Old 04-22-2014, 09:14 AM   #6735
RFB
RFB's Avatar
Drives: FRS
Installed strobe tap turn, new brighter switchbacks, trunk led, and lightweight Shorei battery.
The battery swap resulted in lighter more precise steering and noticeably less body roll.
Doing OFT, discs, pads, lines, fluid, studs, spacers, new wheels, rubber and racing lugs next.
CERBERUS
RFB is offline   Reply With Quote
Old 04-22-2014, 10:50 AM   #6736
husker741
Drives: 2013 Whiteout Scion FR-S 6MT
Originally Posted by misooscar View Post
Agency power header with titanium wrap just installed
OFT stage 2 e85, plenty of power now for me!
Sent from my SM-N900T using Tapatalk
Just wondering, did you do any research before buying those headers? They are by far the worst ones for our car and have been proven to not give any gains. The gains you are feeling are either the placebo effect or just the tune. If you're happy, that's great, but you have a lot of power left on the table because of those headers.
husker741 is offline   Reply With Quote
Old 04-22-2014, 11:43 AM   #6737
hamzam
Proud dad of 2 boys :)
hamzam's Avatar
Drives: Firestorm 6-MT
Originally Posted by Young_makaveli View Post
How are the mtec springs ?
Does shifting really feel better ?
Sent from my SM-N900W8 using Tapatalk
They help guide the shifter into the next gear easier. It almost makes it feel like a gated shifter because it stiffens up the Left-Right, Up-Down movement of the shifter.
There is no "slack" or free play in the shifter after installing these springs.
hamzam is offline   Reply With Quote
The Following User Says Thank You to hamzam For This Useful Post:
Young_makaveli (04-22-2014)
Old 04-22-2014, 11:49 AM   #6738
Young_makaveli
Young_makaveli's Avatar
Drives: 2013 frs
I'm looking into buying theses
Alot of good reviews about it
was the install easy ?
Young_makaveli is offline   Reply With Quote
Old 04-22-2014, 12:05 PM   #6739
hamzam
hamzam's Avatar
Easiest/Quickest Mod to date.
Getting the right size tools is the hard part :P
[ame="https://www.youtube.com/watch?v=Jk8mkTfLANk"]MTEC Shift Spring Installation for Scion FRS / Subaru BRZ / Toyota 86 - YouTube[/ame]
Old 04-22-2014, 12:40 PM   #6740
Choco
Embarrassed Doge
Choco's Avatar
Drives: Shibaru BRZ
Hey is this normal engine noise ?
It happens almost every time after the car has not mover for a few hours
Mine never makes that noise...
Old 04-22-2014, 12:42 PM   #6741
brz2013
brz2013's Avatar
Drives: 2013 wrb brz
WHAT DID YOU DO TO YOUR FRS TODAY?
Sounds like a rod bearing
brz2013 is offline   Reply With Quote
Old 04-22-2014, 12:46 PM   #6742
brz2013
brz2013's Avatar
Sounds like a rod bearing. Does it increase with rpm
Old 04-22-2014, 12:47 PM   #6743
Young_makaveli
Drives: 2013 frs
It actually goes away
It only does it in the morning for like 2 mins
Old 04-22-2014, 12:49 PM   #6744
brz2013
brz2013's Avatar
But while it's doing it if you rev it does it increase? Either way I would go to the dealer right away
Old 04-22-2014, 12:55 PM   #6745
misooscar
misooscar's Avatar
Drives:
I bought a used set for $350, so I thought I'd give them a try. The only info that I could find about them was on this forum (quite negative), as you noted.
I was thinking that the elimination of the cat should make a difference too.
I didn't want to wait 6 to 8 weeks for the Vishnu headers.
Which header do you think offers the best bang for the buck?
misooscar is offline   Reply With Quote
Old 04-22-2014, 01:02 PM   #6746
Chad86
DrivinginDreams...Cloud86
Chad86's Avatar
Drives: Toyota GT86
CERBERUS
Please explain the battery swap. Are you serious on this that it does make a difference?
Chad86 is offline   Reply With Quote
Old 04-22-2014, 01:03 PM   #6747
Chad86
Chad86's Avatar
Drives: Toyota GT86
Exclamation
Get the Open Flash Headers
http://openflashtablet.com/products/OFH/index.html
Old 04-22-2014, 01:36 PM   #6748
husker741
Best bang for buck, IMO, is Rev Works. They hand make all of them, they have been tried and tested, and they are a reputable company that knows their way around Subaru engines and parts. Look for a used one. Once in awhile they come around and you can get it for a little more than you got those AP ones for. The sound is good and the performance is good.
