Old 03-20-2014, 09:17 AM   #43
FRSure
Drives: Toyota
Zz. This is so ridiculous. Its been 3 days , and still diagnosing my car. Apparently the Toyota service technician can't figure out wtf is wrong.. -_- they even call him the "master technician"
FRSure is offline   Reply With Quote
Old 03-20-2014, 09:49 AM   #44
Imrac
Drives: 13 SWP BRZ Prem
Not sure why it would be so hard to diagnose the solenoid.
Steps: Press the brake while in park. You should hear the click of the Solenoid. If you do, then there is something wrong with the linkage that moves the lockout.
If no click, then go to the solenoid and disconnect the wire and put a voltage meter and press the brake, you should get voltage if the wiring is intact. If you get voltage, the solenoid is damaged.
You can test solenoid by applying the appropriate voltage (probably 12v)
If no voltage, you have a wiring problem.
Shouldn't be that complicated...
JDL UEL Headers, Nameless Res&Cat Over&Front, Invidia Q300 Catback, AVO Dry Panel Filter, Custom ECUTek Tune by DriftOffice
191WHP/151 ft-lb on 92
Imrac is offline   Reply With Quote
The Following 2 Users Say Thank You to Imrac For This Useful Post:
AznBRZer (03-20-2014), FRSure (03-20-2014)
Old 03-20-2014, 11:00 AM   #45
FRSure
Drives: Toyota
Not sure why it is taking so long. I called them. They just told me they are doing their best to diagnose a problem. The reason it takes so long is because they want to 100% diagnose the problem and it won't happen again. The same BS every Toyota services give you.
I told them about this and they just told me we'll make a note. Because I'm not the technician , I can't do anything about it... BS
Old 03-20-2014, 11:02 AM   #46
OrbitalEllipses
Drives: Attitude
Check your clutch fluid. You can refill using DOT4 brake fluid!
Old 03-20-2014, 11:05 AM   #47
FRSure
Drives: Toyota
Its a auto...
Old 03-20-2014, 11:11 AM   #48
AznBRZer
Drives: 16 CBS WRX Limited
Its a joke...
AznBRZer is offline   Reply With Quote
Old 03-20-2014, 11:14 AM   #49
FRSure
Drives: Toyota
Man. Toyota Service really likes to take their sweet ass time to diagnose a simple problem like this one...
Old 03-20-2014, 05:52 PM   #50
FRSure
Drives: Toyota
Ok. Update..
AFter 3 days of diagnosing... Those monkeys at the toyota service finally said
"Heyyy! Maybe the fuse blown!!"
And that was the problem. smh
The Following User Says Thank You to FRSure For This Useful Post:
Ramster (03-20-2014)
Old 03-20-2014, 06:29 PM   #51
N1rve
N1rve's Avatar
Drives: 2019 BMW ///M4
Originally Posted by FRSure View Post
Ok. Update..
Didn't someone suggest this? LOL
N1rve
Old 03-20-2014, 07:26 PM   #52
FRSure
Drives: Toyota
I told them.. They told me they already inspect it... And nothing was wrong..
I called them and ask them to recheck everything... Magically they found the issue.
And the cost?
$ 362.89
Paid by insurance, not me. whew
Old 03-20-2014, 11:28 PM   #53
LavosTRD
Toyota Master Tech
Drives: Whiteout MT
Ok. Update..
LavosTRD is offline   Reply With Quote
Old 04-18-2014, 03:29 PM   #54
sprintertrueno86
sprintertrueno86's Avatar
Drives: 2018 BMW M2
And the cost?
$ 362.89
sprintertrueno86 is offline   Reply With Quote
Old 04-18-2014, 03:30 PM   #55
FRSure
Drives: Toyota
Yes. $362.89 for a $1 fuse in the fuse department.
Old 04-18-2014, 04:58 PM   #56
N1rve
N1rve's Avatar
There's a fuse department? They have a department that only sell fuses!?
N1rve
shifting from 1st to 2nd jarviz Scion FR-S / Toyota 86 GT86 General Forum 35 05-26-2016 07:15 PM
Automatic Transmission Kick/Choke when shifting gears Tech Gremlin Engine, Exhaust, Transmission 13 06-16-2015 01:54 AM
MT Shifting n8dog11914 Engine, Exhaust, Transmission 4 08-28-2012 03:28 PM
Paddle shifting automatic downshift FR-YES Scion FR-S / Toyota 86 GT86 General Forum 15 08-06-2012 09:18 AM
shifting and down shifting feel Lowellrenzo Scion FR-S / Toyota 86 GT86 General Forum 23 07-08-2012 05:09 PM
