| Software Tuning Discuss all software tuning topics. |
#57 | |
Drives: UK GT86
.: Stealth 86 :.
#58 | |
Drives: Scion FR-S/Toyota Yaris
Any ADC chip on an ECU has a finite bandwidth, increase the range on the O2 sensor you lose resolution not a big deal and probably well worth if if going forced induction.. Also requesting the tuner to target a less aggressive tune to reduce knock and the trims (corrections) will stray less. Mad_SB's strategies are what us old special guys call a "track tune", you may have a bit less Hp on the dyno but the tune will be more consistent day to day tank to tank.
2013 FRS Argento Silver 6MT
Mods: Clear fender side lights Tactrix ZA1JB01C 2014 Calib |
#59 |
Drives: White FR-S
just do like elvis graton and write bilingual one shot pis ta pas a traduire XD
| The Following User Says Thank You to R3d For This Useful Post: | NoFear99 (08-02-2013) |
#60 |
Drives: FR-S Firestorm
The only way to fix this issue is to continue to send logs to your tuner once a week or every two weeks to show him how your tune react over time and this way tuners should be able to stabilize the afr.
Well this is what I understand after several exchange with Tony in pm.
- 2013 Scion FR-S Firestorm
- 2007 Lotus Exige S 280 Solar Yellow - 2007 Honda CBR 600RR - 2002 Bombardier Legend 800SE Website : http://nofear99.monchar.com |
#61 | |
Calle Atun
Drives: 13 FRS, 93 Mr2, 85 ae86
Also the names of the other tables seem to be a little different. Should I zero all of these too? Closed Loop Delay Maximum Engine Load Closed to open loop Delay periods Delay close loop engine load Timer Delay open loop fuel load Threshold #1 Delay open loop fuel throt thresh #1 |
#62 | |
Drives: UK GT86
-Closed to open loop Delay periods -Delay close loop engine load Timer As for the CL AFR tables, he means fill them with 14.7 I can't see a min CL AFR table in ECUtek though, so I assume that the stock value of 14.0 is used.
.: Stealth 86 :.
#63 |
Calle Atun
So what you saying is if i zero the two tables you listed, then the rest of the tables i list have no effect, if they are zero or stock values?
#64 | |
Drives: UK GT86
http://www.romraider.com/forum/viewt...c8b44bc64d2efd
.: Stealth 86 :.
#65 |
Anyone thinking they have this "issue" should log the commanded AFR, actual AFR and both ST and LT trims.
What is probably happening (without seeing full scope of data) is that the actual AFR is leaner than the commanded AFR but eventually after enough driving the LTFT catches up and the two AFR's are closer (or the same). This isn't an issue with the tune or the car, but a scaling issue with the MAF (or possibly injectors if they've been swapped and not scaled properly). With a properly scaled MAF the trims should be much smaller, or zero even after weeks/months of driving.
| The Following 3 Users Say Thank You to wparsons For This Useful Post: |
| Drift Office Tune vs Visconti Tune | mechaghost | Engine, Exhaust, Transmission | 109 | 07-03-2014 12:57 AM |
| Just want to make sure | Moonbase | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 6 | 04-16-2013 04:02 PM |
| Need to make time this weekend.. | Khánh | Scion FR-S / Toyota 86 GT86 General Forum | 0 | 02-06-2013 07:43 PM |
| Dynotronics and their E-Tune/ OTA tune. | Ricepuddin | User/Vendor/Sponsor Reviews, Feedback, Comments | 5 | 12-24-2012 09:53 AM |
| Time to make some noise and some demands: VR + AP CF FR-S/BRZ aero trim | poormans_LFA | Cosmetic Modification (Interior/Exterior/Lighting) | 14 | 09-05-2012 04:44 PM |
