Old 04-25-2014, 12:52 AM   #29
cpnslow
cpnslow's Avatar
Drives: 2013 Subaru BRZ Limited (WRB)
Tire Size Decision - OZ Ultraleggera 18x8.0
I'm about to pull the trigger on this purchase, but the only thing holding me up is the decision on tire size. I'm looking at Michelin Pilot Supersports in 225/40R18, 235/40R18, or 245/35R18. I'd like to avoid any sort of stretched sidewall, but don't want tires so wide that they'll rub on tight corners or adversely affect handling without suspension mods. Any input would be much appreciated!
http://www.tirerack.com/wheels/Wheel...ll&sort=PriceR
My Build Thread: Nick's BRZ - "CPN SLOW"
My Car Photography: www.ngphotog.com
cpnslow is offline   Reply With Quote
Old 04-25-2014, 05:48 AM   #30
Panman
Panman's Avatar
Drives: 86 GTS
I've got exactly these wheels and am running 225/40/R18 Federal 595-RSR with no stretch (or bulge). Perfect fit from my perspective.
Car does not feel over-tyred, or under-tyred.
Panman is offline   Reply With Quote
Old 04-25-2014, 11:15 AM   #31
cpnslow
cpnslow's Avatar
Great! Would you mind posting a photo or two?
Old 04-26-2014, 02:47 AM   #32
Panman
Panman's Avatar
Drives: 86 GTS
Yep, should be able to get a couple tomorrow
Old 04-26-2014, 03:11 AM   #33
Brzzee
Brzzee's Avatar
Drives: 2015 Subaru BRZ WRBP Limited 6MT.
I'm running Michelin pilot SS in 245/35zr18. Great tire, light weight and works well on smooth tracks. The 35 series with stock suspension makes for a hard ride on the streets in north Texas.
Brzzee is offline   Reply With Quote
Old 04-29-2014, 04:13 AM   #34
cpnslow
cpnslow's Avatar
You probably forgot, but can you post a photo when you get a chance? Thanks!
Old 04-29-2014, 04:17 AM   #35
cpnslow
cpnslow's Avatar
Thanks! Hard decision here. Sounds like both combinations work well.
Old 04-29-2014, 08:42 PM   #36
cpnslow
cpnslow's Avatar
Well... I did it! I ultimately settled on the wider 245/35R18 (like duder's car). Should be delivered in a day or two and on my car by this weekend. I'll post photos.
Old 04-30-2014, 04:29 PM   #37
Yamajee
Yamajee's Avatar
Drives: Rocket Bunny'd GT86
Had the same OZ's, +48mm, square setup, 225/40 michelin pilots, perfect!
Yamajee is offline   Reply With Quote
Old 04-30-2014, 04:32 PM   #38
dem00n
Member of the year - 2016
dem00n's Avatar
Drives: Scion FRS
8 wide?
225, learn from your mistakes, don't hide them.
Old 04-30-2014, 05:23 PM   #39
olorin
olorin's Avatar
Drives: GBS Premium
My understanding is that 225 PSS run wide anyways so they would be the best bet on 8". I am going to put PSS 225/18R40 on my 18x8.5 SSR GT F01 wheels when they arrive tomorrow.
olorin is offline   Reply With Quote
The Following User Says Thank You to olorin For This Useful Post:
SirBrass (04-30-2014)
Old 05-05-2014, 11:16 PM   #40
cpnslow
cpnslow's Avatar
OZ Ultraleggera 18x8 (Black)
Just got my wheels installed today! Here's a quick iPhone shot for now, better ones to come tomorrow...
OZ Ultraleggera 18x8 +48 (Black)
Michelin Pilot Super Sport - 245/35R18
UPDATE! Here's some more detailed shots:
The Following User Says Thank You to cpnslow For This Useful Post:
PT-BRZ (05-06-2014)
Old 05-06-2014, 01:24 AM   #41
brz7400
brz7400's Avatar
Drives: Subaru BRZ
Looks sharp!
brz7400 is offline   Reply With Quote
Old 05-06-2014, 01:54 AM   #42
PT-BRZ
PT-BRZ's Avatar
Drives: 2013 BRZ MT
Stock suspension?
PT-BRZ is offline   Reply With Quote
18x8, 245/35r18, michelin, oz ultraleggera, pilot super sport
OZ Ultraleggera 18x8+48 anthracite on Firestorm ultra Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 35 04-20-2014 06:19 AM
Will 18x8.5 +35 Fit all around? wootloops Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 06-06-2013 06:58 AM
XXR 527 18x8.75 +35 DarrenDriven Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 44 08-23-2012 06:56 PM
OZ Ultraleggera w 225/40/18 ultra Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 36 07-06-2012 03:44 PM
