Old 04-29-2014, 04:58 PM   #29
Captain Insano
OP are you doing lighter internals or higher compression ratio? If so any ideas yet what weight and compression ratio?
Captain Insano is offline   Reply With Quote
Old 04-29-2014, 07:27 PM   #30
EN2_Squirrel
EN2_Squirrel's Avatar
sub'd. Also I am looking in a N/A build mostly for scca solo Street Modified stuff. Was curious about cost obviously and whether parts were lightened(not legal in SM) but better balanced? Higher comperssion pistons, larger cams, tougher valvetrain, and usual 200whp bolt-ons running e85 and tune. I figure 250whp seems reasonable. thats my plan anyway after deployment.
EN2_Squirrel is offline   Reply With Quote
Old 04-29-2014, 07:28 PM   #31
supradoopra
Drives: frs
nice. im tuned in for more
supradoopra is offline   Reply With Quote
Old 04-29-2014, 08:44 PM   #32
celek
Resident Gear Head
celek's Avatar
Yes and Yes
A few things to figure our with the combustion chambers with a 3.5mm larger bore.
Weight unknown nothing extremely exotic in material though
celek is offline   Reply With Quote
The Following User Says Thank You to celek For This Useful Post:
Captain Insano (04-29-2014)
Old 04-29-2014, 08:46 PM   #33
Turdinator
Señor Member
Turdinator's Avatar
Are you looking into improving the rod/stroke ratio with longer rods or is it not a concern for you?
1974 TA22 Celica
2013 86 GT
Old 04-30-2014, 02:04 AM   #34
Snake
Drives: ADM Toyota 86 GT
So those sleeves will bore it out to 2.2ltr? 89.5mm x 86mm = approximate 2.2ltr.
Snake is offline   Reply With Quote
Old 04-30-2014, 08:40 AM   #35
ML
ML's Avatar
Drives: 13 White MT FR-S
From Darton Sleeves page
"New Scion FRS / Subaru BRZ / Toyota 86 / Toyota GT86 MID sleeve kit now available. Comes semi-finished for stock bore size of 86mm and has a max bore size of 90mm. Sleeves can easily handle 50+ psi of boost at any bore size."
The Following User Says Thank You to ML For This Useful Post:
CxG (10-25-2015)
Old 04-30-2014, 03:14 PM   #36
brn12345
brn12345's Avatar
For an NA build bigger bore usually brings with it lower detonation threshold. Careful planning needed otherwise power gain with displacement would be lost to knock resistance.
2013 Lightning Red - 6MT
Perrin Inlet Hose ~ TRD Panel Air Filter ~ OEM Modified Snorkel ~ Revolution 4-2-1 EL Header ~ HKS Resonated Front Pipe ~ BRZedit self tune ~ KW Clubsport Coilovers ~ AP Racing Big Brake 4 Piston ~ Whiteline Front Endlinks ~ Perrin Rear Endlinks ~ WedsSport TC105N 17x8 42+ ~Dunlop Direzza II Star Spec 225/45/17 ~ STI Trunk Lid Spoiler
brn12345 is offline   Reply With Quote
Old 04-30-2014, 05:04 PM   #37
ZeHeadBanger
Stuck like Glue
ZeHeadBanger's Avatar
Drives: WRB BRZ Limited
This is definitely going to be super interesting. I'm personally a fan of NA motors and hopefully this thread should be a good learning experience for me!
Subscribed!
ZeHeadBanger is offline   Reply With Quote
Old 04-30-2014, 08:26 PM   #38
Snake
With the increased bore, HKS's stroker kit might come in handy to bring it to 90mm x 90mm and 2.3ltr. Would certainly give it some more torque!
Old 04-30-2014, 10:05 PM   #39
celek
Resident Gear Head
celek's Avatar
There is a small problem with a 90 mm bore.
This problem is that there is not gasket manufacture that makes a gasket larger than 89.5mm.
As for stroke I have something special planned for the crank. I will know once it is looked over. and it will be cheaper than HKS
Old 04-30-2014, 10:07 PM   #40
celek
Resident Gear Head
celek's Avatar
If I stayed with the stock stroke I could get the rod ratio somewhere around 1.58:1 instead of stock at 1.50
Turdinator (05-01-2014)
Old 05-01-2014, 09:47 AM   #41
w00t692
Drives: 2008 Civic Si
It would be absolutely pointless for him to do an n/a build with heavier than stock components. rods and pistons are probably going to be 100-200 grams lighter than stock each. He'll have amazingly better rev limits and carry power better.
w00t692 is offline   Reply With Quote
The Following User Says Thank You to w00t692 For This Useful Post:
celek (05-01-2014)
Old 05-01-2014, 01:04 PM   #42
stevo585
Drives: White 2014 BRZ
Think about motorcycle engines (not harleys). They all are big bore, short stroke with individual throttle bodies. This allows for more airflow, bigger valves, and high rpms. This is what you need to make big NA power.
stevo585 is offline   Reply With Quote
2.3ltr, all motor, helpful, hks, hks stroker, informative, na brz
Beginner STX Build Whiteout FRS Build Thread Hachi86Roku Tracking / Autocross / HPDE / Drifting 21 03-31-2020 07:52 PM
Ultimate coilover thread, What do you run on your car? got REVIEWS post it up! THMotorsports.com Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 12-11-2013 05:25 PM
The *ULTIMATE* Exhaust Thread by ECS Motorsports! | Over 2 Dozen Options! + FREE S&H! AJ@ECSMotorsports Engine, Exhaust, Bolt-Ons 27 09-05-2013 09:14 AM
*--->>ULTIMATE COILOVER THREAD<<---* The Best Deals + Free Shipping FT-86 SpeedFactory Brakes, Suspension, Chassis 95 01-30-2013 07:48 PM
Who's in for the long haul? Laika BRZ First-Gen (2012+) — General Topics 47 07-09-2012 09:48 AM
