Old 04-25-2014, 02:30 PM   #267
regal
Drives: Scion FR-S/Toyota Yaris
Originally Posted by PollosHermanos View Post
Good question - the dealer is doing the service so I assume they'll be putting in whatever it is that subaru specs for Synthetic.
This particular dealer has a program that will give you perks if you use them for maintenance, among them is free tires for life so I am trying to keep that up. They quoted me $77 for the service. Doing it on my own would be about $20 cheaper if I recall correctly.
After some internetting I can't seem to find if there is a standard synthetic oil for Subaru. I'm going to have to ask them unless some knows better?
EDIT: The dealer "thinks" it's valvoline. That's encouraging
This is relabeled Subaru oil meets warranty http://www.autohausaz.com/search/pro...Fenm7AodC2EAlA
2013 FRS Argento Silver 6MT
Mods:
Clear fender side lights
Tactrix ZA1JB01C 2014 Calib
regal is offline   Reply With Quote
Old 04-25-2014, 02:34 PM   #268
PollosHermanos
PollosHermanos's Avatar
Drives: 2014 SWP BRZ Limited 6SP
Awesome thanks. And no surprise it's way cheaper than I've seen anywhere else.
Also not Valvoline ... at all.
1990 Laser RS - Lights go up, lights go down ||1992 MX-6 Coupe - Hah ... no || 2001 Integra GSR - Almost rice. Risotto || 2003 IS300 - A nice car but no fun. || 2011 Stage I GTI - Lots of fun. Would buy another
2014 BRZ - That BRZ. So hot right now.
PollosHermanos is offline   Reply With Quote
Old 04-25-2014, 05:12 PM   #269
R L Newb
Drives: LR BRZ Ltd, 06 STi
they should have bottles of Subaru 0w20 on the shelf and it says idemitsu so not sure where they'd come up with valvoline. If you're paying $77 they should be using the actual Subie oil, the correct oil filter and a new crush washer, double check before giving them your car.
R L Newb is offline   Reply With Quote
Old 04-25-2014, 05:26 PM   #270
PollosHermanos
I plan to mark them so I can see what does and does not get swapped out. The filter should be a no brainer but the plug and crush washer I could see going back on.
Sent from my Nexus 7 using Tapatalk
Old 04-25-2014, 06:37 PM   #271
R L Newb
I meant they'll replace the filter but it could be the wrong one. I guess it's not a big deal you could point it out after but I would go in with the part number and make sure that's what they have in stock and what they'll be putting on.
a few dealers didn't know which filter was for the BRZ at first so they were selling forester filters, i think they're smaller or something. A few even handed out the older blue filters for the wrx.
Old 05-05-2014, 02:47 AM   #272
tbrocato
Drives: 2013 Raven FR-S (MT)
Any reason you're still changing at 5k with the Eneos? Seems like it could handle the 7500 interval without an issue.
Yah I plan on going 7kish this time. I am now running toyota 0w20. This may be the one I stick with. I really like it.
tbrocato is offline   Reply With Quote
Old 05-12-2014, 06:09 PM   #273
travisb
travisb's Avatar
Drives: N/A
Here is my UOA from my first oil change after 1,823 miles. This was a lot of highway miles and one autocross.
travisb is offline   Reply With Quote
The Following User Says Thank You to travisb For This Useful Post:
R L Newb (05-12-2014)
Old 05-12-2014, 08:47 PM   #274
R L Newb
Any particular reason you changed it so early?
Old 05-12-2014, 10:40 PM   #275
Bobblehead
Bobblehead's Avatar
Drives: 2013 BRZ (gone) 2016 Ford Fusion SE
Probably personal preference. After the 1k mile break in a lot of people change their oil. I won't speak for him, but I'm going to guess its a combination of that, his autocross run, and ultimately time.
FWIW, I'm at about 3400 miles and haven't change the oil yet.
Bobblehead is offline   Reply With Quote
Old 05-12-2014, 11:30 PM   #276
R L Newb
Just seems early considering how good the initial fill oil is.
Old 05-13-2014, 07:22 AM   #277
travisb
travisb's Avatar
Drives: N/A
That's why. I'll probably change it again around 5000 and then stick with a 5000 mile cycle going forward.
I'm also a worry wart and a statistics geek, so I really just wanted to know how it was going and get a baseline of data.
Old 05-13-2014, 08:55 AM   #278
bluesubie
Drives: 2004 Subaru Forester 2.5XT
And unless you changed it to Mazda High Moly 0W-20 or a race oil, you won't be getting an oil with as robust in moly as the factory fill
I agree that the factory fill is good stuff and there's no reason to dump it early, especially if you're not changing it to one with a similar additive pack.
Thanks for sharing!
-Dennis
bluesubie is offline   Reply With Quote
The Following User Says Thank You to bluesubie For This Useful Post:
R L Newb (05-13-2014)
Old 05-26-2014, 01:18 PM   #279
whiteradam
Drives: 2000 RS, 2013 BRZ
So here are my results from the third oil change of the car.
Code:
Oil history
Factory oil
Dealer oil
Motul v300 0w20  <-- Oil that this UOA is reporting on.
Motul v300 0w20  <-- Oil in the car now.
There are around 40-50 autocross runs and a track day along with daily driving on this oil.
Name:  13 BRZ-043014.jpg
whiteradam is offline   Reply With Quote
The Following 5 Users Say Thank You to whiteradam For This Useful Post:
bluesubie (05-27-2014), CSG Mike (05-26-2014), Dezoris (05-26-2014), Lonewolf (05-26-2014), R L Newb (09-08-2014)
Old 05-27-2014, 10:33 AM   #280
bluesubie
whiteradam - With your driving conditions, I would be getting a TBN as well to make sure that the oil is holding up for your interval. Some of this (like the silicon) could still be residual break-in wear.
Insolubles are amazing. What oil filter are you running?
-Dennis
DIY BRZ / FR-S Oil Change RallySport Direct DIY (Do-It-Yourself) Guides 169 09-01-2018 03:42 AM
First Oil Change Jehuty77 CANADA 14 08-10-2012 12:54 AM
When to do your first oil change, and why... MrBodyMassage Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 14 07-17-2012 08:43 PM
Do you change your own oil? If so, why? SteelReign Other Vehicles & General Automotive Discussions 76 04-15-2012 05:44 AM
