Old 04-22-2014, 03:29 PM   #253
Deathalo
Drives: 2013 WR Blue Limited Manual BRZ
Originally Posted by mid_life_crisis View Post
Because if you rip them for max sound quality, they fill up a thumbdrive in a hurry.
It's easier to just grab a few disks on my way out the door.
Really? What thumb drives are you using? You can get 64gb thumb drive for 30 bucks, and that holds more CDs than you can carry with 2 hands.
Deathalo is offline   Reply With Quote
The Following User Says Thank You to Deathalo For This Useful Post:
Prog (04-22-2014)
Old 04-22-2014, 03:46 PM   #254
Prog
Prog's Avatar
Drives: 2016 Cadillac CTS
I'd rather just grab a single 64 GB thumb drive, or my phone that I'll have anyway, either of which will hold well over the amount of CDs you will realistically keep in your car, or be able to "easily grab" on the way out.
Ditto on this. A 64 GB thumb drive would hold well over 100 albums of fully lossless CD rips. If you'd like to hold over a thousand fully lossless CD rips, you can probably [ame="http://www.amazon.com/Seagate-Expansion-Portable-External-STBX500100/dp/B00834SJSK/ref=sr_1_2?ie=UTF8&qid=1398195880&sr=8-2&keywords=portable+hard+drive+usb+powered"]buy one of these[/ame], or find a cheaper one somewhere else.
Prog is offline   Reply With Quote
Old 04-22-2014, 04:13 PM   #255
mid_life_crisis
Drives: FR-S 10 #103 AT
Originally Posted by Prog View Post
A 64 GB thumb drive would hold well over 100 albums of fully lossless CD rips. If you'd like to hold over a thousand fully lossless CD rips, you can probably buy one of these, or find a cheaper one somewhere else.
Lossless compression has improved a lot since the last time I played around with it then. I'll have to look into it again. Can you recommend a good free ripper?
“Sex is like Bridge. If you don't have a good partner, you'd better have a good hand.” - Mae West
Papa said, "son there's a lot of evil temptations out there. Best to try 'em all so you know which ones to avoid."
mid_life_crisis is offline   Reply With Quote
Old 04-22-2014, 04:28 PM   #256
Deathalo
FLAC is the defacto lossless audio codec now, while keeping file size relatively low compared to uncompressed. Still, an uncompressed codec like WAV or AIFF is still only going to produce file sizes equal to the amount of space they take up on a CD, so I think you need some flash drives from this decade....
Old 04-22-2014, 04:59 PM   #257
Prog
Prog's Avatar
I don't really care about lossless audio, so unfortunately, I couldn't recommend an application to you. I just know the technical limitations of CDs are 700 MB without overburn. Albums are usually not the full 80 minutes that a CD can hold, though, so a lossless rip would probably be closer to 500 MB, and if my memory serves me correctly from the last time I dabbled in lossless audio, that file size seems about accurate for an album.
Old 04-22-2014, 05:04 PM   #258
Deathalo
Try EAC or dbPoweramp
Old 04-22-2014, 09:49 PM   #259
Prog
Prog's Avatar
Originally Posted by xjohnx View Post
Also, @SHIFTER - any tips for ejecting the SWC pin so i can reuse it for the amp wire?
How did you get the SWC pin out? I tried Shifter's recommendation of pushing the pin down with needlenose pliers, I tried pulling the wire from the bottom...nothing. Am I missing something?
edit: Nevermind, figured it out. I used a spare harness from my old head unit, pushed down on the little clip inside with an ice pick, and pulled the wire down from the bottom.
Originally Posted by SHIFTER View Post
Nice!!!!!!
I can always yank my stereo to help you with the aux adapter.
So I'm kinda confused on what to do with this aux adapter to make aux in work. Do you have any advice?
Old 04-22-2014, 11:38 PM   #260
Prog
Prog's Avatar
iPhone 5S.
Curious if you got your iPhone 5S working with the old iPhone cable somehow (why haven't they updated this yet?)? It looks like all of the lightning to 30 pin adapters on Amazon don't support audio and only work for charging and syncing. Kind of disappointing.
Old 04-23-2014, 07:37 AM   #261
xjohnx
Grip>Slip
xjohnx's Avatar
I haven't tried yet. I'm hoping CaFi will release an updated cable with a lightning connector. I'm honestly disappointed that it wasn't included since Apple had transitioned over to the lightning connector over a year ago.
Prog (04-23-2014)
Old 04-23-2014, 09:43 AM   #262
Prog
Prog's Avatar
Ditto.
I only got the unit in my car and working about 45 minutes before I went to bed last night, so my only real use was the 30 minutes driving to work this morning.
Very very initial review:
Pros: Looks nice, digging physical buttons over no physical buttons on stock HU/Nexus 7
Cons: Randomly unmounted my USB drive (had to unplug it and plug it back in; it picks up where it left off on whatever it was playing), stock music player sucks (no fast forward functionality other than by dragging the scrubber, which is very unresponsive and not at all intuitive), 30 pin dock connector instead of lightning cable
Neutral: They really didn't try too hard with this disp/seek button. It's honestly pretty useless. Random "Engrish" in the menus, but then again, the stock BRZ HU also had a little of this. Seems to lack a lot of typical head unit features, like controlling fade/balance/bass volume, etc (might just be overlooking this somewhere hidden in the settings, but either way, it doesn't bother me). It does have a setting for the subwoofer frequency, though. Haven't messed with the equalizer yet.
I will post more thoughts and a more thorough review after testing it more and messing with it. I'm hoping I can fix some of the issues I have with the software. I listen to a lot of podcasts in my car, and not being able to fast forward (other than with the quite-literally-useless scrubber) through commercials is a honestly a dealbreaker.
Old 04-23-2014, 09:48 AM   #263
xjohnx
Grip>Slip
xjohnx's Avatar
It does have these. I can't recall off hand where I saw them, but I'll try to check on lunch or after work and update you.
Prog (04-23-2014)
Old 04-23-2014, 09:53 AM   #264
xjohnx
Grip>Slip
xjohnx's Avatar
anyone know the procedure for resetting the unit back to the factory ROM? I'm tempted to try that "root my an-21 u" app, but don't want to try without being able to restore if things get borked up
Old 04-23-2014, 11:39 AM   #265
Prog
Prog's Avatar
I figured I'd just overlooked something in the short amount of time I spent with it.
Just went out to my car and found the bass volume and all of the sound settings for treble/mids/lows etc. Was showing a coworker though so didn't look for the other stuff.
Anyone else having an issue with the unit just randomly unmounting your thumbdrive?
Old 04-23-2014, 11:51 AM   #266
DC2R
Drives: 2014 Scion FR-S
Dumb question but is your thumb drive shaking loose(maybe back of head unit)? We are not talking portable hard drive right?
Sent from my SM-N900T using Tapatalk
DC2R is offline   Reply With Quote
REVIEW: Ca-Fi Toyota Universal - Stock Fitment ANDROID Stereo SHIFTER Electronics | Audio | NAV | Infotainment 16 06-13-2017 06:23 PM
Android, bluetooth, Music, and the FR-S stock pioneer stereo JayNutter Electronics | Audio | NAV | Infotainment 27 12-18-2014 03:54 AM
How to: Torque on an android powered stereo with no hacking v. Ca-Fi Dashlinq4 SHIFTER Electronics | Audio | NAV | Infotainment 29 04-07-2014 04:58 AM
