Old 04-20-2014, 08:08 PM   #701
orthojoe
Originally Posted by solidONE View Post
All I see is that I'm not going fast enough not carrying enough speed
You should really sit down with someone that knows this track well and review this, because that is not what I see. You are oversimplifying it. Your above observation is the last thing I would work on. It's not as simple as just driving faster through a corner. I guarantee you that if you go faster through a lot of those corners, you'll go off with the line you're driving. I'm gonna have to agree with dradernh here. Go back and learn how to drive the line correctly and consistently first because it only gets harder to drive the right line when you increase the speed. The right line is what allows you go drive faster through the corner.
You're also breathing off the throttle entering a braking zone, not using the entire track (I think I see you hitting a berm once?), not tracking out at the exit and pinching yourself off, applying throttle near the exit of the turn rather than at the apex or before (SLOW in, fast out), not starting out wide enough entering a corner... Just work on the line first.
Does this not look smooth? I think I clipped most of the apexes as well.
You need to get a coach. Best thing you can do.
Here's a run I did on a local back road with stock tires with VSC on.
http://s174.photobucket.com/user/sol...43611.mp4.html
As you can see it was very intrusive. I'm sure the stock tires has a lot to say about how the TC is kicking in.
I'm not sure how driving on a broken, jacked up, back road is really relevant when it comes to VSC on a track...? It looks to me like VSC was saving you from wrapping the car around a tree or going off a cliff.
2013 Subaru BRZ
orthojoe is offline   Reply With Quote
The Following 2 Users Say Thank You to orthojoe For This Useful Post:
CSG Mike (04-21-2014), solidONE (04-20-2014)
Old 04-20-2014, 09:28 PM   #702
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
Originally Posted by chrisl View Post
The road looks fairly bumpy and uneven to me, which could cause the TC to kick in a fair amount.
While not quite as bad as this road, buttonwillow and streets of willow are both notoriously chewed up tracks.
Old 04-20-2014, 09:41 PM   #703
ayau
Drives: Some rust bucket
Having the camera mounted in the back window to show your hands would be helpful.
Old 04-20-2014, 09:44 PM   #704
solidONE
solidONE's Avatar
Yeah your right SLOW in fast out has been the way I've been driving to keep smooth. And me not using the entire track is a result of not going speeds high enough to require the use of the entire width of the track. Cutting the turns and sticking on the inside is an attempt to reduce distance traveled and using the excess grip I have available.
To be fair that road I'm very familiar with and the setup I had was more conducive to wheel spin (stiffer springs, harder tires). Tho like I said buttonwillow and streets of willow are very bumpy tracks.
Old 04-20-2014, 09:55 PM   #705
orthojoe
Well it sounds like you've got it all figured out then. Good luck getting faster.
2013 Subaru BRZ
The Following User Says Thank You to orthojoe For This Useful Post:
Old 04-20-2014, 09:56 PM   #706
ayau
Never heard of this philosophy before. Shortest distance traveled doesn't mean the fastest driving line. I thought you wanted to be a faster driver.
The driving line allows you to carry the most speed. You may not be using all of the tires' available grip now, but once you become faster, you'll want to drive that line.
The Following User Says Thank You to ayau For This Useful Post:
AZP Installs (04-20-2014)
Old 04-20-2014, 10:00 PM   #707
solidONE
solidONE's Avatar
Uh.... Thanks?
Old 04-20-2014, 10:01 PM   #708
orthojoe
I think we're wasting our time here. This guy just takes advice and then turns it around with excuses or calls it bull. Coach wont help either...
2013 Subaru BRZ
Old 04-20-2014, 10:05 PM   #709
solidONE
solidONE's Avatar
No of course it isn't, and it's not a philosophy. It's just describing what I'm doing after realizing I'm going way slower than I could have entering the turn.
Old 04-20-2014, 10:11 PM   #710
solidONE
solidONE's Avatar
Chill out man... I do appreciate input. And what I'm saying is not excuse it just describing what I'm thinking and doing. if I seriously think I have it figured out why would I even ask this on a public forum? I wouldn't and I don't. So... No need for angry posting. Mmkay?
Old 04-20-2014, 10:13 PM   #711
AZP Installs
AZP Installs's Avatar
Drives: '11 STi->'14 BRZ | '14 Touareg TDi
Send a message via AIM to AZP Installs
If the VSC is being very intrusive in sport mode, you may still be on stock tires or not smooth enough. I would try it out on a smooth track and summer tires at a minimum.
-Mike Paisan
Maintaining, Modifying and Educating TriState Enthusiasts since 2001.
Like us on Facebook! | E-mail: sales@azpinstalls.com | 725 Fairfield Ave | Kenilworth, NJ 07033 | 908.248.AZP1 (2971) |AIM: AZP Installs
"Race Tested, Enthusiast Approved!"
AZP Installs is offline   Reply With Quote
The Following User Says Thank You to AZP Installs For This Useful Post:
Old 04-20-2014, 10:30 PM   #712
solidONE
solidONE's Avatar
-Mike Paisan
How about RS-3's on a bumpy track? Would you suggest leaving VSC on?
From what I gather with @orthojoe's critique is that you should never stick the inside of the corner regardless how slow or how much more grip u have available and stick with the racing line at all times as a novice level driver? Would you agree with that advice?
Old 04-20-2014, 10:34 PM   #713
orthojoe
Not angry, amused. I can't figure out why you're asking on a public forum either because according to you, you're nailing those apexes, you know the line, you're driving so smoothly that VSC slows you down big time, and you can't be bothered to track out because it will slow you down.... yet your lap times suck. But, you've got it all figured out because you just need to go through that corner faster. So simple! Turn off that VSC, go flat out, and let us know how it goes.
Anyone want to volunteer to be his coach? (crickets)
2013 Subaru BRZ
Old 04-20-2014, 10:36 PM   #714
AZP Installs
I'm not familiar with the RS-3 tires. I'm more familiar with the Direzza ZII, Michelin PSS, R888s, RA1s for the track.
I agree 100% with @orthojoe on that comment. You ALWAYS should be driving the 10/10th line even if you are not driving your car to 10/10ths. The only exception to that rule, which doesn't apply here, is in wheel to wheel racing, where not driving the line is due to race craft.
-Mike Paisan
The Following 3 Users Say Thank You to AZP Installs For This Useful Post:
CSG Mike (04-21-2014), Pat (04-21-2014), solidONE (04-20-2014)
Simple question, hard to find answer... Mango22 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 05-16-2013 06:23 PM
Silly question about protecting track rims sw20kosh Tracking / Autocross / HPDE / Drifting 16 04-25-2013 12:34 PM
Asking the question that I already know the answer to. Are the engines the same? Bigmaxy Engine, Exhaust, Transmission 10 01-19-2013 07:47 PM
Random dog-related question for those who have their BRZ GMU-BRZ BRZ First-Gen (2012+) — General Topics 11 05-31-2012 07:48 AM
Got my answer - BRZ comes with HID headlights as STD Z_Rocks BRZ First-Gen (2012+) — General Topics 20 01-10-2012 09:54 AM
