Old 04-28-2014, 12:56 PM   #6847
dkrou351
dkrou351's Avatar
Drives: Scion FR-S
Took her to Fresh Meet in NJ on Sunday. Met some cool people and got a lot of good mod ideas. Talked to a guy from Boston at the scion racing booth with a really nice CF hood. Apparently it's still being developed but its called the Black Ops hood. Anyone heard of it?
Merica.
dkrou351 is offline   Reply With Quote
Old 04-28-2014, 01:07 PM   #6848
FLIPs_FR-S
KCCO
FLIPs_FR-S's Avatar
Drives: 2013 Raven Scion FR-S, AT
Got a 4 wheel alignment yesterday. I hit a nasty pothole Friday afternoon. She was pulling a little bit to the right. Name:  uploadfromtaptalk1398704862835.jpg
Sent from my SAMSUNG-SGH-I527 using Tapatalk
Alabama state head for Southeast 86
https://www.facebook.com/groups/Southeast86/
FLIPs_FR-S is offline   Reply With Quote
Old 04-28-2014, 02:10 PM   #6849
tennisfreak
Drives: 2018 BMW M240i
Dat ass, so sexy!
Old 04-28-2014, 06:10 PM   #6850
nograde
Drives: Scion FRS
second that.^^^^^^ that trunk and exhaust are awesome. I'm still debating between that trunk or an APR wing (more functionality for the track).
nograde is offline   Reply With Quote
Old 04-28-2014, 08:01 PM   #6851
Young_makaveli
Young_makaveli's Avatar
Drives: 2013 frs
I'm trying to help a friend out ..he's trunk is not opening and the bypass switch is not the issue .. I was wondering if there was a fuse and if so ... where is it located and the name ..
Thanks
Sent from my SM-N900W8 using Tapatalk
Young_makaveli is offline   Reply With Quote
Old 04-28-2014, 08:07 PM   #6852
RFB
RFB's Avatar
Drives: FRS
Installed O.F.T. - WOW !
Best mod to date, turns it into a totally different car, reduced torque dip as expected, but the quickness to high revs and accceleration increase was very impressive.
Also smoother idle , more exhaust burble , cleaner exhaust sound.
Best bang for the buck mod available IMHO.
CERBERUS
RFB is offline   Reply With Quote
Old 04-28-2014, 11:49 PM   #6853
Autocon
Autocon's Avatar
Drives: 2014 Whiteout FRS
Plasti Dipped my rims red because racecar. Had to take a cool little photo before I headed back to LA.
Autocon is offline   Reply With Quote
Old 04-28-2014, 11:58 PM   #6854
AARON691983
Drives: Whiteout Scion FR-S/BRZ/GT86/FT86
Thanks
I've had this problem when I received my car from the dealer. Before removing fuses check inside the trunk for an on/off switch (I believe its on the left side) put the switch in the on position and the trunk actuator should work now. If thats not the problem the you can check the fuses.
AARON691983 is offline   Reply With Quote
Old 04-28-2014, 11:59 PM   #6855
poison1916
Drives: Scion FR-S Hot Lava
Found a well lit parking lot that is completely empty and I drifted around the light posts for a good 30 minutes
Sent from my HTC6525LVW using Tapatalk
poison1916 is offline   Reply With Quote
Old 04-29-2014, 01:59 AM   #6856
Chad86
DrivinginDreams...Cloud86
Chad86's Avatar
Drives: Toyota GT86
Talking
CERBERUS
I'm interested in doing the same. What tune are you running? (Stage 1, etc.?) How easy was it to set up? What octane gas are you using?
Chad86 is offline   Reply With Quote
Old 04-29-2014, 04:30 AM   #6857
Evil Jesus
Evil Jesus's Avatar
Drives: '13 FR-S Raven 6MT
http://www.toyotaterritory.com/Scrip...idproduct=1739
Is this really the cheapest I can get these?
Evil Jesus is offline   Reply With Quote
Old 04-29-2014, 04:50 AM   #6858
RFB
RFB's Avatar
Drives: FRS
I have TRD intake and Magnaflow catbacks using 91 octane which calls for stage one map .
As soon as my headers arrive, I'll use stage two map.
About 15 minutes to set up - super easy.
Check with Vishnu web site support as to any d/l updates required before use.
1 - Connect O.F.T. to car, read and store original stock map (To flash back for smog cops or dealer warranty repair).
2 - Connect O.F.T. to internet connection , d/l both maps (or more if planning supercharger etc.).
3 - Connect O.F.T. to car, install new map.
4 - Enjoy a brand new, faster and smoother engine, and exhaust !
Ignore the instant erection - KEEP YOUR HANDS ON THE WHEEL !
The provided maps are different (for different regions, auto trans vs. manual trans, UEL vs. EL headers etc.). Just d/l and use the ones appropriate for your car set up. When connected to the car, close the doors and make sure NOTHING is on. Follow directions on the screen exactly. After starting car with the new map - do not step on the gas pedal for a few minutes.
For $195 Vishnu will allow you to send them your data logs (up to 7 times I think) for finer tuning of your map for you to d/l. A couple of hot laps at the track or a dyno run is enough for a data log. I wouldn't risk tuning yourself unless you were an expert tuner.
CEREBRUS
Old 04-29-2014, 05:15 AM   #6859
wtrxprs007
wtrxprs007's Avatar
Drives: 2006 Toyota Prado 4.0V6
Can someone tell me what an "O.F.T" is? I'm guessing its some kind of ecu tuning or something like that....
wtrxprs007 is offline   Reply With Quote
Old 04-29-2014, 05:20 AM   #6860
Chimera
Drives: FRS
correct,
head on down to the software tuning section.
