#197 | |
poverty cause racecar
Drives: Subaru BRZ JRSC'd
#198 | |
I've driven the BRZ in snow a few times... I would personally never drive it with the aids in an ultra low traction environment (I was on OEM Primacys). |
#199 |
Drives: 2013 FRS Whiteout
Pretty cool, just did it and worked on first try. So this leaves the cars braking bias to what? 70% front?
GTX2867R, moto-tuned , tomei op , motiv fp , Invidia Q300 ti , Rota titan 17x9 +42 , nt555 255/40 , ST coilovers w/cascam , Hotchkis sways
#200 |
Any reason as to why we should use lower friction pads on the rear? Thanks
#201 | ||
Drives: 86
![]() Quote:
#202 |
Thanks, i thought so. I recall driving my frs at the track back in 2012 and not really having so much skill as to notice these things. I asked because I was planning on getting a set of track pads and wanted to hear some suggestions or advise first.
#203 | |
#204 |
What do you recommend, I won't be using for street but I will be using with stock rotors and calipers.
#205 |
#206 | |
Drives: FR-S 10 #103 AT
I routinely make a u-turn on my way to work because of a "right turn only" at the bottom of an off-ramp, and I never slide when I do it. This morning I engaged this at the left I take to go onto the highway and once I hit the highway I stabbed the button thinking it would turn it off and drove almost all the way to work like that. When I made my u-turn, I spun the tires and slung the car around it, which has never happened before. Good thing I didn't need that particular nanny at any point on the way.
“Sex is like Bridge. If you don't have a good partner, you'd better have a good hand.” - Mae West Papa said, "son there's a lot of evil temptations out there. Best to try 'em all so you know which ones to avoid." |
#207 |
I used this for the first time in autox. It makes pad choices more obvious of what does not work. I could not get the pile to trail brake to save my life. Brakes are so front biased on the sprint kit.
But point was you could not really tell before. Now I can't get away running those turd hawks on front and OEM rear. Need to switch back to 1521 and see if its any better.
| The Following User Says Thank You to Dezoris For This Useful Post: | CSG Mike (04-28-2014) |
#208 |
Drives: -'02 PSM WRX, '94 Miata, '13 BRZ
I will never do the pedal dance again, it almost resulted in a very bad weekend for me. I thought I would give it one more try in one of my time trial sessions this weekend. Going off the banking at TWS into turn one, about 130 down to about 60, I braked as deep as I was the session before trailing into the corner and ICE mode kicked in almost putting me off track. Later that session it happened again at a less high speed section of the track. Didn't do it again the next 5 sessions and never had a problem. I see the traction light flash on warm up lap sometimes, it might during the session I never look, but I never notice anything that would effect lap times.
![]() Sponsered by:Chasebays/Corr Performance Tuning/KartBoy/Bad Panda Motorsports/Racer-X Fabrication STX Build thread 14th/67 SCCA Nationals (2014) |
#209 | |
#210 | |
The Stig's German cousin
It's worse if you've got a big front bar.I had more ice mode issues than most - pedal dance or no - until I started braking in a straight line. If I trail brake now, it's maybe 10% of the brakes or I just lift and use the tires to scrub speed. |
| Where to buy "heel/toe" shaped gas pedal? | dookie11 | Scion FR-S / Toyota 86 GT86 General Forum | 56 | 01-22-2019 11:24 AM |
| Which Markets have "GT86" and "Toyota" badges on trunk? | Tanuki | Scion FR-S / Toyota 86 GT86 General Forum | 20 | 02-10-2013 05:23 PM |
| Anyone else try running "square" tires on "staggered" wheels? | hamlet | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 21 | 12-19-2012 12:59 PM |
| Thoughts on a "component" setup with a 3.5" dash and 6.5" door setup? | PatrickSAN | Electronics | Audio | NAV | Infotainment | 22 | 11-14-2012 02:12 PM |
| Dyno testing and "drivetrain loss" | serialk11r | Other Vehicles & General Automotive Discussions | 5 | 11-03-2011 08:55 AM |
