Old 04-26-2014, 03:49 PM   #1345
pixel67
pixel67's Avatar
Drives: 13 Asphalt FRS AT
Anyone happen to have pics of prodrive boost controller install? I had mine installed by a local shop but am not seeing any boost increase via selectable maps. I should be seeing wastegate on map 1, 8 on map 2, 9-10 on map 3, 10-11 on map 4. I am seeing 7 psi regardless of map selection. Harness is wired to prodrive so not sure where there issue is.
Sent from my Nexus 7 using Tapatalk
pixel67 is offline   Reply With Quote
Old 04-27-2014, 02:52 AM   #1346
Justkiz
Drives: WRB BRZ
Did u get a tune for maps? Ebc doesn't work itself, it has to be ecu tuned for each maps.
Justkiz is offline   Reply With Quote
Old 04-27-2014, 02:59 AM   #1347
Justkiz
Drives: WRB BRZ
Any one has got an air intake temp problem with this kit? I had to trim airfilter pipe shorter due to HID headlights (BRZ) and my AIT is a big problem, close to 180f° in traffic.
I'm going to reroute the airfilter to the space where the windscreen washer bottle is located.
Old 04-27-2014, 05:22 AM   #1348
pixel67
pixel67's Avatar
Yes, tune has built ebc. That's the issue. Ecu should be requesting higher boost but not seeing it...
Old 04-27-2014, 05:37 AM   #1349
pixel67
pixel67's Avatar
Is your header and down pipe wrapped or ceramic coated?
Old 04-27-2014, 05:49 AM   #1350
mike the snake
I wrapped my intake tube and sensor with gold heat resistant tape and it really helped drop the IAT's in traffic.
I think putting the gold tape on the top halves of the intake runners would also help keep the heat down on the intake manifold too.
Old 04-27-2014, 09:41 AM   #1351
Ny Brz
Hella Flush
Ny Brz's Avatar
Drives: 2013 SWP BRZ
What radiator and fans you guys running?
Ny Brz is offline   Reply With Quote
Old 04-27-2014, 12:03 PM   #1352
pixel67
pixel67's Avatar
Still running stock
Old 04-27-2014, 12:45 PM   #1353
Ny Brz
Hella Flush
Ny Brz's Avatar
Yeah summer is coming up def want to do the radiator and oil cooler upgrade
Old 04-27-2014, 12:51 PM   #1354
Frs300
Frs300's Avatar
Drives: Pile of junk
Throw the kit in the trash
Frs300 is offline   Reply With Quote
Old 04-27-2014, 12:53 PM   #1355
pixel67
pixel67's Avatar
I had my header and downpipe ceramic coated and will be rewrapping them in a few weeks. Ceramic alone won't do it. I need to get this boost control fixed first though. Did some searching last night and it doesn't look like it is plumbed correctly. The harness is facing towards the front of their car in the video below.
Turbo frs boost controller: [ame]http://youtu.be/AOrQlo1pZ5o[/ame]
Old 04-27-2014, 12:55 PM   #1356
pixel67
pixel67's Avatar
Can't afford it and gotta make the best out of a bad situation.
Old 04-27-2014, 08:07 PM   #1357
Justkiz
Drives: WRB BRZ
My header and down pipe are not ceramic coated but wrapped and my intake charge pipe is wrapped with gold heat reflective tape too. gold tape is definitely helping but not enough.
I got a Koyo rad and Laminova oil cooler from fa20club too and they are working very well.
The Following User Says Thank You to Justkiz For This Useful Post:
Ny Brz (04-27-2014)
Old 04-27-2014, 11:21 PM   #1358
lexusb3
Drives: FRS
Summer is here in Florida it was like 97 today -_- the oil/rad cooler fa20club I did do a few passes on my break to see and temps were at about 215.
lexusb3 is offline   Reply With Quote
0-60 in 22million sec, beam, best of all, doyen done done it again!, fa20club header, fa20club.com, fa20crap, fa20crud.com, frs turbo kit, i like turbos, turbo frs, turbo kit, turbocharged brz, visconti 2.0?, welding4noobs, www.p&lclub.com, you'llneedamuletoride
FA20CLUB TURBO KIT T3/T4 60 86pro Forced Induction 50 07-26-2014 11:48 AM
Fa20club turbo install issues Mikegraves777 Forced Induction 8 07-25-2013 12:56 AM
FA20CLUB 60 Trim Turbo 16 PSI Results Are In FA20Club.com Forced Induction 148 07-22-2013 08:00 PM
FA20CLUB V2 Turbo Kit Progress FA20Club.com Forced Induction 40 05-17-2013 01:26 PM
