Old 04-23-2014, 05:38 PM   #645
steve99
Drives: FT86
Originally Posted by Td-d View Post
Someone want to do some tests for me? Trying to check an address for Fueling Mode (PI, DI, Both).
for A01C, can you log 0xFFF8BD33 as an 8bit, and see if it correlates to what would likely be fueling mode (1,2, or 3).
I would but I'm on G rom.
Old 04-24-2014, 12:47 AM   #646
regal
Drives: Scion FR-S/Toyota Yaris
I won't have time to figure out logging for about a month. I will say going from A00C to B01C is a huge upgrade, if you believe the torque app much less knock. The engine just feels healthier and doesn't stumble and ping at all. Cold starts and idling in general are a huge improvement.
2013 FRS Argento Silver 6MT
Mods:
Clear fender side lights
Tactrix ZA1JB01C 2014 Calib
regal is offline   Reply With Quote
Old 04-24-2014, 03:02 AM   #647
Td-d
Garden variety obsessive
Drives: 2009 Sti Hatch; 2015 Audi RSQ3
Then you can try FFF8BC2F
Td-d is offline   Reply With Quote
The Following User Says Thank You to Td-d For This Useful Post:
steve99 (04-24-2014)
Old 04-24-2014, 04:48 AM   #648
steve99
Drives: FT86
put this in logcfg.txt
;DI PI Both 1 2 3
paramname = Fuel_mode
paramid = 0xFFF8BC2F
databits = 8
scalingrpn = x
always logged "0" unfortunatly.
Old 04-24-2014, 09:57 AM   #649
Td-d
Whilst driving, or in idle?
Old 04-24-2014, 10:06 AM   #650
Td-d
Also - can you try unk_FFF8F5A0 for me?
Old 04-24-2014, 10:08 AM   #651
vgi
Drives: frs
tune A01C defined as:
paramname = Injectors_Mode
paramid = 0xFFF8BD33
databits = 8
always 0
http://www.datazap.me/u/vgi/vishnu-s...=0&data=4-9-16
Td-d, could you pls also look at this param, the values don't make sense to me.
paramname = Manifold_Relative_Pressure
paramid = 0xFFF88F78
isfloat = 1
Could we get Manifold_Absolute_Pressure ?
vgi is offline   Reply With Quote
Old 04-24-2014, 11:06 AM   #652
Td-d
MAP is defined? FFF88F74, or FFF8DB7C.
Can you send me a log of MRP, so I can see what the issue is?
Have you got it correctly scaled?
<conversion units="psi relative" storagetype="float" expr="x*0.01933677" format="0.00" />
<conversion units="bar relative" storagetype="float" expr="x*0.001333224" format="0.000" />
<conversion units="mmHg relative" storagetype="float" expr="x" format="0" />
<conversion units="kPa relative" storagetype="float" expr="x*0.1333224" format="0.000" />
<conversion units="inHg relative" storagetype="float" expr="x*0.03937" format="0.00" />
EDIT: I see you logged it above - I've had a look, you're logging the raw value which is mmHG. When I convert to PSI, looks right.
vgi (04-24-2014)
Old 04-24-2014, 11:31 AM   #653
vgi
Drives: frs
duh. thanks for pointing out, i didn't look at the RR def file.
and i really gotta clean up my file as I can't find anything in it due to all commented out test and ram params
Old 04-24-2014, 05:11 PM   #654
steve99
Drives: FT86
was while driving for about 5 min bit of wot as well always zero
Old 04-24-2014, 05:14 PM   #655
steve99
Drives: FT86
Will try it, is it 8bit any scaling needed ? or is it another address for fuel mode ?
G rom
Old 04-24-2014, 08:50 PM   #656
steve99
Drives: FT86
Tried that address on G rom
8 bit no scaling
always returned 35 in log on a 30 min drive
Old 04-24-2014, 10:38 PM   #657
vgi
Drives: frs
for those self tuning, willing to share and participate in open source software there is an updated MafScaling tool proggie:
http://www.romraider.com/forum/viewt...p?f=32&t=10481
The Following 3 Users Say Thank You to vgi For This Useful Post:
AdrianG (04-24-2014), Hagbard (04-24-2014), s2d4 (04-25-2014)
Old 04-25-2014, 02:05 AM   #658
Td-d
Sigh... ok, back to the drawing board.
vgi (04-25-2014)
Close iJason Member's Car Journals 1 08-04-2013 08:26 PM
Close pche Engine, Exhaust, Bolt-Ons 3 08-04-2013 02:04 AM
Sorry. please close. finch1750 Scion FR-S / Toyota 86 GT86 General Forum 1 07-31-2013 01:00 AM
please close abutterman Wheels and Tires 0 07-05-2013 09:40 AM
