Drives: 2013 Raven fr-s
should i be worried about small amounts of knock?
I live in florida, the land of the flat...Every once in a while when i am not paying attention and i go up a really steep drive, or try and make a u turn on a steep driveway and just give it a lithe gas i have noticed a little knock
. I have only noticed this twice thank goodness. Do i need to be worried about the affect of that? This isn't something that happens often. I guess sometimes i just forget I have no torque since i drove a mustang for so long...
#2 |
Drives: 2013 asphalt scion FRS
Is it knock, or is it the LSD kicking in? From what your describing, sounds more like your LSD...
2013 raven frs(dd/grocery getter)
1990 mitsu eclipse gsx(street/strip car) 1995 gmc 1500 4x4(off road toy) 2005 Yamaha yz250f |
#3 |
If it is indeed knock then yes worry away
#4 |
Drives: FRS
this.
#5 |
So elite I'm 1338
Drives: WRB Subaru BRZ
Nah. If you are worried about Knocks, just ask them if they are or not.
| The Following User Says Thank You to tahdizzle For This Useful Post: | PEWPEW (04-18-2014) |
#6 |
Drives: '13 FRS
So, you think you hear it? Or are you logging it?
Those don't sound like scenarios that will produce knock. Brief acceleration just doesn't heat anything enough to cause problems from what I've seen. It's WOT pulls through long gears like 3rd or higher that can produce real knock and break parts.
'13 Asphalt FR-S // 6 spd, 3M bra, BeSpoke, Sportsguy83 arm rest, YoSpeed sills & plaque, P3Cars Vent Gauge +oil P sensor; on shelf: SRP pedals
'93 Pearl White 3000GT VR-4 // 5 spd, stock block & 30+ psi: 10.5@135 |
| The Following User Says Thank You to frsvr4 For This Useful Post: | JohnJuan (04-21-2014) |
#7 |
It is not the LSD, trust me I know what that feels like and sounds like...
Have any of you never let the clutch out either too slowly or too quickly with the car at a really low RPM and had it shutter and make a knocking noise? I know what knocking sounds like as I have had several bikes and cars do it in the past... |
#8 | |
| The Following User Says Thank You to J_kennington For This Useful Post: | JohnJuan (04-21-2014) |
#9 |
so you are saying the knock knock knock sound i have heard twice when trying to start from a dead stop up a steep hill with probably too much clutch and not enough throttle is not knock? It doesn't sound any different then my buell trying to take off from a dead stop in traffic with too little throttle and not enough clutch...
#10 |
So, what your saying is your dumping the clutch without the proper throttle to back it up, thereby starving the motor fuel and almost stalling the car? In that case, yes I would be concerned and learn to properly operate a manual transmission for personal safety reasons...
Either way, stalling a car is not true knock. And all you may do is burn the clutch due to improper use.
#11 |
thats right I just don't know how to drive a manual...I have driven a manual for longer then many members on this forum have been driving cars.
#12 |
You didn't answer the question. Are you nearly stalling the car? I'm guessing that's what you meant by "to much clutch, to little throttle". So, is that correct? Are we talking 800rpms or 200rpms when this "knock" happens?
#13 |
Not near stalling, thats why I am thinking it is mild knocking. Although, no CEL. I am probably being paranoid, but with the DI seal failures some people have seen I am always slightly worried. I haven't seen too many threads related to that lately, which is probably a good sign.
#14 |
Grip>Drift
Drives: FRS
Quit almost stalling your car and this problem will quit happening.
| The Following User Says Thank You to BlaineWasHere For This Useful Post: | extrashaky (04-18-2014) |
| Knock Correction vs Knock Correction Learn values? | swift996 | Software Tuning | 19 | 11-03-2015 10:09 PM |
| Dream car at 85... | paros28 | Other Vehicles & General Automotive Discussions | 4 | 09-09-2014 01:23 PM |
| Should I be worried ? | Brooklyn | BRZ First-Gen (2012+) — General Topics | 8 | 03-12-2014 12:18 PM |
| No CEL Should I be worried?? | Mr.Jay | Issues | Warranty | Recalls / TSB | 5 | 04-05-2013 10:51 AM |
| a bit worried | MontrealFRS | Issues | Warranty | Recalls / TSB | 7 | 09-14-2012 06:46 PM |
