Old 04-23-2014, 02:15 PM   #15
ToyoburuBRZ
ToyoburuBRZ's Avatar
Drives: Black BRZ
Originally Posted by Acree View Post
No problem man. Glad it was a simple fix.
As am I!
ToyoburuBRZ is offline   Reply With Quote
Old 04-30-2014, 04:57 PM   #16
1010110
Drives: 2013 Scion FR-S Manual in Whiteout
Did you ever resolve the LED side marker light flickering problem?
1010110 is offline   Reply With Quote
Old 04-30-2014, 05:49 PM   #17
ToyoburuBRZ
Drives: Black BRZ
They were cheap LEDs that came with the side markers. I just replaced them
The Following User Says Thank You to ToyoburuBRZ For This Useful Post:
1010110 (04-30-2014)
Old 04-30-2014, 11:48 PM   #18
Bg8780
Bg8780's Avatar
Drives: '13 Black Subaru BRZ Limited
I had the same issue. I think it's fuse 10 by the steering column. Glad you got it fixed. Those helix markers are pretty shitty. I gave up on them and went back to stock
Sent from my LG-V500 using Tapatalk
Bg8780 is offline   Reply With Quote
The Following User Says Thank You to Bg8780 For This Useful Post:
BAOVAN (01-13-2017)
Old 05-01-2014, 04:20 PM   #19
KI_ZN6
KI_ZN6's Avatar
Talking
We have OEM Japan Clear Side Markers available given that some aftermarket side markers have seal issues (causing moisture buildup, condensation, water leaks, etc.). The OEM Japan side marker lens are a great alternative to aftermarket lens/light housings in terms of quality, especially in the long run and will stand the test of time.
KI_ZN6 is offline   Reply With Quote
Old 10-20-2014, 11:04 PM   #20
KelvinBRZ
GBS Mafia Member
KelvinBRZ's Avatar
Drives: with Snow mode on
Originally Posted by ToyoburuBRZ View Post
@Acree, that was it! 10amp tail light fuse was blown so I replaced it with a spare and got all lights back.
I can't believe all those lights run on the same circuit.
Thanks for your help!
My tail fuse was blown an hour ago. I heard from @Camop82 that there is an extra fuse somewhere, could someone confirm? Much appreciated...
GBS Mafia
KelvinBRZ is offline   Reply With Quote
Old 10-20-2014, 11:05 PM   #21
KI_ZN6
KI_ZN6's Avatar
There is a fuse box in the engine bay. You may refer to your owner's manual and you will find that there are a number of spare fuses that you can use (different ratings). Good luck!
The Following 2 Users Say Thank You to KI_ZN6 For This Useful Post:
BAOVAN (01-13-2017), KelvinBRZ (10-21-2014)
Old 02-20-2015, 09:54 PM   #22
Driftz
Drives: 2015 Raven FRS
Thanks for this thread I blew my number 4 fuse (tail lights) also when changing to LED side marker lights
Driftz is offline   Reply With Quote
Old 08-10-2018, 11:27 PM   #23
GrantedTaken
How does the fuse blow when changing side markers?
Touching the 2 wires together?
Just wanted to say thanks for this thread.
My side markers were not working.
After reading this thread, I noticed my tail lights were not working!!
I changed the 10a fuse under the dash, and it fixed it.
Tail lights are now also working. Damn.
GrantedTaken is offline   Reply With Quote
oem clear side marker mush Cosmetic Modification (Interior/Exterior/Lighting) 9 01-27-2014 01:53 PM
WTB: orange OEM side marker (passenger side or both) Kayzer Soze Exterior Parts (Aero, Lighting, Etc.) 4 09-05-2013 04:46 AM
WTB: smoked side marker (driver side) vincent201089 Exterior Parts (Aero, Lighting, Etc.) 2 07-29-2013 04:29 AM
Side marker feature mashal Cosmetic Modification (Interior/Exterior/Lighting) 17 07-08-2013 07:27 AM
(FS) TX- Orange Side Marker tts266 Exterior Parts (Aero, Lighting, Etc.) 1 02-16-2013 06:16 PM
