Old 05-05-2014, 12:52 PM   #323
jamesm
at 420ish whp on my gtx2867r i have major, major traction issues on my crappy kumhos. i'm sure with better tires it would be more manageable, but 350lbft makes 3rd/4th gear rolling burnouts a reality.
personally the only thing i hate about going with a bigger turbo (which i intend to do, 3076r) is that i will lose the 'kick' that you get from the 2867. it's a pretty intense shove compared to the 30r and larger turbos, even though you're ultimately making more power with the bigger ones it doesn't always 'feel' that way.
The Following 2 Users Say Thank You to jamesm For This Useful Post:
Reaper (05-18-2014), Sportsguy83 (05-05-2014)
Old 05-05-2014, 01:11 PM   #324
Rican_D
Rican_D's Avatar
Drives: Asphalt FR-S
I'm really surprised how well these engines are taking boost considering the high compression.
Rican_D is offline   Reply With Quote
The Following User Says Thank You to Rican_D For This Useful Post:
Old 05-05-2014, 06:26 PM   #325
xwd
Originally Posted by jamesm View Post
The 3076r seems to be the best balance of area under the curve and sheer power potential that I've seen thus far. I've tuned all the gtx's, borg warner, precision etc. it just the best all around. That doesn't mean that it's the best for every application, though.
What about the BW7163? Guys saw pretty amazing results with that on the 2.5L STi motor. Not quite as big of numbers as the 3076R but close, it spooled quite a bit faster, and the response is quite a bit better. I'd love to see some results from it on this motor.
The Following User Says Thank You to xwd For This Useful Post:
cdrazic93 (05-19-2014)
Old 05-05-2014, 06:59 PM   #326
sw20kosh
Drives: 2013 Black FR-S
How similar do you think its performance would be on an AP2 S2000?
You could take a look at ptuning's s2000 kit to get an idea. The base kit uses a 3076r. 400-420 whp on 93 octane.
http://www.s2ki.com/s2000/topic/8972...-s2000-ptuned/
GTX3076r on 93 octane
http://www.s2ki.com/s2000/topic/1038...t__p__22896126
The Following User Says Thank You to sw20kosh For This Useful Post:
Old 05-05-2014, 07:35 PM   #327
jamesm
That's a dyno dynamics remember... Easy way to gain 10% lol. That's assuming they're in 'dynojet mode' which tends to read crazy high from what I've seen. Not saying it is, but looking at it I'd guess it might be. Either that or s2000's are beasts
EDIT: just read that s2000's come from the factory with forged internals... so uh yeah... they're beasts. and i kinda want one now.
The Following User Says Thank You to jamesm For This Useful Post:
Old 05-05-2014, 07:48 PM   #328
spitfire481
spitfire481's Avatar
Drives: 2JZ FRS
we activated boost by gear on my car with ecutek. 9psi in 1/2, then 18 in 3/4/5/6. Ill never go back lol
The Following User Says Thank You to spitfire481 For This Useful Post:
Old 05-05-2014, 07:50 PM   #329
sw20kosh
From what I have seen yes the si and s2000 engines make much higher power numbers I'd speculate due to that 2nd big cam profile that comes online, higher flowing heads, and higher redline. (Though I don't think all or any Si engines have that 2nd cam profile I could be wrong.
Old 05-05-2014, 08:36 PM   #330
ptuning
ptuning's Avatar
Drives: White FR-S
Our low-mount S2000 turbo system is extremely efficient as is the F20xC engine in the S2000.
On a side note, to answer the question regarding dyno numbers..... ALL of the Dyno Dynamics numbers that we publish are uncorrected, true Dyno Dynamics numbers. There is no "X" or fudge factor in ANY of our published dyno numbers. An S2000 that made 430whp with a GT3076R on 13.5psi on 93 pump gas made 475whp on a local Dynojet. Our dyno typically reads about 10-12% lower than a Dynojet, 13-15% lower than a Dynopack, and 2-3% lower than a Mustang dyno.
I can say this without being biased as we produce turbo systems for both the S2000 and FR-S/BRZ..... the F20xC engine in the S2000 is the baddest 4-cylinder production engine in stock form on the planet when it comes to both VE and strength, period, EOS. S2000 engines have seen 700-800whp on a Dynojet unopened. The FA20 engine probably comes in second in terms of efficiency, but lower down the ladder in terms of strength (amongst 4 cylinder engines).
With this said though, you can probably hit 600whp on a Dynojet with a GTX3076R at around 20psi with E85 on an S2000. Assuming the FA20 engine could hold the power, the same numbers would probably be attainable around 25-27psi on the same turbo running E85 too.
- Toan
ptuning is offline   Reply With Quote
The Following 2 Users Say Thank You to ptuning For This Useful Post:
MooKz (05-05-2014), Sportsguy83 (05-05-2014)
Old 05-05-2014, 08:59 PM   #331
jamesm
- Toan
that's not helping make me not want to buy an s2000
Old 05-05-2014, 09:10 PM   #332
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
What about if I buy one and let you tune it on Hondata? Would that help you?
The Following 2 Users Say Thank You to King Tut For This Useful Post:
jamesm (05-05-2014), Sportsguy83 (05-05-2014)
Old 05-18-2014, 01:08 AM   #333
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Confirmed my mustang numbers with a local dynojet and Rev Work assessment of their dyno reading 20% low are pretty much on point. Map 3 which we calculated to be 499 whp dynjoet after adding 20%, yielded 496... That mans map4 was really close to 550 (iriginally calculated to be 552 after adding 20%).
439 whp run was @14 psi,
The 496 whp run is @ 17 psi..
The Following User Says Thank You to Sportsguy83 For This Useful Post:
sw20kosh (05-18-2014)
Old 05-18-2014, 03:35 AM   #334
sw20kosh
Gotta love that corn!!! What a diff e85 makes! Are you going to dyno with straight 93 at all?
Sportsguy83 (05-18-2014)
Old 05-18-2014, 09:48 AM   #335
Sportsguy83
Drives: Limited BRZ
No. I had initially dynoed 93 and did 320 at 10 psi, but there were a lot of things unfinished from cam timing to fast spool, but I rarely go on 93 so don't think I'll get it down to E10-15 to do a few runs.
Corn is a helluva drug...
Old 05-18-2014, 10:00 AM   #336
Reaper
in orbe terrum non visi
Reaper's Avatar
Drives: violent
How long have you been driving in the 400's on stock internals?
Sent from my SAMSUNG-SGH-I747 using Tapatalk
gtx3076r, kab customs, kab where amazing happens
Shift-knob Developed! - Team Voodoo Koji_Online Cosmetic Modification (Interior/Exterior/Lighting) 91 09-28-2020 03:49 AM
Local custom exhaust Gen Southern California 7 11-18-2013 08:11 PM
Report: Supercharged Toyota 86 being developed by TRD!! Craikeybaby Engine, Exhaust, Transmission 205 03-04-2012 03:42 PM
Navy developed and tested a railgun SVTSHC Off-Topic Lounge [WARNING: NO POLITICS] 21 03-01-2012 07:43 PM
