Old 02-08-2014, 08:56 PM   #43
Mikepage
Mikepage's Avatar
Drives: Scion FR-S 2013 Raven
Originally Posted by mad_sb View Post
Mine was the same, as soon as i adjusted the lockout more to the left it got better, much better. If your lockout plate is preventing you from lining up the gate just right it will make it notchy.
Ok thank for the info, then I will check the lockout plate.
o= FR-S =o
Mikepage is offline   Reply With Quote
Old 02-09-2014, 08:50 AM   #44
koevasi
koevasi's Avatar
Drives: 1
i have tried the whiteline+mtec+kartboy combo. it does have more distinct and certain shifts except its a little too stiff and heavy. the shifting action has to be in line with steering and pedal inputs and these parts go a little over the top..
koevasi is offline   Reply With Quote
The Following User Says Thank You to koevasi For This Useful Post:
Mikepage (02-09-2014)
Old 02-09-2014, 12:10 PM   #45
lickitysplit
Don't care
Drives: 2013 Whiteout FRS
What knob are you using?
I found the knock off ebay short shifter (same type of design as the billet pro rattled like hell from 4k and up, it was much worse with my mtec drift shift knob than with the stock knob.
My kartboy barely rattles with the mtec drift and only slightly noticeably with the stock knob. Weighted knobs seem to reduce rattle, i guess because they act like a mass damper.
I have the stock knob. The shifter shouldn't rattle under any circumstances, hence why I'm taking it off.
lickitysplit is offline   Reply With Quote
Old 05-05-2014, 12:32 AM   #46
johnnyfast11
Drives: none yet
you can do it all.
but if you do the whiteline insert, then dont add the perrin/forcefab.
if you add the perrin/forcefab, then dont do the whiteline.
having both right under need the trans will rattle your teeth out.
johnnyfast11 is offline   Reply With Quote
The Following User Says Thank You to johnnyfast11 For This Useful Post:
Mikepage (05-05-2014)
Old 05-05-2014, 12:41 AM   #47
Mikepage
Mikepage's Avatar
Best shifter setup
Originally Posted by johnnyfast11 View Post
you can do it all.
I have the Whiteline trany insert for the shifter, I will stay only with this concerning the trany.
Just the Whiteline already add some noise, but I love it, it's not too much... I don't imagine with the Perrin...
If I do an another mod for the shifter, I will take the TRD short shifter for sure.
Thanks!
o= FR-S =o
Manual MT Shifter Boot Swap Onto Automatic AT Shifter Assembly? soulstice Cosmetic Modification (Interior/Exterior/Lighting) 52 01-24-2016 08:20 PM
kartboy short shifter and rear shifter bushing install and review. FR-S UMB FR-S DIY (Do-It-Yourself) Guides 21 10-18-2014 01:41 AM
Anyone have this setup? Gt86_nick Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 23 03-04-2014 05:32 PM
Shifter TSB 03-71-13 v. Perrin Rear Shifter Bushing swansons Issues | Warranty | Recalls / TSB 4 02-02-2014 02:27 PM
Thoughts on a "component" setup with a 3.5" dash and 6.5" door setup? PatrickSAN Electronics | Audio | NAV | Infotainment 22 11-14-2012 02:12 PM
