Old 04-19-2014, 07:15 PM   #561
krayzie
Drive From Home
krayzie's Avatar
Drives: BRZ STI Performance
Originally Posted by cslntuee View Post
I almost pull the trigger to buy the Bilstein B8. (I have already bought
the standard pink STI spring, but have not yet install.)
I change my mind after I carefully reading the STI website again.
(I put it in Google translate)
http://www.sti.jp/parts/catalogue/br...0330AS000.html
It sounds like standard pink STI spring is designed for the Stock shock.
Bilstein B8 (or STI tuned Bilstein) might match with new pink STI spring (front is different than standard one) and 18 inch wheel better.
Thanks.
Then you have the Toyota optional shocks from Sachs with the new handling pack which matches the stock springs. Now wouldn't that mean these optional shocks would match the STI Performance Catalog pink springs?
krayzie is offline   Reply With Quote
Old 04-19-2014, 08:56 PM   #562
cslntuee
Drives: Subaru BRZ Limited
I also thought this option before ( Sachs)
I read the announcement as below
http://car.watch.impress.co.jp/docs/...10_643687.html
It looks like this new shock is for 18 inch wheel, so need to rebalance
the handling and comfortable.
I am not sure the different between the 2015 GT86(FRS) and 2015 BRZ,
but the spring is the only suspension different between 2013-14 FRS and BRZ.
I am a BRZ owner, so I prefer to keep this small unique points and
try to believe that Subaru (STI) can tune this car better than Toyota.
So, I will temporary go STI standard pink spring on stock shock with 17 inch
wheel and wait and see how Subaru modify this parts on 2015 BRZ.
However, I might consider (or copy) BRZ STI (ts) setup (Bilstein+ new STI
front spring) or Toyota (Sachs), if I upgrade to 18 inch wheel.
Thanks.
cslntuee is offline   Reply With Quote
Old 04-19-2014, 09:13 PM   #563
krayzie
Drive From Home
krayzie's Avatar
Thanks.
That's a very good point, I totally forgot about the 18" staggered setup they tested these shocks with (F: 215/40/R18 R: 225/40/R18).
If you look at the STI Peformance Catalog, they will specify if the part is compatible with Rev. A (MY2013) or Rev. B (MY2014). If they are using stiffer bolts for the engine crossmember and rear shocks, I can't wait to see if they will rate the handling and chassis parts to be compatible with Rev. C (MY2015).
Old 04-20-2014, 02:22 AM   #564
SuperDave
SuperDave's Avatar
Drives: DAT Rally Blue BRZ
Thanks.
Are you selling the pink brz sti springs then?! If so, let me know!
SuperDave is offline   Reply With Quote
Old 04-20-2014, 06:40 AM   #565
cslntuee
Actually, I am trying to say standard pink STI spring match stock shock
better than Bilstein B8.
So, I change my mind and will not buy the Bilstein B8.
Sorry for the misleading.
Thanks.
Old 04-21-2014, 04:43 AM   #566
mister.bond
Drives: BRZ Subaru
[QUOTE=chanomatik;1683819]Almost Stalker Status...
NO ! not at all,..... bitte erst nachdenken, dann schreiben !
the thing is, if someone do NOT reply to PN´s 2 times.....
i thought the PN writing does not come through.......
so, that is the reason why i try to write here to the person....
but now, i know.... er hat einfach keine Bock zu antworten !
mister.bond is offline   Reply With Quote
The Following User Says Thank You to mister.bond For This Useful Post:
chanomatik (04-21-2014)
Old 04-21-2014, 05:48 AM   #567
Baramzisyan
turbo turtle
Baramzisyan's Avatar
Drives: exit GT86 enter STI
okay, guys!
need price for this airbag cover with STI logo
Baramzisyan is offline   Reply With Quote
The Following User Says Thank You to Baramzisyan For This Useful Post:
Trap63 (04-21-2014)
Old 04-21-2014, 07:05 AM   #568
mister.bond
Drives: BRZ Subaru
airbag STI Logo Badge is not available....
but ...... i wrote to japanparts cause of the
STI Air Filter ( PART Nr. : ST16546ZA000 )
and..... then 10 hours later....... they listed the STI Air Filter
Link : http://www.japanparts.com/db/parts_d...=&SEARCH_page=
ok, without a photo, but its ready for Order
The Following 3 Users Say Thank You to mister.bond For This Useful Post:
chanomatik (04-21-2014), krayzie (04-21-2014), Trap63 (04-21-2014)
Old 04-21-2014, 07:12 AM   #569
Burrcold
Again, relax man!
The Following User Says Thank You to Burrcold For This Useful Post:
Old 04-21-2014, 07:46 AM   #570
DaJo
FT86Club Vancouver
DaJo's Avatar
Drives: BRZ Sport-Tech; Drove: MR-S, AE86
[ame="https://www.youtube.com/watch?v=GTKAJUkEwuo"]Relax man, it's just... - YouTube[/ame]
1984 AE86 BT 20V 5MT 2007-2012
2000 MR-S 5MT
2010-2012
2013 BRZ Sport-Tech 6AT
Since '12 (OEM+ STI tS Build)
2015 Lexus IS250 AWD F-Sport 2 2015-2018
2018 Lexus NX300 F-Sport 3 Since '18
DaJo is offline   Reply With Quote
The Following User Says Thank You to DaJo For This Useful Post:
Trap63 (04-21-2014)
Old 04-21-2014, 02:21 PM   #571
Khazzy
Khazzy's Avatar
Drives: SWP Subaru BRZ
tS radio shroud and dash piece for RHD is now available too under Subaru Parts on japanparts.com
2013 SWP BRZ full STi Lip kit installed. Tons of other mods from interior to exterior. One of the cleanest BRZ's around in the midwest! Enjoy the build thread below.
Full of pictures, exhaust clips, garage shots, and walk around video encasing its beauty.
The Following User Says Thank You to Khazzy For This Useful Post:
Trap63 (04-21-2014)
Old 04-21-2014, 02:33 PM   #572
krayzie
Drive From Home
krayzie's Avatar
Did you ask them about the radiator cap too?
Old 04-21-2014, 02:38 PM   #573
mister.bond
Drives: BRZ Subaru
Yes i do ask him about the radiator Cap.
but i think i wrote to late cause no answer yet.
when i wake up here in Germany i have only a short time to contact
the Guy from Japanparts cause of the Difference in Time between
Germany ( Me ) and Japan ( Guy from Japanparts ) :-))))
So , when i start the day, he leave the office a few minutes later
but i think he will answer tomorrow
ps : searching for used STI Axelback /
Old 04-21-2014, 05:18 PM   #574
chanomatik
Snow Don't Hurt!
chanomatik's Avatar
One can never have too many STI parts! Keep 'em comin'!
it sucks to be broke, sti omg!
WTB: Parts for my FR-S hyperpunx Interior Parts (Incl. Lighting) 1 03-05-2013 05:28 PM
[Group Deals] SoCal Subaru BRZ parts or Any Parts Giccin Southern California 25 08-26-2012 10:30 AM
