go_a_way1
Old 04-20-2014, 12:32 PM   #4439
robwbright
Drives: '13 BRZ Limited WRB Phantom ESC 1.5
Originally Posted by enwave View Post
Tryin' my best to get this thing ordered! Waiting to hear back from Rob, who I know is very busy.
This'll be fun -- OFT/OFH/E85 currently, adding 1.5dump TQ250 should be an absolutely insane value.
Rob told me he doesn't take any money until he has availability. I asked him to put my name on the list because I'd like to be in the next batch that's available.
'13 BRZ Ltd MT WRB Phantom ESC 1.5
2012 Honda Accord Coupe
2006 Saab 9-3 2.0t
1997 Honda Accord Coupe
1995 Honda Prelude VTEC
robwbright is offline   Reply With Quote
The Following User Says Thank You to robwbright For This Useful Post:
enwave (04-20-2014)
Old 04-20-2014, 12:32 PM   #4440
fenton
Originally Posted by Sojhinn View Post
Don't forget the huge smile!
Happy Easter everyone!
Suggest also starting a good relationship with your local tire shop....gonna be replacing some rubber!
Sent from my HTC One using Tapatalk
fenton is offline   Reply With Quote
The Following User Says Thank You to fenton For This Useful Post:
raven1231 (04-20-2014)
Old 04-20-2014, 12:49 PM   #4441
enwave
That headunit though...
enwave's Avatar
Drives: 2013 Subaru BRZ Limited SSM
Hehe I just took a nail through the sidewall of my last set, so took the chance to go PSS. We'll see how long those last me
2013 BRZ Limited SSM 6AT
Phantom ESC 1.5Dump + E85 + OFH + Q300
Eibach Pro-Kit + Michelin PSS (stock size)
enwave is offline   Reply With Quote
Old 04-20-2014, 01:11 PM   #4442
WNDSRFR
Drives: FR-S,GTI
The only part I know is the batteries are 21 dollars each. Rob had to create a custom conversion kit to add it to your original dump pack. All said and done it will be a nice little upgrade at a fairly minimal cost.
From the dyno we saw a increase of about 7 to 10 HP from 4000 rpm on....shiv managed to pick up 11 HP with the dual dump without even modifying the tune.
That being said this mod obviously won't put you back in the seat the same way the original installation of the ESC did. It really rounds out the performance of the kit and helps the system maintain a bit more boost on the top end.
Where can you get batteries for $21 each?
The website says they are $89.54 for the dump pack.
Or is there that big a difference between US $ and Canadian $?
Old 04-20-2014, 01:28 PM   #4443
TM
TM's Avatar
Drives: DGM BRZ 6MT
The $21 is for the extra half dump batteries.
TM is offline   Reply With Quote
The Following User Says Thank You to TM For This Useful Post:
fenton (04-20-2014)
Old 04-20-2014, 01:41 PM   #4444
raven1231
Thought it was a different battery
Old 04-20-2014, 02:01 PM   #4445
fenton
Yes the addition half dump are different batteries from the first ones.
They are half the size and half the price. 21 bucks each.
The Following 2 Users Say Thank You to fenton For This Useful Post:
-Ozzy- (04-20-2014), raven1231 (04-20-2014)
Old 04-20-2014, 08:37 PM   #4446
Gary in NJ
Gary in NJ's Avatar
Drives: WR Blue BRZ, 240Z
What's the make and model? I might as well get 'em because resistance is futile.
Phantom ESC, ECUtek Tune, Nameless Front Pipe & Axle Back, Enkei RS+M 17x8 et35, OEM+Ref
Gary in NJ is offline   Reply With Quote
Old 04-20-2014, 08:43 PM   #4447
Sojhinn
Lightning McQueen Driver
Sojhinn's Avatar
Drives: Limited Red 6MT BRZ
2 of these:
http://www.atbatt.com/power-sonic-12...roduct=12V+9Ah
Installed Mods:
The Following 3 Users Say Thank You to Sojhinn For This Useful Post:
Gary in NJ (04-20-2014), robwbright (04-24-2014), WNDSRFR (04-21-2014)
Old 04-21-2014, 11:05 AM   #4448
fenton
Has anyone with the oft and phantom sc tried launch control?
I know we probably shouldn't go WOT with boost and LC both being active but maybe 75 percent throttle just so that it gets to 5500 rpm then wait for the revs to drop a bit and hit it with 100 percent throttle?
This is what I did with my brz edit tune..... With ecutek it was not possible because because you had to do a special launch sequence that involved clutch, first gear, 100 percent throttle.
@shiv@vishnu can you comment on if LC is safe with boost?
Thanks
Old 04-21-2014, 11:14 AM   #4449
Gary in NJ
Gary in NJ's Avatar
I've posted on this a few times. Launch control works via the ECU rapidly opening and closing the throttle plate to maintain rpm (5,000 or 5,500...I don't remember where the sweet spot lies). It would be much safer to just hold that rpm via the throttle and going WOT during launch. You would get the instant response of the ESC rather then a depleted engagement. For example, if you held the launch control for two seconds you'd launch with 18.x volts rather then a full charge if you modulated the throttle.
Old 04-21-2014, 11:15 AM   #4450
fenton
Oh I agree. Plus if you add boost to 5500rpm you are just going to spin to redline. The key is to get off the line quick and then when traction stabilizes hit boost.
Gonna try it today...I will report back.
Old 04-21-2014, 01:33 PM   #4451
jflogerzi
jflogerzi's Avatar
Absolutely. With that setup you are looking at 235ish HP and at least 200tq at 2500 rpm.
Holly Hell! Those are great numbers for the costs!
Old 04-21-2014, 04:05 PM   #4452
WNDSRFR
Drives: FR-S,GTI
I've been thinking a lot about batteries lately.
What do you guys think about the Power-Sonic starter battery?
Have you ever had a problem starting the car?
I ask you this because I've never had a problem with it but I live in Florida and I notice a lot of you live in the frozen north. Or the really cold northwest.
I'm totally impressed how such a relatively small and light weight thing can replace the anchor of the stock battery.
So... Any bad stories?
Circuit Motorsports - Vortech Supercharger FR-S Build + Full Perrin Exhaust & Extras Circuit Motorsports Member's Car Journals 4 03-21-2013 04:45 PM
Subaru BRZ : Full Throttle, powerslide, hard revving & ride ESBjiujitsu BRZ Photos, Videos, Wallpapers, Gallery Forum 20 05-30-2012 06:43 PM
86 Full Throttle Video + another. Aus86 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 2 04-02-2012 07:07 AM
