Old 04-19-2014, 09:02 AM   #1
Muskokan
Drives: white Sport-tech
Least harmful additives to eliminate crickets
why hello there,
Like most of you my Brz has been experiencing crickets on and off through out its life, currently I've been on the latest DI pump for 10,000 km and they are becoming more constant than ever, no matter what fuel i use.
I have previously read people using a couple things to stop the friction that causes the chirps, whether it be a cap full of 2 smoke oil, fuel injector cleaner, or octane booster.
I want to hear from you guys what worked best with your 86, and if some people with more expertise could chime in on possible risks, increased wear, or effects on performance on using any additive that could help with crickets.
hoping to find the best way to get rid of this annoyance cause toyotabru ain't gunna do it!!
Muskokan is offline   Reply With Quote
Old 04-19-2014, 09:15 AM   #2
s2d4
s2d4's Avatar
run e85
Old 04-19-2014, 09:40 AM   #3
Muskokan
We don't get corn up here in northern ontario not even 93
Old 04-19-2014, 09:48 AM   #4
White64Goat
Some people are using Lucas Upper Cylinder Lubricant which is mixed 3oz. to 10 gallons. Also cleans injectors etc.
Old 04-19-2014, 11:31 AM   #5
m.wood0213
Driving Enthusiast
m.wood0213's Avatar
Drives: 2013 BRZ Limited
This used regularly seemed to help me out a lot.
“This isn’t a supercar, it’s a sports car. It sacrifices rear seats yes but it just feels alive. Pure, direct, immediate. The other two are going to get all the admiring looks yes, that’s my point. I’m not driving around in this for other people’s benefit. I’m driving around in this BECAUSE I LOVE DRIVING IT. END!”
-Richard Hammond, Top Gear, USA Supercar Road Trip, 2011 Porsche GT3 RS.
My BRZ
m.wood0213 is offline   Reply With Quote
Old 04-19-2014, 09:08 PM   #6
Muskokan
Any way there could be side effects?
Old 04-19-2014, 10:26 PM   #7
White64Goat
Maybe if you dumped a whole bottle in...........
Old 04-19-2014, 10:32 PM   #8
extrashaky
Drives: 2014 BRZ Limited
Anybody using Marvel Mystery Oil?
Old 04-20-2014, 01:31 AM   #9
shellslinger
Drives: Whiteout FRS
Turn up the radio!
shellslinger is offline   Reply With Quote
The Following 3 Users Say Thank You to shellslinger For This Useful Post:
Pseud0logik (04-28-2014), strat61caster (04-23-2014), swpbrz (04-27-2014)
Old 04-20-2014, 03:17 AM   #10
Tromatic
Klotz Uplon works well for me.
Old 04-20-2014, 07:25 AM   #11
Muskokan
whats that?
thinking of gunna just try some lucas injector cleaner from the gas station today and see how that does, im pretty sure i remember people saying using it can hurt gaskets or seals or something...
Old 04-20-2014, 08:51 AM   #12
Mad1723
Mad1723's Avatar
Drives: Asphalt FR-S
Best way is to avoid petro canada 94 (which contains 10% ethanol) and go with Shell V-Power. Never had the crickets before, used Petro 94 and it started. Went back to Shell V-Power, boom, problem fixed
Mad1723 is offline   Reply With Quote
Old 04-20-2014, 08:57 AM   #13
BRZnut
Drives: BRZ DGM Limited
Some have used 2-cycle TC-W3 engine oil. They add 1 oz to 5 gallons of gas after each fill up. It keeps the crickets away and makes the engine less noisy.
This has been used in may types of cars with positive results and no negatives that I've ever read. There is a lot written on it. (do a search and see!)
Old 04-20-2014, 09:24 AM   #14
Muskokan
yea after doing some research tc-w3 oil seems to be a generally accepted additive for a smoother running engine that also helps ethonol in the fuel.
I use Shell v power 91 regularly and my crickets are literally starting to sound like bird chipring now theyre getting so loud, ive checked oil and coolant 3 times in the past 2 days cause the engine sounds like shit, chirping, woodpeckers, louder than ever, and not even when completely warmed up now... makes me wonder if my pump might actually fail.
chirp, cricket fix, di pump
Tire smell harmful? eSOLOR Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 7 01-27-2014 09:15 PM
Substantive Evidence K and N that harmful? BlackyRose Engine, Exhaust, Transmission 22 06-11-2013 03:27 PM
Local airport has 100 octane gas, would it be harmful to run? VesperLynn BRZ First-Gen (2012+) — General Topics 26 05-19-2013 09:02 AM
Myth about Fuel Additives Grishbok Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 0 09-20-2012 12:32 AM
Fuel Additives ArKiTeCkT Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 40 06-13-2012 03:26 AM
