Old 05-01-2014, 01:00 PM   #1289
SirBrass
Trust me, I'm the Doctor
SirBrass's Avatar
What I want to make sure of is that a laminova mocal oil cooler will fit with a Vortech install. I don't want 3 air-air or air-liquid heat exchangers out front. Two is enough (radiator and FMIC), what with the a/c condenser sandwiched there near 2 heat-radiating heatsinks already. No need to add a 3rd. Also, a laminova cooler acts as an oil temp regulator, and for Phoenix heat, that's just smart. Moreso than an oil cooler driven by moving air. I want to reduce engine bay heat, so keeping the heat in the radiator system just seems like a good idea.
So, how to integrate the mocal install listed in the DIY section to this. OR, is the mocal cooler listed in the DIY larger than it needs to be (since it's keeping oil temps at 212 F, which might be a little low... right?).
^GT5 Replay Photo Mode^
Old 05-01-2014, 01:04 PM   #1290
FyeaFRS
Drives: 1992 Nissan Skyline GTS-t Type-M
Pretty much the main reason I even considered replacing the oem radiator.
In retrospect, I'm pretty sure I would have gone with the GReddy, HKS or other side mounted oil cooler, rather than adding another radiator to the pile. But only if they were more reasonably priced.
FyeaFRS is offline   Reply With Quote
Old 05-01-2014, 01:34 PM   #1291
HRTROB
HRTROB's Avatar
Drives: Toyota 86
Originally Posted by FyeaFRS View Post
I installed the Mishimoto when I put in my Vortech, wasn't very difficult. Now clamping all the loose hoses on the other hand...
Were you able to reinstall the fans on the car with the blower already installed? When I did mine, there was no way the fans were going to go in. I had to move the blower out of the way.
HRTROB is offline   Reply With Quote
Old 05-01-2014, 01:45 PM   #1292
SirBrass
SirBrass's Avatar
Even the cusco liquid oil cooler (sits like a sandwich plate, and has water lines running to the radiator hoses) is overpriced and says that it kicks in when oil temps go above 266F.
The Greddy oil cooler looked good till I saw its $1k price tag. Good grief! The laminova core way seems about the same price as Mishimoto or Perrin air/liquid methods.
Old 05-01-2014, 02:09 PM   #1293
FyeaFRS
I installed the radiator first and put everything back together before installing the vortech. Even though I had to loosen/take off some the parts again, I just wanted everything to fit back together properly.
Also, anyone else have a hard time mounting the intercooler and having the splash guard go back on a bit messed up?
Old 05-01-2014, 02:53 PM   #1294
Tye300
Tye300's Avatar
Drives: Toyota 86 TRD Version AT
With the supercharger, the way the laminova was installed in the pic would not work. It would get in the way of the blower itself from the way it looks in the pic. I think you can mount it flat on the plastic floor in front of the intercooler and it would not block it that much. Or you can take the styrofoam out from the crash beam and install it on the crash beam itself. But not knowing the exact dimensions of the cooler itself makes it a guess also. Plus how to extend the radiator hose to the front would be a hurdle also. You could also mount it behind the foglight area, since it does not need air to cool it. Just some ideas.
Tye300 is offline   Reply With Quote
The Following User Says Thank You to Tye300 For This Useful Post:
SirBrass (05-01-2014)
Old 05-01-2014, 03:06 PM   #1295
SirBrass
SirBrass's Avatar
Here's where info on the specific laminova core that the guy was talking about can be found: http://www.racerpartswholesale.com/p...eat_Exchangers
Old 05-01-2014, 05:12 PM   #1296
Foobar
SLO NO MO
Foobar's Avatar
Originally Posted by Red FRS View Post
The oil is in the cross hairs. I put the full 4oz bottle in after draining it.
I seem to recall some discussion about not using the full 4oz bottle since you can't actually drain the oil completely, did Vortech get back to you?
Old 05-01-2014, 05:16 PM   #1297
415FRS
Drives: Red SCion FRS
Thats right. I had oil came out from the blower before when i put more than 3/4 of the 4oz.
Sent from my HTC One using Tapatalk
415FRS is offline   Reply With Quote
Old 05-01-2014, 05:54 PM   #1298
DJCarbine
Thupercharged
DJCarbine's Avatar
I run the oil in the middle of the cross-hatch area, if I run it full it will vent some excess oil out until it drops to the middle
If I fill to the middle I lose no oil between new oil fill and the next required change
2013 FRS
Vortech V3 11psi
Revworks UEL - PLM Overpipe - MOTIV catted frontpipe - Invidia Q300
2019 Series.Grey STI - Stage1+ SF
DJCarbine is offline   Reply With Quote
Old 05-02-2014, 08:39 AM   #1299
draggin_az
Small penis big dreams
draggin_az's Avatar
Drives: '13 Scion FR-S
^^^^ I experienced the same thing when i filled mine up. and it suuuuuuuuuuuuucks cleaning up all that oil
v3 -> v2 Vortech SC / 2.87 pulley
Fuel pump, FIC 770 injectors, custom header back, perrin resonated CBE
277hp 93 octane
370hp on E-85
draggin_az is offline   Reply With Quote
Old 05-02-2014, 10:41 AM   #1300
welllam
Drives: STi
I think robispec offers the best option out there but too bad he's not really active in this forum any more...
welllam is offline   Reply With Quote
Old 05-02-2014, 12:27 PM   #1301
FyeaFRS
The clearance here has me concerned. I got my kit used and there was obvious wear on the tube there.
Has anyone considered modifying the bracket there to move the pipe and few millimeters to the left..?
Old 05-02-2014, 12:53 PM   #1302
reyruiz191
reyruiz191's Avatar
Drives: 2013 FRS Vortech Supercharged
Vortech addressed the issue and as long as you sent in the warranty card they were replacing the pipe with one that had an indention to make more room for the belt to clear.
I personally have never had an issue with the belt touching the tube and I still have the original piping without the indention and I've been running the kit since April of 2013, you just have make sure you adjust the pipping well enough to clear the belt.
reyruiz191 is offline   Reply With Quote
Vortech Supercharger denverizzles Forced Induction 176 10-19-2013 06:48 PM
New Vortech Supercharging System Information... Brian@Vortech Forced Induction 306 11-08-2012 05:49 PM
Supercharging the GT86 Billy2224 Engine, Exhaust, Transmission 13 06-05-2012 03:58 PM
Turbo/Supercharging Your FRS BoostJunkie Engine, Exhaust, Transmission 123 05-18-2012 06:26 PM
Supercharging: the forgotten form of FI madfast Engine, Exhaust, Transmission 76 03-02-2012 05:06 PM
