Old 05-05-2014, 02:25 AM   #813
brz7400
brz7400's Avatar
Drives: Subaru BRZ
Wow your car has good pick up!
brz7400 is offline   Reply With Quote
The Following User Says Thank You to brz7400 For This Useful Post:
Scooby South (05-05-2014)
Old 05-05-2014, 02:53 AM   #814
PoWn3d_0704
PoWn3d_0704's Avatar
Drives: 1990 BNR32 GTR
@Scooby South
I have a couple questions, as someone who is JUST getting into AutoX and would love to be competitve in the STX class (since I've already locked myself in there).
What would you consider the best mods for STX you have done to 'eliminate the car from the equation?'
I also was wondering why the 4-2-1 long header when compared to other options?
And lastly, how much do you like the coils? I am in the market.
For Reference I have:
Wilwood BBK, 6pot front and 4pot rear, SS brake lines, Motul RBF fluid
Perrin 3" resonated w/ 3" catted Front Pipe, stock header/OP.
Perrin 19mm front sway w/ poly endlinks
Perrin intake w/ KnN drop in
17x9 +42 Mach V Awesomes wrapped in RS3 v2's (on order, to meet the 200 treadwear req. next year)
And that's about it. I'm pretty competitve already locally, but would like to be able to show up anywhere and do okay.
Picked up my BRZ on 6/11/13.
Build Album:
PoWn3d's BRZ Pictures
Build Thread: PoWn3d's BRZ
PoWn3d_0704 is offline   Reply With Quote
Old 05-05-2014, 12:15 PM   #815
Scooby South
Conedancer
Scooby South's Avatar
Drives: 2013 Subaru BRZ SWP
Originally Posted by PoWn3d_0704 View Post
@Scooby South
Hi there.. couple of things.. My car is built to the letter of the STX ruleset. theres not much left I can/need to do. When I say that I want to eliminate the car from the equation, it means that I can eliminate the car because it is fully built with plenty of adjustment to be able to get the car right. Setup takes lots of trial and error. So I can adjust on the car to get it right for the particular course/conditions and then ....after that..Concentrate on "ME" the driver.. knowing the car is under foot and not having to try and figure out why the car 'isn't' performing and not being able to concentrate on "Driving".. if that makes sense..
4/2/1 header gives you some "off the corner" umph to get it going.. Longer tube headers produce the power/torque in a lower RPM range, so you can "pull" off the corner.. Short tube headers rotates the power to the right on the RPM scale which translates to a Higher RPM power band...Vs the longtube which produces it more to the left of the RPM gaining pickup vs. Topend..
and lastly.. coils are somewhat personal.. But most top level drivers get "Dual" Adjustable Coilovers so they can fine tune Rebound and Compression. Rebound only coils..... IE: BC, fortune auto, any other Cheap Chinese brand.. tend not to be the best option for Autox due to the needed adjust-ability for the different conditions. Popular Dual Adjustable Coilovers are a bit more expensive.. but provide the best feedback... Some examples of are MCS, KW, Cusco, Eibach, Bilstien, etc... Depends on how serious you want your build to become.. http://www.motioncontrolsuspension.com/
With my car pretty much to the letter of the rules.. expect about 20K on costs.. mild builds are about 7k or so.. again depending on the components you use. Do yourself a favor.. Make a spreadsheet of what your budget is.. Include the big ticket stuff, Tune, headers/exhaust, Suspension, wheels and tires...and Misc stuff like the rear Diff (LSD). Bushings. Alignments, etc...and see where you land.
It looks like your on your way to a decently prepped car.. But don't just add parts to the car just to add parts.. Plan your build according.. and read the rules... ALOT.. I re-visit the rules everytime I add something to the car.. again mine is a full National build..but should apply locally also
LMK if I can help
Bill
Scooby South is offline   Reply With Quote
The Following User Says Thank You to Scooby South For This Useful Post:
No5ki (05-30-2014)
Old 05-05-2014, 12:19 PM   #816
vroom4
Not trying to take this off topic or turn it into an advertisement, but if someone wants to put together an entry level STX prep package let me know, Terry can probably get you a great deal through Maximal Performance. He worked with me and got me a great deal on my CS prep.
And Ill wait for Annie to get sick of her car and try to be first to scoop up the salvage parts .
vroom4 is offline   Reply With Quote
The Following User Says Thank You to vroom4 For This Useful Post:
Old 05-06-2014, 01:55 AM   #817
PoWn3d_0704
@Scooby South, honestly, with a great tune, do you think the full exhaust, BBK, coilovers (I really want Ohlins) and sway bars (are 19mm front and 16mm rear big enough?) Are enough to be competitve? Along with the 245 tires on 9" rims?
How much do you like the LSD?
Build Album:
Old 05-06-2014, 06:48 PM   #818
Scooby South
Conedancer
What level of competition?? Locally...Regionally or Nationally..
With the mods that you have and the ones you have planned.. you should be fine locally and Regionally..Nationally.. When the competition is within a second of each other from 1st thru 10th.. then every 1/10th counts.. My suggestion is to learn the car.. with your current plan.. learn to adjust on it.. learn to drive it.. and yes 245's on 9's are fine.. some national level guys run the same setup. I would suggest doing all the bushings as well. (maybe $500) total.. and it will tighten up any loose ends....Literally ...if you look at my mod list above.. you will see.. theres not much left to do..
I would also suggest some driver instruction along the way.. Evolution or similar to get the most out of your experience..
You should be adequate with what you have to become competitive ... ..Remember enjoy yourself.. and LEARN what the car is telling you.
Bill
Old 05-06-2014, 07:29 PM   #819
Dezoris
Dezoris's Avatar
Bill
Are you still running any regional events?
The Following User Says Thank You to Dezoris For This Useful Post:
Scooby South (05-06-2014)
Old 05-06-2014, 07:34 PM   #820
Scooby South
Conedancer
yes...absolutely...when available.
Bill
Old 05-06-2014, 08:02 PM   #821
Dezoris
Dezoris's Avatar
Bill
I was looking at your SCCA results its funny, so many of the same people running the events after all these years.
PoorMansRacing (05-20-2014)
Old 05-07-2014, 11:09 AM   #822
mrazny
Drives: BMW 135i, soon to BRZ
Cash and Frank are likely lifers.
mrazny is offline   Reply With Quote
The Following User Says Thank You to mrazny For This Useful Post:
Scooby South (05-07-2014)
Old 05-20-2014, 01:21 PM   #823
Scooby South
Conedancer
Heres one of my Runs from Sunday... Preparing for Lincoln, doing Tire tests.
[ame]http://youtu.be/IuEW705GpKM[/ame]
Old 05-20-2014, 04:10 PM   #824
PoorMansRacing
Anorexic
PoorMansRacing's Avatar
Drives: 2003 Honda S2000 Suzuka Blue
What tires do you prefer?
2003 Honda S2000, SCCA Club Racing T3
2013 Subaru BRZ Limited, SCCA Solo II STX
2008 Honda S2000 CR, SCCA Solo II STR
PoorMansRacing is offline   Reply With Quote
Old 05-20-2014, 04:12 PM   #825
vroom4
FYI: @Maximal is working on an oil cooler kit for y'all STX drivers which isnt stupid priced like the competition. Hopefully the board rules in favor.
Old 05-20-2014, 04:14 PM   #826
tahdizzle
So elite I'm 1338
Drives: WRB Subaru BRZ
as far as I know... Oil coolers are not legal in STX. But good to know.
Subaru/Scion warranty and autocross Ribface Tracking / Autocross / HPDE / Drifting 55 06-17-2015 08:30 PM
Will you Autocross your 86? Ribface Tracking / Autocross / HPDE / Drifting 131 06-22-2012 05:48 PM
Which autocross class? jpdarty7 Tracking / Autocross / HPDE / Drifting 66 06-21-2012 05:53 PM
FR-S at a CA Autocross oneday Scion FR-S / Toyota 86 GT86 General Forum 57 03-26-2012 03:38 PM
