Old 05-05-2014, 10:12 PM   #29
CircuitJerk
Pull my finger...
CircuitJerk's Avatar
Drives: Silver Scion Slushbox
Originally Posted by SirBrass View Post
So the right 2-stroke oil would be...?
On phone I am. Therefore, if mistakes I make, Frank Oz blame you should.
If I knew, I would have mentioned it.
More of a general statement.
CircuitJerk is offline   Reply With Quote
Old 05-05-2014, 10:30 PM   #30
gramicci101
Off Topic
2 oz of Valvoline 2 stroke oil with TCw3 per 10 gallons of gas has my car purring smoothly. I'm sold. If it eventually shits a cat out, then I have an excuse to upgrade.
Old 05-05-2014, 10:33 PM   #31
cjsporl1996
Drives: WRB BRZ, Monte Carlo SS
I use lucas upper cylinder lubricant. It takes care of the crickets
cjsporl1996 is offline   Reply With Quote
Old 05-05-2014, 11:52 PM   #32
Aaron_blatherwick
I just started using SeaFoam the last time I filled up, 1oz to a full tank. Will see if it makes a difference.
Aaron_blatherwick is offline   Reply With Quote
Old 05-07-2014, 10:36 AM   #33
rice_classic
rice_classic's Avatar
Drives: Nevermorange FRS
Synthetic ashless.
1oz per 5 gallon. worked wonders on my econoline's v8. The thing has over 100k miles and this was like adding 20ft/tq to the damn thing.
Crickets are gone in the FRS.
The ashless two stroke is intended to be used and combusted at a 1:20 ratio. We're using it a 1:600 or higher so I'm not worried about fouled plugs or cats.
PRO86 | WTCC | STL
Old 05-07-2014, 12:20 PM   #34
Ghost 86
Drives: 2013 Whiteout FR-S
Last fill up I used a couple ounces of the pennzoil tcw3 and I can say the engines quieter smoother and the crickets aren't real noticeable
Ghost 86 is offline   Reply With Quote
Old 05-07-2014, 03:42 PM   #35
w00t692
Drives: 2008 Civic Si
I have used tcw3 2 stroke oil in my k20 for years. Shit's still clean as fuck and my compression is 220 on every cylinder, my valves look brand new. I swear by this stuff. It helps a LOT more when you're running e85 as well, that shit is relentlessly "dry" compared to regular gasoline.
w00t692 is offline   Reply With Quote
Old 05-08-2014, 04:57 PM   #36
schmearcampain
Drives: 2014 Argento FRS 6MT
I'm pretty sure any TC-W3 grade oil will work. The spec essentially means "ashless" or no residue/ash after combustion.
schmearcampain is offline   Reply With Quote
Old 05-08-2014, 05:02 PM   #37
Hyper4mance2k
Alexandrino_Auto
Hyper4mance2k's Avatar
Drives: series.Blue
2 Stroke will drastically lower octane level. I only know this from my near two decades of building and racing rotaries. You can use it, but be careful. A better bet might be MMO.
The Shadetree Project: I turn wrenches
Hyper4mance2k is offline   Reply With Quote
Old 05-09-2014, 01:01 AM   #38
SirBrass
Trust me, I'm the Doctor
SirBrass's Avatar
With the quantity per gallon you'd probably use with a rotary, you're probably right. But 2oz in 13 gallons (832oz of gas to 1oz of 2-stroke oil)? I doubt it'd lower octane by 0.1 AKI, if even that.
^GT5 Replay Photo Mode^
Old 05-09-2014, 09:32 AM   #39
w00t692
I doubt it would even lower it by .1 lol Maybe hundreth's.
Old 05-09-2014, 02:39 PM   #40
Hyper4mance2k
Alexandrino_Auto
Drives: series.Blue
The rule of thumb is that a ratio of 1/2 an oz per gallon lowers it equivalent to 10 points.
Old 05-09-2014, 02:44 PM   #41
SirBrass
SirBrass's Avatar
By points you mean 0.1 octane. 10 points would be 1 octane.
that's 0.1 octane per 1/64th concentration (1 oz. per 1/2 gallon in ounces). now, the concentration we're talking about is 1/832 concentration. That's 13x as diluted. That's less than 0.1 loss in octane.
Old 05-09-2014, 04:10 PM   #42
Hyper4mance2k
Alexandrino_Auto
Drives: series.Blue
I mean 10 octane.
chirping, noise
Plano Tx - Quaker Steak & Lube Meet 20firestorm13 Southwest 1 06-03-2013 04:55 PM
So my girlfriend took the car to Jiffy Lube... Mandy Other Vehicles & General Automotive Discussions 24 04-08-2013 02:35 PM
How shall I lube? jimmillion Off-Topic Lounge [WARNING: NO POLITICS] 5 11-17-2012 01:13 AM
Anyone change transmission lube yet? BMWDavid Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 14 08-21-2012 05:47 AM
the BMW killer! RRnold Off-Topic Lounge [WARNING: NO POLITICS] 10 08-28-2010 01:48 AM
