go_a_way1
Old 04-29-2014, 02:37 PM   #967
CSG David
CSG David's Avatar
Originally Posted by smbstyle View Post
Has anyone else had issues with boiling RBF600?
I ran two days at Sebring this past weekend; fresh RBF600 fluid, Cobalt XR1 fronts / XR2 rears, NT-01s, TF Brake Cooling kit with titanium shims, and 95*f ambient temps with a passenger the entire time.
In the afternoon I was pushing hard, and noticed each lap, the pedal travel was getting a little bit longer and longer, then backing off for a few laps, I still had a long pedal. Came in, bled the fronts, went back out and it was good for a few laps, then when again when I started pushing really hard, pedal travel was getting longer and longer after each hard lap. (wasn't pad knock-back; I was priming the brake pedal after each corner on the straight away thinking thats what it was, as I usually get knock-back after I get on the exit curbing).
I'm thinking it's not so much the RBF600, as I've never boiled the fluid before, but that was my first time running the Cobalt XR1 (usually run XR2 front), which is their most aggressive pad, and I've also increased my front brake bias by running a XR2 pad in the rear, which is putting more heat into the front brakes. That, plus the high ambient temps and an extra 200lb passenger the entire time probably contributed to it.
I think next time I'll just go back to the XR2 fronts and go to a better fluid like the RBF660 or Castrol SRF.
We boil or notice significant pedal changes from RBF600 in 2-3 sessions, SuperATE in 1-2 sessions, RBF660 in about 1-2 days, and PMU G-Four in 4 days. We are currently running RT700 with no degradation in pedal feel. Unfortunately, RT700 is on backorder right now and I believe we only have 1 bottle left with epic security lockdown on that unit.
The Following User Says Thank You to CSG David For This Useful Post:
retrosmiths (04-29-2014)
Old 04-29-2014, 02:39 PM   #968
retrosmiths
Drives: Scion FR-S Whiteout
@CSG_Mike, which track brake pads produce the lowest noise when used on streets/cold?
2013 Scion FR-S
retrosmiths is offline   Reply With Quote
Old 04-29-2014, 03:00 PM   #969
smbstyle
smbstyle's Avatar
Drives: 2013 SWP BRZ
Wow, alright, i'll have to try that then (if i can find it)
2013 SWP BRZ
Build Thread: http://www.ft86club.com/forums/showthread.php?t=38781
smbstyle is offline   Reply With Quote
Old 04-29-2014, 03:07 PM   #970
CSG David
CSG David's Avatar
Our ETA for RT700 is next week or week after...we've been waiting for 2 months now
Old 04-29-2014, 03:16 PM   #971
smbstyle
smbstyle's Avatar
wow that is nuts!
2013 SWP BRZ
Old 04-29-2014, 04:49 PM   #972
CSG Mike
CSG Mike's Avatar
You're putting more heat into the fronts than you're used to, and you're also probably getting faster (on top of the passenger weight).
Try Project Mu G-Four. It's specs are higher than RBF660, cheaper by unit volume, and is green when it's fresh, and turns an ugly brown as it degrades (same as degrade RBF600), so you can easily check the fluid's status without having to "test it on track".
Unless we get RT700 in.
smbstyle (04-29-2014), solidONE (04-29-2014)
Old 04-29-2014, 04:52 PM   #973
CSG Mike
CSG Mike's Avatar
No underscore!
Project Mu NS400, Bforce
Carbotech 1521
Winmax W1, W2
Autozone duralast...
Old 04-29-2014, 04:52 PM   #974
CSG Mike
CSG Mike's Avatar
I've refused some offers of big $$ for my personal stock of RT700...
SHOO. GET AWAY.
Old 04-29-2014, 04:59 PM   #975
retrosmiths
Brown? I thought I read in other website description that it turns clear when boiled?
Sent from my phone. Might have typos. Sorry.
2013 Scion FR-S
Old 04-29-2014, 05:06 PM   #976
retrosmiths
No underscore!
Carbotech 1521
Winmax W1, W2
Wait.."track" pads?
2013 Scion FR-S
Old 04-29-2014, 05:08 PM   #977
CSG Mike
CSG Mike's Avatar
Wait.."track" pads?
Street pads :p
Old 04-29-2014, 05:14 PM   #978
retrosmiths
LOL something better or equal to HC+800 with less squeal.
2013 Scion FR-S
Old 04-29-2014, 05:15 PM   #979
Thongpocket
Master Troll
Thongpocket's Avatar
Drives: 2013 BRZ Limited
Sorry if someone asked this but what do you guys run as far as camber and toe for track days usually?
Sent from my XT1080 using Tapatalk
Thongpocket is offline   Reply With Quote
Old 04-29-2014, 05:20 PM   #980
CSG Mike
CSG Mike's Avatar
-3 to -4 front camber
-2 to -3 rear camber
0 toe
That ballpark fits most "track" BRZ/FRS. If you're street driving as well, you'll probably need to compromise on something unless you care more about performance than tire life. (We're talking maybe a 30% decrease in life at most)
Chazzzy (09-14-2016), Thongpocket (04-29-2014)
Simple question, hard to find answer... Mango22 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 05-16-2013 07:23 PM
Silly question about protecting track rims sw20kosh Tracking / Autocross / HPDE / Drifting 16 04-25-2013 01:34 PM
Asking the question that I already know the answer to. Are the engines the same? Bigmaxy Engine, Exhaust, Transmission 10 01-19-2013 08:47 PM
Random dog-related question for those who have their BRZ GMU-BRZ BRZ First-Gen (2012+) — General Topics 11 05-31-2012 08:48 AM
Got my answer - BRZ comes with HID headlights as STD Z_Rocks BRZ First-Gen (2012+) — General Topics 20 01-10-2012 10:54 AM
