Old 03-06-2014, 08:19 AM   #15
Fresh86
Fresh86's Avatar
Drives: 2013 Scion FRS
This build is amazing! and those rims...oufff... and btw do you ever get in trouble for the tinted yellow head lights? I just purchased the tint but I have a feeling im going to get pulled over alot for it :P
Fresh86 is offline   Reply With Quote
The Following User Says Thank You to Fresh86 For This Useful Post:
kybrz (03-16-2014)
Old 03-16-2014, 03:39 PM   #16
kybrz
Drives: SWP Brz
I haven't gotten hassled yet! I haven't driven the car too much lately though but once this is done it will be driven everyday so hopefully they leave me alone!
kybrz is offline   Reply With Quote
The Following User Says Thank You to kybrz For This Useful Post:
Fresh86 (03-16-2014)
Old 03-16-2014, 03:41 PM   #17
kybrz
Drives: SWP Brz
Updated second post with some pics.
Old 03-31-2014, 11:14 AM   #18
kybrz
Drives: SWP Brz
Little teaser shot of the kit getting put on.
Old 04-03-2014, 06:25 PM   #19
kybrz
Drives: SWP Brz
Ready for paint!
Old 04-17-2014, 02:14 PM   #20
ntaphse
Drives: beater
@kybrz So with the rear fenders trimmed and welded like that does the tire clear with the Air Lift kit aired all the way out? I'm looking to do this to my car soon and hoping I don't have to move any more metal than that.
Did you trim anything other than the outer fender skin in the front?
Thanks!
ntaphse is offline   Reply With Quote
Old 04-17-2014, 02:17 PM   #21
ntaphse
Drives: beater
Originally Posted by kybrz View Post
What's going on in this pic? Did you start to weld then decide to cut higher?
Old 04-18-2014, 10:50 AM   #22
kybrz
Drives: SWP Brz
Thanks!
Yup, I had to make a second cut like you see in the picture above, the first time i didn't cut high enough so I remeasured and re cut that is why it looks goofy. But I can air completely out and still have about an inch of clearance from the body to the tire. Note I measured that with a 18x10.5 -7 with a 275/35 tire and I clear as far as the front, I had to bash in part of the frame rail as my tire would rub on it. Other than that I didn't have to trim anything else in the front. As of right now. I don't have my wheels and tires on it right now, I have a temp set which are similar in size, but for now nothing else needed to be trimmed.
FloridaBRZ (05-13-2014)
Old 04-18-2014, 11:34 AM   #23
ntaphse
Drives: beater
Awesome, thanks so much for the info. It should save me some time figuring things out when I go to do mine. One more question, did you have any trouble with warping when you fully welded the fender? I might just tack mine and use seam sealer to keep the heat out of the panel.
Old 04-22-2014, 12:20 PM   #24
kybrz
Drives: SWP Brz
I didn't have too much of an issue with it. I didn't see much of any warping.
Old 04-22-2014, 12:26 PM   #25
kybrz
Drives: SWP Brz
Here is a quick little shoot of everything on, They are temporary wheels The rear is not nearly aggressive enough.
All picture credit goes to Justin Smith.
leicaboss (04-22-2014)
Old 05-13-2014, 12:29 PM   #26
kybrz
Drives: SWP Brz
Couple photos snapped. Car isn't quite where I want it to sit, but getting there!
RallySport Direct Eat, Greet, Car Meet 2014 by Michael "Pumpkyn" Nielsen, on Flickr
ML (05-13-2014)
Old 05-13-2014, 12:31 PM   #27
alpine
Not what you think
alpine's Avatar
Drives: 718 GTS 4.0
I follow you on instagram! Glad I found you on here to see some hi-res pictures
alpine is offline   Reply With Quote
Old 05-13-2014, 01:19 PM   #28
ML
ML's Avatar
Drives: 13 White MT FR-S
what happened to the splitter?
Beginner STX Build Whiteout FRS Build Thread Hachi86Roku Tracking / Autocross / HPDE / Drifting 21 03-31-2020 07:52 PM
PC Build Thread WingsofWar Off-Topic Lounge [WARNING: NO POLITICS] 126 01-22-2017 09:59 PM
YDNA's build thread YDNA Member's Car Journals 58 12-31-2014 03:06 PM
The OTHER Stranoparts STX FR-S - build thread apexaddict Tracking / Autocross / HPDE / Drifting 99 11-27-2013 12:42 PM
EOJ (Not much of a Build) Thread jonbatz01 Member's Car Journals 41 07-31-2013 07:34 PM
