:9), 30 fps
960p = 1280x960 pixels (4:3), 30 fps or 48 fps
720p = 1280x720 pixels (16:9), 30 fps or 60 fps
WVGA = 848x480 pixels (16:9), 60 fps or 120 fps
Sensor Type: 1/2.3" HD CMOS
Light Sensitivity: Professional low-light sensitivity (>0.84 V/lux-sec)
Video Format: H.264 compression, saved as Windows- and Mac-compatible MPEG4 (.mp4) file
Exposure Control: Auto with user-selectable center-weighted average and spot-metering settings
White Balance: Auto
Audio
Microphone: Built-in, mono with AGC (Automatic Gain Control)
External Input: Stereo 3.5mm jack
Audio Format: 48 kHz, AAC audio compression
Still Photo
Resolution: 11 megapixel, 8MP, or 5MP
Capture Modes: Single shot; photo every 0.5, 1, 2, 5, 10, 30, or 60 seconds; 10 photo burst; self-timer
Storage
Memory: SD card (SDHC), up to 32GB capacity (not included)
Average Recording Times (using 32GB SD card):
1080p (30 fps): 4h
960p (30 fps): 5.5h
720p (60 fps): 4h
720p (30 fps): 6h
WVGA (120 fps): 4.5h
Camera Connectors & Cables
PC Connection: USB 2.0 (data connection and battery charging)
HDTV Out: Mini-HDMI
TV Out: NTSC and PAL composite port
PC Compatibility: Windows® Vista or Windows® 7; Mac OS® X 10.5 and later
Power & Battery
Battery Type: Rechargeable 1100 mAh lithium-ion
Battery Life: Approximately 2.5 hours
Charging: via USB to computer or to power adapter (adapter not included)
Charge Time: 80% capacity after 1 hour from AC or DC source (requires adapter, not included) or 2 hours from USB port
Waterproof Camera Housing
Depth Rating: Up to 180 feet / 60 meters
Construction: Polycarbonate with stainless steel hardware
Size and Weight
Dimensions (H x W x D): 1.6" x 2.4" x 1.2" (42mm x 60mm x 30mm)
Weight: 3.3 oz (94g) including battery / 5.9 oz (167g) including housing
BacPac comes with different mounts for the back.
tigermack is offline   Reply With Quote
Old 05-07-2014, 05:45 PM   #1524
B2FiNiTY
JDM JUNKY
B2FiNiTY's Avatar
Drives: NSX
if that plate is real, gangsta
B2FiNiTY is offline   Reply With Quote
Old 05-07-2014, 05:47 PM   #1525
tigermack
STX 188
tigermack's Avatar
Drives: STX BRZ
It's not.
Old 05-07-2014, 06:07 PM   #1526
chas3wba0
chas3wba0's Avatar
Drives: Yes
Pretty sure it's shopped
"If thy pleaſure be in Underſteere, thou art Weird." - Distraxi
NW Marketplace v1.0 (CLOSED) DarrenDriven Northwest 2872 08-14-2015 02:48 PM
MCM FR-S now in NorCal!!! microcarmag Southern California 6 07-01-2012 06:01 PM
2nd BRZ in NorCal? Chauntalei BRZ First-Gen (2012+) — General Topics 15 05-29-2012 09:44 AM
Marketplace GenkiElite Off-Topic Lounge [WARNING: NO POLITICS] 3 02-08-2012 03:26 PM
