#785 | |
Drives: Firestorm FR-S
Check out my YouTube channel with Autocross videos: http://www.youtube.com/user/MrAreddi
#786 |
Conedancer
Drives: 2013 Subaru BRZ SWP
.. mine is the 2.5 in.. my team-mate is running the 3in.. not sure there's any real benefit to running that diameter unless your boosted.. Bill
Join my BRZ/FRS FB Group ![]() Thanks to:Kartboy/Wheeldude/Nameless Performance /Gaurd Transmission LSD |
#787 | |
It's the gasket that's 2.5", not the collector ( unless it's some type of one-off deal). All the Nameless outlets are 3" and the option on website is just for gaskets. Shameless plug: If you do decide on the Nameless header, I'm selling one in the Marketplace for cheap. |
#788 | |
Car Nut
Drives: BMW 335d, Toyota Echo RS, FRS
#789 |
Conedancer
^^^^ ahhh I see
#790 |
Drives: 1990 BNR32 GTR
If I am not mistaken, and I am new to this whole AutoX thing, wheels and tires are going to make the biggest immeditate difference on our twins, right?
I'm looking at a set of 17x9's, and I'm pretty sure I'm going with them, since they are 4 lbs per corner lighter than stock, and give me my width. Should I be looking at 'R comp' tires? I realllyyy want a set of Hoosiers to run. I'm planning on a few AutoX days and then some Portland International Track days too.
#791 |
Dodging cones
Drives: 2013 BRZ Limited, 93 Z28
Hooisers will put you in CSP with some FAST Miatas. If you're inexperienced with autocross, skip the R Comps and go street tires to learn. R Comps are awful to learn on, hide mistakes too well.
#792 | |
You can learn how things work, try things out, and then move up to STX with more mods at a later time if you choose. You have to use stock size wheels in Street though, so those 17x9s will put you in ST.
#793 |
Car Nut
This was kinda my experience as well, I ran R comps on a previous car and found I wasn't good enough to take advantage of them and they were also REALLY expensive, I am far happier running in a street tire class for less money and work, and working on my driving skill instead.
| The Following User Says Thank You to BRZZZZZZZZZZ For This Useful Post: | Kido1986 (04-29-2014) |
#794 | |
9" rims are the limit on STX, as are 140 treadwear tires, right? The STX limit is 255's, though I'd run 245s. Oh, I think I just realized that the Hoosiers are acutally 40 treadwear, huh? So..... The new RS-3's are UTQG 200 (Which is the requirement for next year?) Now I'm lost again.
#795 | |
Undisputed El Presidente
Drives: Zenki 37J ZN6
#796 |
Is that what most guys are running then? RS3s?
#797 |
thats what I have gathered, but nobody really knows what the new ones are like. The ZII is the other top choice. There is at least one big name on here that runs Federal 595RSR
And to clarify I am assuming the new ZII will be 200 UTQG, and just heard on here something about November. Also I am in no way as serious about autox as many on here but these are my observations. I personally am only on Potenza S-04 on stock wheels with springs. Lol |
#798 |
Roger that. I have plenty of questions on suspension too. I'll hold off until the tire thing gets chimed in on.
| Thoughts on a "component" setup with a 3.5" dash and 6.5" door setup? | PatrickSAN | Electronics | Audio | NAV | Infotainment | 22 | 11-14-2012 02:12 PM |
| SCCA sway bar rules | gmookher | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 0 | 09-01-2012 06:48 PM |
| Suggestion for vendor rules... | Tainen | Site Announcements / Questions / Issues | 31 | 08-15-2012 01:53 PM |
| Rules for posting in this section | Hachiroku | User/Vendor/Sponsor Reviews, Feedback, Comments | 0 | 06-25-2012 11:02 AM |
