Old 05-01-2014, 06:35 AM   #1275
HRTROB
HRTROB's Avatar
Drives: Toyota 86
I don't know if my airbox bracket is different or not, but I have some clearance with my Perrin oil cooler
HRTROB is offline   Reply With Quote
The Following User Says Thank You to HRTROB For This Useful Post:
Tye300 (05-01-2014)
Old 05-01-2014, 08:42 AM   #1276
SirBrass
Trust me, I'm the Doctor
SirBrass's Avatar
Originally Posted by Tye300 View Post
First time to see this solution. Thanks for this!
Looking at prices, it looks to be cheaper than a Perrin or Mishimoto oil cooler, too. And it's the same oil cooling concept as in a robispec radiator.
On phone I am. Therefore, if mistakes I make, Frank Oz blame you should.
^GT5 Replay Photo Mode^
Old 05-01-2014, 09:32 AM   #1277
HRTROB
HRTROB's Avatar
Drives: Toyota 86
Originally Posted by SirBrass View Post
I wonder, what about this as an oil cooler solution to use with the Vortech. It'll keep you from having to have yet another air-based heat exchanger:
http://www.ft86club.com/forums/showthread.php?t=42511
Looks like it will get in the way of the bypass valve if installed exactly like that guy did, in the lower radiator hose.
Old 05-01-2014, 09:35 AM   #1278
SirBrass
SirBrass's Avatar
Well, it has to be installed on the cold side of the radiator.
And a bpv can be relocated, right?
Old 05-01-2014, 09:45 AM   #1279
sissupr
sissupr's Avatar
Drives: 2014 BRZ Premium - SWP
If I didn't want to tackle this Vortech install... what should I expect to pay a shop for the install? 5-6hr or labor...
sissupr is offline   Reply With Quote
Old 05-01-2014, 11:09 AM   #1280
draggin_az
Small penis big dreams
draggin_az's Avatar
Drives: '13 Scion FR-S
trust me when i say you can tackle it. i did it in my aunts drive way with hand tools.
also its not a 5-6 install lol. it took me a little longer to install it then normal (i have a habbit of taking my time and getting side tracked) and i had 24 hours of install time. most are reporting 18-20.
honestly its easy. theres A LOT of little things to do so its time consuming but if you have common sense and the basic understanding of tools, you can do it.
v3 -> v2 Vortech SC / 2.87 pulley
Fuel pump, FIC 770 injectors, custom header back, perrin resonated CBE
277hp 93 octane
370hp on E-85
draggin_az is offline   Reply With Quote
Old 05-01-2014, 11:50 AM   #1281
HRTROB
HRTROB's Avatar
Drives: Toyota 86
Yup it's definitely doable. The only step where I needed an extra hand was when I had to slip the belt in. The blower's bracket made it extremely difficult to manipulate the belt tensioner. You don't have a good leverage because you must use a short open end wrench and then you have to pull up on it. Very frustrating.
If you plan on upgrading your radiator, I would strongly recommend doing it the same time you install the supercharger. I installed mine after, and I had to remove the blower again. Hardest part again was reinstallation of the belt.
After you're done with the installation, reward yourself with a nice cold beer, and prepare yourself to have a sore body for the next 2-3 days
The Following 2 Users Say Thank You to HRTROB For This Useful Post:
draggin_az (05-01-2014), Tye300 (05-01-2014)
Old 05-01-2014, 11:53 AM   #1282
SirBrass
SirBrass's Avatar
What about getting and installing a better radiator before getting and installing the Vortech?
Pretty sure this is the FI solution I want, after much internal debating and weighing of options. But I want to do things in stages. I think a better radiator and a laminova oil cooler would be good things to get and get installed well before I even make this purchase.
Old 05-01-2014, 12:00 PM   #1283
draggin_az
draggin_az's Avatar
if you hvae a lift or access to a lift, use it
@HRTROB is right. your body is going to be sore esp your back.
277hp 93 octane
370hp on E-85
The Following User Says Thank You to draggin_az For This Useful Post:
HRTROB (05-01-2014)
Old 05-01-2014, 12:04 PM   #1284
HRTROB
HRTROB's Avatar
Drives: Toyota 86
Installing a radiator on a NA car should be a walk in the park. You just have to remove the bumper, airbox and the metal beam above the radiator.
I thought you were going to stay NA with 200whp on 91?
Old 05-01-2014, 12:09 PM   #1285
SirBrass
SirBrass's Avatar
I am for now. Probably for the next year or so while I get everything else done. But I want to make sure all the mods I do do in the engine bay are compatible with a future FI installation.
Old 05-01-2014, 12:18 PM   #1286
HRTROB
HRTROB's Avatar
Drives: Toyota 86
Sounds like a good plan
Old 05-01-2014, 12:39 PM   #1287
Tye300
Tye300's Avatar
Drives: Toyota 86 TRD Version AT
That's the path I took which ultimately led to installing the vortech. Can't go wrong with that.
Tye300 is offline   Reply With Quote
The Following User Says Thank You to Tye300 For This Useful Post:
Old 05-01-2014, 12:53 PM   #1288
FyeaFRS
Drives: 1992 Nissan Skyline GTS-t Type-M
I installed the Mishimoto when I put in my Vortech, wasn't very difficult. Now clamping all the loose hoses on the other hand...
FyeaFRS is offline   Reply With Quote
The Following User Says Thank You to FyeaFRS For This Useful Post:
SirBrass (05-01-2014)
Vortech Supercharger denverizzles Forced Induction 176 10-19-2013 06:48 PM
New Vortech Supercharging System Information... Brian@Vortech Forced Induction 306 11-08-2012 05:49 PM
Supercharging the GT86 Billy2224 Engine, Exhaust, Transmission 13 06-05-2012 03:58 PM
Turbo/Supercharging Your FRS BoostJunkie Engine, Exhaust, Transmission 123 05-18-2012 06:26 PM
Supercharging: the forgotten form of FI madfast Engine, Exhaust, Transmission 76 03-02-2012 05:06 PM
