Old 04-17-2014, 02:17 AM   #631
Td-d
Garden variety obsessive
Drives: 2009 Sti Hatch; 2015 Audi RSQ3
Originally Posted by qoncept View Post
merchgod wrote Learning View and he works for Cobb now.
Dale has incorporated Learning View capability into Romraider now - but it's not yet set up for the BRZ.
Td-d is offline   Reply With Quote
The Following 3 Users Say Thank You to Td-d For This Useful Post:
Sportsguy83 (04-17-2014), steve99 (04-17-2014), Wepeel (04-17-2014)
Old 04-17-2014, 12:06 PM   #632
D-VO
Drives: Whiteout FR-S, Evo 8 RS
Is there a reason the AVCS tables in ECUflash for B01C are incomplete? I attempted to attach the addresses found in RR. And this is what I ended up with:
The represented numbers are about 40 units higher than the units in RR. Does this seem correct?
D-VO is offline   Reply With Quote
Old 04-17-2014, 12:44 PM   #633
Td-d
I'm not sure why you're trying to put them in - they are already there, but in the BRZ Alpha section.
Make sure you are running the correct 32BITBASE - as I mentioned elsewhere, I had to move the Alpha 32bitbase.xml that has all the new BRZ tables into a seperate branch, as it was causing issues for Merp with respect to his MerpMod project.
Use this one: https://raw.githubusercontent.com/TD.../32BITBASE.xml
The Following User Says Thank You to Td-d For This Useful Post:
D-VO (04-17-2014)
Old 04-17-2014, 03:18 PM   #634
D-VO
Apologies, I got confused as to which program was being discussed. It's still not showing a BRZ Alpha section. It shows up in the Misc section but the tables are still greyed out.
Old 04-17-2014, 04:29 PM   #635
Td-d
^ That means it's not reading the 32bitbase.xml correctly - or not reading the right one. Check in the log text to the right whether it's actually reading the 32bitbase.xml that you have replaced.
Old 04-17-2014, 11:31 PM   #636
D-VO
Thanks a lot! I was trying to keep two versions of ECUFlash and it was pulling the 32bitbase from the original.
Old 04-18-2014, 06:25 AM   #637
Td-d
Ok, great - so you're sorted?
Sent from my iPad using Tapatalk HD
D-VO (04-18-2014)
Old 04-18-2014, 03:22 PM   #638
regal
Drives: Scion FR-S/Toyota Yaris
Originally Posted by Td-d View Post
Well - Ecuflash link for latest beta is above.
Rom is here: https://dl.dropboxusercontent.com/u/...13ZA1JB01C.hex.
Tactrix OP2 can be purchased here: http://www.tactrix.com/index.php?opt...id=6&Itemid=53
Then open the rom in Ecuflash, connect laptop to OP2 which is connected to OBD2 port, and flash. Done.
The hex file rom isn't being read (matching) or finding the GitHub defs file.
2013 FRS Argento Silver 6MT
Mods:
Clear fender side lights
Tactrix ZA1JB01C 2014 Calib
regal is offline   Reply With Quote
Old 04-18-2014, 03:54 PM   #639
Td-d
Ok, step by step.
You have the rom file above, correct?
You have this definition file? https://raw.githubusercontent.com/TD...Z/ZA1JB01C.xml (right click to save as the xml)
You have this 32bitbase? https://raw.githubusercontent.com/TD.../32BITBASE.xml
Old 04-18-2014, 03:55 PM   #640
Td-d
Also post up a screen grab of the log that Ecuflash gives on the right hand side when it boots up.
Old 04-18-2014, 04:02 PM   #641
regal
I got it to work. IE11 and GitHub don't play nice, luckily I have Chrome.
Also it is important to know that one cannot start from the beta ecuflash. You must install the latest (non beta) version first to get the drivers and firmware then install the beta.
Thanks everyone I finally have an up to date 2014 calib in my 2 year old FRS!
Mods:
Old 04-18-2014, 04:12 PM   #642
Td-d
Great, glad you got it sorted.
Old 04-18-2014, 04:16 PM   #643
regal
And thankyou for posting all the useful info and files. My dealer refused to update my ZA1JA00C calib for over a year. Who needs em
Mods:
Old 04-23-2014, 04:50 PM   #644
Td-d
Someone want to do some tests for me? Trying to check an address for Fueling Mode (PI, DI, Both).
for A01C, can you log 0xFFF8BD33 as an 8bit, and see if it correlates to what would likely be fueling mode (1,2, or 3).
Close iJason Member's Car Journals 1 08-04-2013 08:26 PM
Close pche Engine, Exhaust, Bolt-Ons 3 08-04-2013 02:04 AM
Sorry. please close. finch1750 Scion FR-S / Toyota 86 GT86 General Forum 1 07-31-2013 01:00 AM
please close abutterman Wheels and Tires 0 07-05-2013 09:40 AM
