Old 04-30-2014, 05:33 PM   #2115
Johnny_MA
Drives: 2014 Subaru Brz Limited WRB
Originally Posted by Kosmos View Post
I need more camber in the front. What would I need? My camber plates are maxed out on my coils or does it just depends on the coilover system
Sent from my SM-N900P using Tapatalk
Im in the same boat...I have camber bolts on my Bc extreme lows and they dont offer much more camber than what the plates give. Its the struts design. I believe we are gonna have to notch the holes in order to give the camber bolts more play? Any insight would be great aswell
Johnny_MA is offline   Reply With Quote
Old 04-30-2014, 09:46 PM   #2116
Crazy Drew
Drives: Smells like tires when I drive
When I worked in a machine shop I helped several friends by setting up their camber plates in my mill and slotted the holes further. Many of these cars were raced often and/or driven on the street with no failures. Unfortunately this was years ago and I no longer have access to the same equipment but a competent local machine shop should be able to slot the holes further without costing an arm and a leg or sacrificing the strength of the plates.
I would avoid slotting the towers at all costs.
I have also seen people slot the upper hole on the lower strut bracket to allow camber gain between the front knuckle and the strut. GTO's actually come this way from the factory. The only thing you'll have to worry about with this is contact between the coilover and wheel.
Crazy Drew is offline   Reply With Quote
Old 04-30-2014, 10:49 PM   #2117
Johnny_MA
Thats what I was refering to..slotting the upper hole on the lower strut bracket...I wouldnt even attempt to mess with the plates. Ive never done this before and im actually getting more camber on one side and everything is equal on both sides at the camber plates/bolts..Im at a loss
Old 04-30-2014, 11:00 PM   #2118
A-RS
A-RS's Avatar
Drives: Ultramarine FR-S (Candice)
A-RS is offline   Reply With Quote
The Following User Says Thank You to A-RS For This Useful Post:
van_fc3s (04-30-2014)
Old 04-30-2014, 11:26 PM   #2119
Frs123
Frs123's Avatar
Drives: Raven
Originally Posted by ShanHean View Post
Hey guys i dont really come on the forums a lot but heres a pic of my frs
They look so good. I'm going with work vsxx 18x10 +15 or +5 all around just have to figured out how to fit the front and which adapter size to go with since they're 5x114.3.
Instagram: erik239
Frs123 is offline   Reply With Quote
The Following User Says Thank You to Frs123 For This Useful Post:
ShanHean (05-01-2014)
Old 05-01-2014, 09:13 AM   #2120
cfig21
cfig21's Avatar
Drives: SWP BRZ Ltd , 96 240sx Built KA-T
Originally Posted by tr1x5tuh View Post
heres my contribution....
can't believe stance super sports are maxed out in the front. New set up in the works
@PradiG
I'm in the same boat except i took out 2 collars and preloaded all the way and its still not where i want it. John from Stance said I could droop the spring but idk how comfortable i feel doing that so i might go with BC extreme low or a similar setup to these meisterbaters are running
Check out my Build Thread:
Emma's build
Instagram: @cfig21
cfig21 is offline   Reply With Quote
Old 05-01-2014, 10:15 AM   #2121
tr1x5tuh
The Original Super Saiyan
tr1x5tuh's Avatar
Drives: 2014 SWP BRZ
That sucks man PadiG is selling his ark for a prett good price. But he's trying to keep it local. Hit him up for the right price and I'm pretty sure he will ship.
To each his own, Agree to Disagree
tr1x5tuh is offline   Reply With Quote
Old 05-01-2014, 10:25 AM   #2122
moomoopanda
moomoopanda's Avatar
Drives: Argento FRS
with BC's camber plates and upper camber bolts, I got to about -5 degrees.. with lower camber bolts, I was able to get to -6 degrees..
moomoopanda is offline   Reply With Quote
Old 05-01-2014, 10:28 AM   #2123
SmsAlSuwaidi
Boosted
SmsAlSuwaidi's Avatar
Drives: Not a supra....yet
Anybody running pbm coils ?
Sent from my IBrick
The Following User Says Thank You to SmsAlSuwaidi For This Useful Post:
DAEMANO (05-01-2014)
Old 05-01-2014, 11:05 AM   #2124
PradiG
Drives: Fr-s
When I maxed out my front coils (ARK) I couldn't turn my wheel cause my car just sat on the tire lol. I was running 18x9.5 with a 225/40.
So I didn't even max my coils when I has them cause I couldn't turn my wheel when I did
PradiG is offline   Reply With Quote
The Following 2 Users Say Thank You to PradiG For This Useful Post:
cfig21 (05-01-2014), tr1x5tuh (05-01-2014)
Old 05-01-2014, 11:14 AM   #2125
mr. slim
SoCal86
mr. slim's Avatar
Drives: '13 Whiteout FR-S
Sent from my IBrick
I am
.: SUPER KAWAII :.
.: BUBSQUAD :.
.: LivinLow :.
.: FRS86 :.
mr. slim is offline   Reply With Quote
Old 05-01-2014, 12:21 PM   #2126
moomoopanda
Drives: Argento FRS
BC Extreme Low's paired with PBM/Stance LCA's is the recipe for success if you wanna be slammed. I wanna say I'm one of the lowest static cars, probably pretty even with nab...
@nab335 told me to put my lip on to see how low it hangs, so I just kinda set it there and held it up with wrenches..
The Following 4 Users Say Thank You to moomoopanda For This Useful Post:
cfig21 (05-01-2014), Chokeefrs86 (05-01-2014), OAKOS Automotive (05-05-2014), stancypants (05-01-2014)
Old 05-01-2014, 12:46 PM   #2127
JayM2S
JayM2S's Avatar
Drives: 2013 Ultramarine Fr-S
sharing my work in progress on this awesome car
JayM2S is offline   Reply With Quote
The Following 2 Users Say Thank You to JayM2S For This Useful Post:
cfig21 (05-01-2014), Kosmos (05-01-2014)
Old 05-01-2014, 01:00 PM   #2128
cfig21
cfig21's Avatar
Yea im settled on going with BC extreme low after offset kings since i cant get it done before then. my exhaust is the only thing im concerned with.
Emma's build
Instagram: @cfig21
dontlike?dontlookmoveon
Post the Wheels You want On your FRS/BRZ!! Zaku Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1738 10-11-2017 04:29 PM
RPF1 and PF01 aggressive fitment size requests Crossover Auto Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 12 10-22-2012 02:30 PM
post VIN with any problem thread? fistpoint Issues | Warranty | Recalls / TSB 0 10-04-2012 10:11 PM
Do aggressive offsets cause more debris to kick up into the paint? switchlanez Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 7 09-26-2012 10:03 PM
Scion FR-S / Toyota FT-86 / Subaru with Aggressive Body & High Wing! + VIDEO! Hachiroku Scion FR-S / Toyota 86 GT86 General Forum 538 06-15-2011 02:20 AM
