Old 04-18-2014, 11:15 PM   #1
ecko04
Seems Legit
ecko04's Avatar
Drives: Toyota
DIY/Post Your Spec-D Headlamp Pics
So here are mine.
Preface: These are NOT FI friendly!
Start with removing your bumper and current headlamps
http://www.ft86club.com/forums/showthread.php?t=8788
Wiring Info for Spec-D Lamps
Wires:
Headlamp harness (4 wires)
Red (+12v), Red/Black (Ground) = These toggle the high beam actuator
Blue (+12v), Blue/Black (Ground) = Positive trigger for the low beam headlight. Essentialy these turn the headlight on.
Other 4 remaining wires.
x2 Black (Ground) - x1 ground for the high beam actuator. x1 ground for the LED boomerang, turn signal and low beam headlight.
Yellow (+12v) - Amber turn signal
White (+12v) - LED boomerang
Do you need a DRL mod?
You DO NOT need a DRL mod for these lamps!
Those with the FRS can essentially opt to NOT connect the yellow wire if you don't like the amber within the lamp, after all, you have turn signals in the lower bumper.
For the FRS, if you want the boomerang to remain lit at all times as long as the headlights are on or the parking brake is dropped, you can wire them to the +12v in the turn signal harness. I'll verify which wire this is tomorrow when I complete the install.
The LED boomerang color changes depending on what angle you look at it. I don't believe there is an HID kelvin temp perfect match.
Now, how you wire yours will depend on how you want them to function. Personally, I wired my boomerang to the remote wire of the turn signal as well as diode isolated to the parking light circuit. Wiring it this was keeps the boomerang on as a DRL as well as with the low and high beam.
Current Setup Winjets
HIDs for Spec-D
Bulb Installation (bar towards the bottom)
Military Splice Ground (No need to connect 2 separate ground wires)
D2S Ballasts with wires pulled through grommet
https://dl.dropboxusercontent.com/u/...2019.28.35.jpg
Clamp these down a little more to grasp the cable tighter to ensure a solid connection
Plastic Cap will need to be drilled to run wires
Wiring to Switchback (Turn Signal)
Testing
No build thread. I don't want to be reminded of how much money I spent.
[insert profound quote here]
ecko04 is offline   Reply With Quote
Old 04-19-2014, 07:28 AM   #2
ecko04
Seems Legit
ecko04's Avatar
Drives: Toyota
Old 04-19-2014, 10:01 AM   #3
FRSNewb
FRSNewb's Avatar
very nice! I should get getting my Spec-D lights soon in the mail
1993 Mazda MX-3 - *SCRAPPED* / 1999 Plymouth Neon - *WRECKED* / 2000 Chrysler Neon - sold / 2006 Honda CR-V - sold / 2019 Chevrolet Colorado - All Year Round Vehicle / 2013 Scion FR-S - Summer Car
FRSNewb is offline   Reply With Quote
Old 04-19-2014, 12:39 PM   #4
charged86
charged86's Avatar
@ecko04 why are these not FI friendly?
INSTAGRAM @Rcf_700 www.youtube.com/boostindub
Old 04-19-2014, 01:18 PM   #5
ecko04
Seems Legit
ecko04's Avatar
Drives: Toyota
If you have a FI system that was designed for the FRS the Spec-D lamps have a mounting surface on the bottom to accommodate factory ballasts. That may not clear the FI guys IC piping.
If you have a system designed for the BRZ then you're fine since it should've been designed with the factory ballasts in place.
Old 04-19-2014, 01:18 PM   #6
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
I'm wondering this too..
Old 04-19-2014, 01:34 PM   #7
FRSNewb
FRSNewb's Avatar
Originally Posted by ecko04 View Post
If you have a FI system that was designed for the FRS the Spec-D lamps have a mounting surface on the bottom to accommodate factory ballasts. That mounting surface will hit your front mount intercooler piping on the passenger side and not provide enough clearance to mount the lamp. You'd have to do some major hacking to the lamp to get it to fit...then you'll need to seal it up.
what does FI mean?
Old 04-19-2014, 02:55 PM   #8
ecko04
Seems Legit
ecko04's Avatar
Drives: Toyota
Originally Posted by FRSNewb View Post
what does FI mean?
Foolish Individual
Old 04-19-2014, 03:24 PM   #9
ecko04
Seems Legit
ecko04's Avatar
Drives: Toyota
Stolen pics from @Jarumie42172 who has a real camera.
Originally Posted by Jarumie42172 View Post
Got the Spec-D headlights put on!
So far I'm in love with these headlights!!
DSC_0107 by Jarumie42172, on Flickr
DSC_0119 by Jarumie42172, on Flickr
DSC_0136 by Jarumie42172, on Flickr
DSC_0125 by Jarumie42172, on Flickr
DSC_0122 by Jarumie42172, on Flickr
Old 04-19-2014, 03:24 PM   #10
ecko04
Seems Legit
ecko04's Avatar
Drives: Toyota
Stolen pic from @FRSTRM
Old 04-19-2014, 04:06 PM   #11
Wyattkb
Drives: 2014 Whiteout FRS
So do these look that purple in person? Or is it more of a white glow?
Wyattkb is offline   Reply With Quote
Old 04-19-2014, 04:41 PM   #12
FRSTRM
Baby LFA
FRSTRM's Avatar
Drives: Baby LFA
FRSTRM is offline   Reply With Quote
Old 07-18-2014, 02:04 AM   #13
aznknightz17
Drives: Vroom Vroom
Kinda need help with this guys, please bare with me. I got the headlights same time as you all but now i just had the chance to installed it on Wed. Long story short got the HID H1 in and after couple mins of messing with the washer, i got it to fit. The long "rod" was upward and the bulb itself on on the bottom if you know what I mean. The output and coverage was quite disappointing, please check and see. Is that what you guys are getting also?
As you can see since the "rod" is above the actual bulb, there is a reflection of it on the wall and also on the ground. Hard to miss it. Should I go get D2S instead?
aznknightz17 is offline   Reply With Quote
Old 07-18-2014, 04:51 AM   #14
Chen
Regional Moderator
Chen's Avatar
Drives: 00-AP1 20-A90 06-Z33 07-FA5 93-NA1
The rods are supposed to be at the 6 o clock possession.
Chen is offline   Reply With Quote
Springs! Post your Pics!! stevohl Suspension | Chassis | Brakes -- Sponsored by 949 Racing 113 11-10-2016 02:30 PM
Cat/Car pics, post yours :) ZionsWrath Other Vehicles & General Automotive Discussions 18 08-10-2014 11:26 AM
Post your winter pics kidgogeta Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 13 12-16-2013 01:52 PM
Raven Only! Post Pics! imlevinit FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 1 07-06-2012 07:41 PM
