Old 04-23-2014, 07:11 PM   #23577
sklimo
Good luck nerd lol
sklimo is offline
The Following 2 Users Say Thank You to sklimo For This Useful Post:
Calum (04-23-2014), M-17 (04-24-2014)
Old 04-23-2014, 07:17 PM   #23578
LadyFRZ
Car N00b
LadyFRZ's Avatar
Drives: 97 Miata
Originally Posted by Calum View Post
How I know I'm way too deep into exam week and possibly this new trade. I'm sitting here studying for pulse tomorrow and I started thinking about how a regressive damping curve is desired for automotive dampers and how easy that curve is to create with electronics. A simple first order highpass filter is all that is required to achieve that kind of damping. Then I started to think about weather or not that would be possible with mechanical compounds. That's when I realized that I've gone from being a mechanical nerd to an electronics nerd.
Anyway one exam left wish me luck.
Sent from my samstone
Woohoo,one more exam! You can do it!
LadyFRZ is offline
The Following User Says Thank You to LadyFRZ For This Useful Post:
Calum (04-23-2014)
Old 04-23-2014, 07:38 PM   #23579
Swift
I just Drive.
Swift's Avatar
Drives: in the womb still
Lightbulb
Has a cat ever choked to death on a hairball?
Swift is offline
Old 04-23-2014, 08:08 PM   #23580
Muskokan
Drives: white Sport-tech
Haha thought that would get some good answers, asked cause I couldn't sleep lastnight and remembered my buddy had this happen to him with a random, he wrenched away and accidentally elbowed her in the face. Needless to say her brother fought him and there were some awesome stories going around.
Muskokan is offline
The Following 2 Users Say Thank You to Muskokan For This Useful Post:
sklimo (04-24-2014), xoxomichaela (04-24-2014)
Old 04-23-2014, 08:51 PM   #23581
Dimman
Kuruma Otaku
Dimman's Avatar
Penske has done regressive curve dampers. I've looked at it before and come up empty. There are also damping that increases with position, independent of velocity. Those are not too hard.
I'm taking a pneumatics class on Saturdays, and am starting to think about it again. Logic gates through valving. Must be able to do something with dampers...
Because titanium.
Dimman is offline
Old 04-23-2014, 09:06 PM   #23582
Calum
That Guy
Drives: 2013 asphalt FRS MT
I think the problem that we'll never get away from is packaging. Especially considering the stuff DougW is working on will male all of this obsolete.
That said my work with pneumatics didn't include logic gates. It was all vane & nozzles and needle valves to create PID controllers, square root converts, and flow sensors. I'm not sure what a pneumatic logic gate would even look like. Sounds like an interesting course.
Increasing damping with position would probably work well with progressive springs, but otherwise I can't think of a good reason for it.
Calum is offline
Old 04-23-2014, 09:30 PM   #23583
Dimman
Kuruma Otaku
Dimman's Avatar
Well Very simple logic gates, And, Or, Not. We are just doing physical programming with simple circuits. 5/3 valves, cylinders, pilots, physical actuation. It's neat, yet kind of irrelevant to my work because ours are all PLC controlled. So I'm thinking of car applications.
The position valving does come from progressive springs, but from motocross. Linear springs with linkages used for progressive rate increase for the big landings.
The packaging was something else I've thought about. Remote valving. The shock body is just a piston, and the valves are mounted to the chassis in blocks, with high flow, dry break quick disconnect fittings and tubing. Would be more for racing, so a shock could effectively be totally revalved in a very short pit stop. Could mount them in the cabin, maybe, for driver adjustments on the fly, too.
Things I think of when I'm bored...
Because titanium.
Dimman is offline
The Following User Says Thank You to Dimman For This Useful Post:
Calum (04-23-2014)
Old 04-24-2014, 10:52 AM   #23584
Calum
That Guy
I'm DONE:happy anim:: happyanim::happya nim::h appyanim:
Calum is offline
The Following 3 Users Say Thank You to Calum For This Useful Post:
Dimman (04-24-2014), Giccin (04-24-2014), M-17 (04-24-2014)
Old 04-24-2014, 01:47 PM   #23585
Calum
That Guy
Ah, that make since
That would be fucking cool! And it might just work.
Calum is offline
The Following User Says Thank You to Calum For This Useful Post:
Dimman (04-24-2014)
Old 04-24-2014, 11:29 PM   #23586
Dimman
Kuruma Otaku
Dimman's Avatar
Ah, that make since
Hydraulics are pretty much the same, right?
Any way we could tie in vacuum assistance like brakes, for certain applications? If high velocity is detected (pressure based?) we could use vacuum to balance it, creating less proportional damping (which is just pressure differential and flow control?) in that case, possibly regressing the normal curve?
Hmmm... 5 question marks in one post. Out of my comfort zone knowledge-wise. Heh...
Because titanium.
Dimman is offline
Old 04-25-2014, 09:53 AM   #23587
sklimo
LOL I like to wait for my crabs to clear up too before going to doctor!!!!!
sklimo is offline
Calum (04-25-2014), zenki_levin (04-25-2014)
Old 04-25-2014, 10:12 AM   #23588
sklimo
Sounds like you have the flu or worse. Get yo ass to a doctor quick.
And sorry you don't feel well
sklimo is offline
Old 04-25-2014, 10:26 AM   #23589
n2oinferno
Praise Helix!
n2oinferno's Avatar
Originally Posted by zenki_levin View Post
Does anyone here postpone doctor visits when they're sick?
I've been sick for a month maybe longer and finally made a doctors appointment for monday. It'll be interesting what he'll have to say.
It's ebola. You have ten seconds to live. Sorry.
edit: I read the post after the one I quoted.. Trouble breathing sucks. I had pleurisy once and it scared the crap out of me. Every single breath was painful. So I went to the doctor, and then they started running tests to make sure my heart was okay. Thankfully a huge dose of ibuprofen several times a day for several days was the way to fix it, but oh yeah, definitely sucked. Hope you feel better soon.
Just get yourself an octopus. I hear they like to eat crabs. Careful with those suction cups though.
n2oinferno is offline
The Following 2 Users Say Thank You to n2oinferno For This Useful Post:
sklimo (04-25-2014), zenki_levin (04-25-2014)
Old 04-25-2014, 10:59 AM   #23590
sklimo
sklimo is offline
h6 swapouts? any thoughts or advice? f1ver BRZ First-Gen (2012+) — General Topics 53 11-22-2014 12:46 AM
Aspera's thoughts on AWD/RWD... aspera Scion FR-S / Toyota 86 GT86 General Forum 89 11-16-2013 03:55 PM
random casual discussion on dynamic brakes serialk11r Other Vehicles & General Automotive Discussions 4 07-16-2012 10:34 PM
The "if you wanna kiss the backside of white musicians make a thread about it" Thread aliphian Off-Topic Lounge [WARNING: NO POLITICS] 8 12-19-2011 08:59 PM
