Old 04-28-2014, 10:55 AM   #57
kcam86
Drives: Asphalt FR-S MT
My question is how much difference do turbo blankets, ceramic thermal coating and thermal wraps make? Ty in advance
kcam86 is offline   Reply With Quote
Old 04-28-2014, 12:28 PM   #58
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
If Reliability is the largest concern, superchargers win hands down. There are less parts that can fail.
Can you explain to me how an oil cooled Rotrex supercharger with a heat exchanger and intercooler along with added pulleys and belt complexity has less parts that can fail?
Old 04-28-2014, 12:33 PM   #59
King Tut
NASA SpecE30 Racer
King Tut's Avatar
That's exactly what I'm saying. Then you got manifolds to deal with, additional heat from all the extra piping that has to hold exhaust gas that's radiating heat, additional oil heat that needs to be cooled off, the turbine itself radiating heat, etc.
Since when do superchargers not have exhaust manifolds/headers as well. In fact many of them add additional pipe in a similar area to most turbo kits. Regardless of the forced induction kit, heat has to be dealt with.
Old 04-28-2014, 12:33 PM   #60
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Am I destroying aerodynamics of the car when going high MPH?
Yes.
Sportsguy83 (04-28-2014)
Old 04-28-2014, 12:35 PM   #61
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Why do so many people not understand the concept of radiant heat vs heat soak?
I'm saying turbos have to deal with BOTH, whereas superchargers do not.
When you're cooking on your stove, and you can "feel" the heat when you get close, that is radiant heat. When you keep your hand in that spot where you feel the radiant heat, and it starts to burn, that's heat soak.
If you reduce the number of items (and thus, surface area) of the sources of radiant heat, you reduce heat soak.
SC: header
Turbo: turbo manifold/header, turbo, exhaust/dump piping, turbo itself.
The supercharger is compressing air and is being oil cooled no different than a turbo, it is just being spun by a belt instead of the exhaust gasses. It has to be factored into the heat equation.
Old 04-28-2014, 12:38 PM   #62
King Tut
NASA SpecE30 Racer
King Tut's Avatar
That's the worst suggestion I've seen in this thread by a LARGE margin...
An actual track car running the Full Blown kit made that recommendation as it eliminated their overheating issues at the track.
Old 04-28-2014, 12:51 PM   #63
SirBrass
Trust me, I'm the Doctor
SirBrass's Avatar
Originally Posted by HRTROB View Post
Sorry to burst your bubble, but I highly doubt you will get 200whp on a Mustang dyno with headers, over pipe, front pipe, exhaust and tune on 91
Then you're wrong. It's already been done (not on my car, but another 86 with similar exhaust mods). I may not make 200 exactly on a Mustang, but it will most likely be 190-200.
So, no bubble to burst. The 200whp wall on pump gas & NA has already been breached.
On phone I am. Therefore, if mistakes I make, Frank Oz blame you should.
^GT5 Replay Photo Mode^
Old 04-28-2014, 01:47 PM   #64
RehabJeff86
RehabJeff86's Avatar
Drives: 2013 WhiteOut FR-S
Originally Posted by swift996 View Post
@RehabJeff86 I'm sure there is some heat soak towards the end of the session. I'm fortunate, there is E85 on the way so I fill to the max and bring a spare 5 gallon jug or two and I'm good for the day. I only run E85 about 10% of the time on the street but it's benefits make sense for the track.
I have a lightweight tow hitch so I can put a small tire trailer on my car and tow. When I went to VIR, I just used a UHaul sport trailer and borrowed a bunch of jugs and filled with E85. A little bit of a hassle but it works for me.
Ya totally agreed E85 makes sense for tracking, i hv done calculation given E85 also burn 15-20% faster than 100 Octane, i will need total of 30 gallons per track day for me..... I hv a rear diffuser not able to add tow hitch....
Sent from my iPhone using TapatalkfQ
2013 Scion FR-S whiteout
2012 Porsche Panamera S carbon grey
2008 Range Rover Sport SS black - sold
2004 BMW M3 alpine wies - sold
RehabJeff86 is offline   Reply With Quote
The Following User Says Thank You to RehabJeff86 For This Useful Post:
CSG Mike (04-28-2014)
Old 04-28-2014, 02:08 PM   #65
HRTROB
HRTROB's Avatar
Drives: Toyota 86
You keep saying it's been done, but you aren't providing any proof. I'd like to see these magical 200whp, NA, 91 pump Mustang unicorn dyno graphs you are talking about.
HRTROB is offline   Reply With Quote
The Following 2 Users Say Thank You to HRTROB For This Useful Post:
Tye300 (04-28-2014), WatchmaN (05-25-2014)
Old 04-28-2014, 02:32 PM   #66
victorb
Drives: Black 86
On a dynojet I believe someone did 200whp. I have yet to see someone do 200whp on a mustang dyno.
Sorry to burst your bubble as well!
Running SC or turbo doesn't matter. Just keep an eye on your water temperAture and oil temperatures. I think for water, do not exceed 110'c and for oil temp 130'c (track levels). Please correct me if I am wrong.
victorb is offline   Reply With Quote
Old 04-28-2014, 02:34 PM   #67
Tye300
Tye300's Avatar
Drives: Toyota 86 TRD Version AT
Dyno numbers are subjective anyway. Showing the baseline is more important before breaching the 200whp mark. When I was NA, I baselined 135whp on a dynojet. After tune, with headers and exhaust, I was around the 160whp mark. Imagine if I baselined 135 and hit 200whp with exhaust mods on pump gas, now that's a unicorn in the flesh right there!
Tye300 is offline   Reply With Quote
The Following User Says Thank You to Tye300 For This Useful Post:
glamcem (04-28-2014)
Old 04-28-2014, 02:37 PM   #68
swift996
swift996's Avatar
OT - but some data on oil temps:
http://www.ft86club.com/forums/showthread.php?t=44873
2010 Cadillac CTS-V Sedan M6 w/550whp (Build Thread)
swift996 is offline   Reply With Quote
Old 04-28-2014, 02:41 PM   #69
kcam86
Take it for what it is but I saw a post somewhere with the wiper plastic being removed and it caused a negative pressure pocket right at the windshield that forced are into the engine bay. Not saying this good or bad but maybe you guys can relate on the pros and cons of it. Since both of you are pretty knowledgeable in many regards to this car. ty
Old 04-28-2014, 02:56 PM   #70
SirBrass
SirBrass's Avatar
It's called a search feature.
Edit (now that I'm on a desktop instead of on Tapatalk's limited platform): I apologize for the above. I finally found the chart, but it took a) knowing it definitely existed, and b) searching for the "thanked" posts of the tuner (b/c "posts by user" maxed out before the posting date of this post). So, it would have been incredibly difficult to find. It was effectively buried in the forum.
The 200 whp on E85 you're referring to was done by Shiv on a dynojet (iirc. may have been a mustang), and it was 207 rwhp. Here is the post with 200 whp on a mustang dyno on 91 octane pump gas in AZ.
http://www.ft86club.com/forums/showp...postcount=1549
The Following User Says Thank You to SirBrass For This Useful Post:
going forced induction ft86me Forced Induction 14 02-05-2014 09:23 AM
So who is running Forced Induction and tracking their car? track_warrior Tracking / Autocross / HPDE / Drifting 88 08-20-2013 11:00 PM
Forced induction for ATs? Lokutus Forced Induction 10 02-26-2013 04:42 PM
NOS or Forced Induction? v3rgil AFRICA 1 11-08-2012 08:17 AM
Forced Induction Primo86 Engine, Exhaust, Transmission 11 05-29-2012 08:50 PM
