Old 05-05-2014, 09:09 AM   #1499
Dipstik-sportech
Dipstik-sportech's Avatar
Jesus 15psi and only 320whp?!! I made more on a gt28 with the same engine and on pump with the pte I was over 400 wheel. Something isn't right there
The Frozen North
Old 05-05-2014, 09:52 AM   #1500
Deadspool
Much title. Wow.
Deadspool's Avatar
Drives: 2013 BRZ Sport-Tech
How did you identify blown headgasket during turbo swap?
༼ つ ◕_◕ ༽つI PUT A SPELL ON YOU ༼ つ ◕_◕ ༽つ
Deadspool is offline   Reply With Quote
Old 05-05-2014, 10:01 AM   #1501
blackfireball5
blackfireball5's Avatar
Drives: Scion FRS Firestorm
Originally Posted by FullBlown View Post
Please call us, we have a revision on those lines and will send you a set free of charge
Took it apart. The tube was brittle and disintegrating. Looked like it would have burst any moment.
Thanks for the response and diligence! I'll give you guys a call on my lunch break!
blackfireball5 is offline   Reply With Quote
Old 05-05-2014, 10:27 AM   #1502
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
There's a lot more factors to consider than X psi equals Y power. Ignition timing, cam timing, boost targets, type of boost control used... We cannot just equate a power number to a psi number and call it a day..
Old 05-05-2014, 11:01 AM   #1503
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
Originally Posted by pmccut View Post
@DeliciousTuning suggested switching back to the stock injectors as he thought we could hit 400whp (dynojet) on 91 pump with my setup without maxing the injectors. He tuned it local to me last week and it made 270whp @ 15psi on a MAHA dyno. That's probably 320whp dynojet. It looks like the port injectors are pretty maxed out :/
So now my car is running smoother than it ever has, but making less power on a larger turbo. Now I'm still left scratching my head what to do.
Personally I would find another tuner. A tuner should never recommend going back to OEM injectors so he can run them on the ragged edge of duty cycle when you have perfectly good upgraded 550s and 1000s. It sounds like he has issues tuning the injector scaling on the aftermarket injectors. My advice would be to go get on a Dynojet and see what the car does. I am not that familiar with what kind of power cars should see with lower compression on 91 octane, but I would throw the bigger injectors back in and turn up the boost.
Sportsguy83 (05-05-2014)
Old 05-05-2014, 11:13 AM   #1504
Dipstik-sportech
Well I have the same engine, basically the same turbo same fuel and we both had 1000's so we theoretically be near in power. The only variable is the tuner
The Frozen North
Old 05-05-2014, 11:26 AM   #1505
Sportsguy83
Drives: Limited BRZ
The Frozen North
Ye sir, all factors I mentioned are 100% dependent on tune.
Old 05-05-2014, 12:26 PM   #1506
jamesm
There's absolutely no reason whatsoever to try and push stock injectors to the ragged edge when you have a set sitting there. Install the bigger injectors, get them tuned and profit.
Old 05-05-2014, 12:37 PM   #1507
King Tut
NASA SpecE30 Racer
King Tut's Avatar
By charging for rides?
Old 05-05-2014, 12:39 PM   #1508
jamesm
Exactly.
Old 05-05-2014, 02:00 PM   #1509
Sterz
Great White
Drives: 2013 Whiteout FRS
Guys we shouldn't just jump to conclusions, there HAS to be something else going on. Bill @DeliciousTuning tuned my car. I made 370whp on their mustang dyno (~438whp on a jet figuring 20%) at 15 PSI on e85. I have Bosch 1000's and he was able to dial them in like a dream, and not once telling me that I needed smaller injectors. I don't think he has a problem dialing in injectors. I think there is some information we aren't getting. I beat the living hell out of my car at the track and practice drift events and I have not had one single problem. AFR's are ~11.8 at wot and I haven't seen leaner. Something just seems fishy to me, I just think there are too many variables to go and blame the tuner. (and no I am not one of those guys who worships their tuner like a god and thinks all the rest are crap). I think there is something else going on.
Sterz' Great White 86
http://www.ft86club.com/forums/showthread.php?t=54533
Invidia Q300 Catback | Invidia Catless Frontpipe | Invidia Overpipe
Sterz is offline   Reply With Quote
The Following User Says Thank You to Sterz For This Useful Post:
DeliciousTuning (05-05-2014)
Old 05-05-2014, 02:26 PM   #1510
pmccut
Drives: Blue Subarus
I think it's the lower compression. All the cars tuned there so far have been stock engines, so there's not nearly as much to change to make the power. I think he just wanted to get rid of as many variables as possible. That's not what he said, but I can't see any other good reason.
'13 GBS BRZ 6MT | FBM 9:1 w/ GTX3076R| FBM oil cooler + catch-can + radiator + SPAL fans| Rays 57xtreme / PSS | Perrin 2.5" FP | Invidia 2.5" OP | Perrin 3" CBE | RCE T2s | Exedy Stg1
'15 STI LE | Cobb Stg1
pmccut is offline   Reply With Quote
Old 05-05-2014, 02:28 PM   #1511
Infamous Performance
Infamous Performance's Avatar
Drives: 02 WRX, 05 LGT, 08 LGT, 08 SpecB
Sterz, your IDC was 44% with those 1000cc on e85 too.
PM, glad we could assist with getting the head gaskets replaced and the oil leaks fixed.
King Tut, Bill does not run port to the "ragged edge". He does not normally go above 94% IDC.
Deadspool, we identified the blown head gasket as soon as we put the car on the dyno. We did not drive it prior to swapping turbos as we were told the tune was suspected of causing drive-ability issues. But on start up after the swap, we had the smell of burnt marshmallows from the exhaust, liquid dripping from the exhaust even after reaching operating temp and coolant dripping into the header from the exhaust valves.
Infamous Performance is offline   Reply With Quote
The Following 2 Users Say Thank You to Infamous Performance For This Useful Post:
Deadspool (05-05-2014), pmccut (05-05-2014)
Old 05-05-2014, 02:45 PM   #1512
Deadspool
Much title. Wow.
Deadspool's Avatar
Good to know, Ive been smelling feint bits of coolant lately. No overheating issues are present though.
best company ever, big fuck off turbo, blown, bow chicka wow wow, fbm, full, owners, powaaaaaa!, thread, will work for turbo
AVO Turbo Kit Owners Topic Sportsguy83 Forced Induction 1935 02-20-2023 11:46 AM
Full Blown FRS/BRZ Stage 1 Turbo Kit FullBlown Forced Induction 456 09-27-2021 04:10 AM
FA20Club Turbo Kit Owners Topic pixel67 Forced Induction 1531 09-09-2014 01:36 PM
Full Blown Turbo Kit! Unleashed Engine, Exhaust, Bolt-Ons 70 10-09-2013 10:46 AM
WTB: Full Blown turbo kit (used) whitefrs Engine, Exhaust, Bolt-Ons 12 03-29-2013 10:15 PM
