Old 04-11-2014, 05:46 AM   #267
mike the snake
I'm going to get the cord so I can plug my laptop into my ECU. I'll be able to read IAT's then.
Old 04-28-2014, 02:19 PM   #268
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
http://ft86speedfactory.com/rksport-...hood-1496.html
Anybody have experience with this hood?
Old 04-28-2014, 03:58 PM   #269
Dipstik-sportech
Dipstik-sportech's Avatar
That hood will probably hinder more than help air flow. You want air to come out of the engine bay not force more into it.
The Frozen North
Old 04-28-2014, 04:05 PM   #270
SirBrass
Trust me, I'm the Doctor
SirBrass's Avatar
The Frozen North
Think of the engine bay the way your would the inside of a computer case: you have venting fans to push air out, but the real work horses are your blower fans which push cooler air IN, thus creating a cool air stream across hot components and moving fresh air into the interior space. The venting fans just help keep the air moving out.
Same here, and the principle is the same, but using the vehicle's velocity as the "fan": evacuate the hot interior air and replace it constantly with cooler outside air.
^GT5 Replay Photo Mode^
Old 04-28-2014, 04:12 PM   #271
Dipstik-sportech
Yes but that air has to then escape the bay. That hood style just forces more air in and actually might pressurise it enough to actually decrease air flow across the radiator due to pressure equalisation. What you need is a rear facing vent or a slash cut style to create a low pressure area over the hood drawing the hot air out
The Frozen North
Old 04-28-2014, 08:53 PM   #272
Sellout
Mr. Cranky Pants
Sellout's Avatar
Drives: 2013 Argento FR-S
You've already got air coming in, it comes through the radiator in front. You don't need anymore air going in. You need more air going out.
Sellout is offline   Reply With Quote
Old 04-28-2014, 08:55 PM   #273
SirBrass
SirBrass's Avatar
It's already been pointed out that it's still a choke point for airflow.
If you've got air coming in, you've got air going out. The more air coming in, the more air that is going out. Otherwise your engine bay would inflate like a balloon and pop.
Old 04-29-2014, 12:13 AM   #274
Sellout
Mr. Cranky Pants
Sellout's Avatar
That's exactly the point. Maybe I should have worded it better. We have the POTENTIAL for all the airflow we could possibly need coming through the radiator, but we don't get that airflow because there's not enough places for the high pressure air under the hood/behind the radiator to get out. If the hot air can't get out, fresh air can't get in.
Adding places to get air IN doesn't help us. Not even a little bit. Because we need that air going through the radiator on its way into the engine bay.
Old 04-29-2014, 01:05 AM   #275
SirBrass
SirBrass's Avatar
Airflow will do that anyway. It's the air that is diverted around the radiator which could be used to blow out hot air.
A properly vented hood & an air ram on the aluminum skid plate could do that. Air there wasn't going to the radiator anyway.
On phone I am. Therefore, if mistakes I make, Frank Oz blame you should.
Old 04-29-2014, 01:20 AM   #276
steve99
Drives: FT86
you need a pressure differential for air to flow. A forward facing hood scoop or "ram air" skid plate, will most likely increase the air pressure in the engine bay behind the radiator and hence reduce the flow of air through the radiator. If you look at the stock car its quite carefully designed to make sure that the maximum amount of air flows through the radiator and not around it.
Old 04-29-2014, 01:26 AM   #277
steve99
Drives: FT86
The Frozen North
correct, ensuring is actually a a low pressure area would be the key.
Old 04-29-2014, 03:26 AM   #278
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
I still think actually making the side vents functional is the cheapest and best way to release the trapped hot air in the engine bay.
Old 04-29-2014, 06:24 AM   #279
mike the snake
Our intercoolers cover almost the entire front grill, which I think might also restrict a lot of the air that normally would flow through the radiator.
Tomorrow, I am planning on cutting on my metal skidplate to enlarge the engine bay exhaust opening size, and adding my rubber "trip strips", which I hope will help pull extra air from the engine bay.
I want to retain some of the protection of the skidplate, otherwise I'd just remove the skidplate altogether.
This, coupled with the holes I've cut into the front bumper, I'm hoping will increase the air exchange.
I plan to do some "smoke bomb testing" after that.
Old 04-29-2014, 01:09 PM   #280
sidetrak06
Drives: 2013 Subaru BRZ - 6MT Ltd
Thermal Imaging Camera
Does anyone have access to a thermal imaging camera? We can stop the speculating about where the heat is going and actually see it!
http://www.flir.com/thermography/ame...=830&col=61190
These things sell for $1,500 and are extremely useful for visualizing heat transfer and fluid dynamics. It seems to me that vendors such as Full Blown could greatly benefit from this relatively small investment and put some extremely powerful R&D to work to come up with innovative solutions to these heat issues. Simply modifications such as removing cowls and modifying skid plates could be visualized on a dyno run in minutes.
sidetrak06 is offline   Reply With Quote
any serious benefit Heat Tapes? Djen Engine, Exhaust, Transmission 22 02-18-2014 03:20 PM
Heat bad for your car? Ways to cool it? BushMan Scion FR-S / Toyota 86 GT86 General Forum 35 08-01-2013 10:15 PM
Misfire with heat? bigjake Issues | Warranty | Recalls / TSB 2 04-28-2013 09:02 PM
Do I Need a Heat Shield? arleewa Engine, Exhaust, Transmission 1 01-08-2013 06:37 AM
Overpipe Heat question Amadeus Engine, Exhaust, Transmission 5 12-19-2012 01:18 AM
