Old 04-25-2014, 08:38 PM   #1261
kiichiro
corolla specs/GTR looks
Drives: ooh oooh pretty tail lights
Originally Posted by Red FRS View Post
Has anyone had problems with the blower leaking fluid from the top part of the drain hose? (Bottom of blower)
I took the blower off to tighten it, and I got it tight. Put the blower back on, and it's still leaking. Any suggestions where else it could be leaking from or how I can stop it from leaking from the hose?
Edit: turns out it's leaking from the supercharger behind the pulley
Send to vortech for fresh seals
SOLD THEM BOTH
Hers: 2007 987S
Mine: 2012 991S
That was fun, thanks Hachi
kiichiro is offline   Reply With Quote
Old 04-25-2014, 08:39 PM   #1262
DJCarbine
Thupercharged
DJCarbine's Avatar
Its not excess spewing from the vent plug? What oil level do you keep the blower at?
2013 FRS
Vortech V3 11psi
Revworks UEL - PLM Overpipe - MOTIV catted frontpipe - Invidia Q300
2019 Series.Grey STI - Stage1+ SF
DJCarbine is offline   Reply With Quote
Old 04-25-2014, 09:55 PM   #1263
DJCarbine
Thupercharged
DJCarbine's Avatar
Thanks for the response guys.
The oil is in the cross hairs. I put the full 4oz bottle in after draining it.
Also, not sure if anyone have had this issue. But I just started having a rough idle and the CEL and skid light have come on. I saw some threads of NA guys having this happen too but no one with the vortech kit.
What DTC do you get if you scan it?
2013 FRS
Vortech V3 11psi
Old 04-25-2014, 10:11 PM   #1264
DJCarbine
Thupercharged
DJCarbine's Avatar
My gauge is showing 219a and 0017 when I turn the car on but I don't have anything to scan it
That sounds like the issue people were having with the cam system
http://www.ft86club.com/forums/showthread.php?p=937176
2013 FRS
Vortech V3 11psi
Old 04-28-2014, 09:13 AM   #1265
sissupr
sissupr's Avatar
Drives: 2014 BRZ Premium - SWP
Can anyone post pics of their oil cooler setup. anyone running Mishimoto? Want to make sure there's mounting issues... any other recommendations?
Sent from my SCH-I605 using Tapatalk
Vortech SC V3 // 3.12 Pulley // Moto-East Tune (93oct,e40-50,e85)
sissupr is offline   Reply With Quote
Old 04-28-2014, 09:16 AM   #1266
marcoaferrer
marcoaferrer's Avatar
Drives: Whiteout FR-S
There are mounting issue. Check ft86speed factory's build thread you'll see what I'm talking about there
marcoaferrer is offline   Reply With Quote
Old 04-30-2014, 10:16 AM   #1267
FyeaFRS
Drives: 1992 Nissan Skyline GTS-t Type-M
I'm running the Perrin, it was a bit of a bitch with the pipe there and the hoses..
FyeaFRS is offline   Reply With Quote
Old 04-30-2014, 01:41 PM   #1268
Tye300
Tye300's Avatar
Drives: Toyota 86 TRD Version AT
I'm using the Mishimoto oil cooler. I wasn't able to use the bracket because of the intercooler. I just screwed it to the floor at the front. The oil lines clear the airbox up top with the new sandwich plate.
Here's how I installed it.
http://www.ft86club.com/forums/showp...&postcount=276
Tye300 is offline   Reply With Quote
Old 04-30-2014, 07:27 PM   #1269
Dezoris
Dezoris's Avatar
Are your lines touching the vortech airbox bracket by the sandwich plate?
Old 04-30-2014, 07:37 PM   #1270
FyeaFRS
I modified the bracket via a dremel
Old 04-30-2014, 07:43 PM   #1271
sissupr
sissupr's Avatar
So what everyone is telling me is there is no plug n play kit that works with the vortech SC
Old 04-30-2014, 08:01 PM   #1272
Dezoris
Dezoris's Avatar
Looks like I need to get on that train.
Old 04-30-2014, 08:40 PM   #1273
SirBrass
Trust me, I'm the Doctor
SirBrass's Avatar
I wonder, what about this as an oil cooler solution to use with the Vortech. It'll keep you from having to have yet another air-based heat exchanger:
http://www.ft86club.com/forums/showthread.php?t=42511
^GT5 Replay Photo Mode^
The Following User Says Thank You to SirBrass For This Useful Post:
Tye300 (05-01-2014)
Old 05-01-2014, 05:23 AM   #1274
Tye300
Tye300's Avatar
First time to see this solution. Thanks for this!
The Following User Says Thank You to Tye300 For This Useful Post:
SirBrass (05-01-2014)
Vortech Supercharger denverizzles Forced Induction 176 10-19-2013 06:48 PM
New Vortech Supercharging System Information... Brian@Vortech Forced Induction 306 11-08-2012 05:49 PM
Supercharging the GT86 Billy2224 Engine, Exhaust, Transmission 13 06-05-2012 03:58 PM
Turbo/Supercharging Your FRS BoostJunkie Engine, Exhaust, Transmission 123 05-18-2012 06:26 PM
Supercharging: the forgotten form of FI madfast Engine, Exhaust, Transmission 76 03-02-2012 05:06 PM
