Old 04-03-2014, 12:58 PM   #981
andrew20195
Drives: 2013 Subaru BRZ
Originally Posted by ptuning View Post
I think you may be thinking about EVO X ROM tuning. That car uses both methods for load blend calculations straight from the factory. Other cars use the MAP sensor for things like boost control and boost cut (factory turbo Subarus), for EVAP purging, and for limp mode conditions when the MAF sensor dies.
Hmm, I'll have to experiment with that. At Subaru Technical Training the instructor had us doing experiments showing that the ECM ignores MAF and uses MAP to calculate fuel delivery during quick transitions, but that was on an Outback with the FB25. The BRZ may very well be different.
If you are against speed density tuning just because ECUTek is the only company currently offering it...
As I am not ready to jump on the mod train just yet, I have not completely ruled out any tuning solution. I know a well set up speed density tune can be quite good.
And it looks like my other question about MAF scaling was answered in the other thread.
andrew20195 is offline   Reply With Quote
Old 04-03-2014, 01:05 PM   #982
ptuning
ptuning's Avatar
Drives: White FR-S
But yeah, there is nothing wrong with retaining full MAF operation for NA and mildly boosted cars. We use speed density blending mainly to address issues with MAF overrun.
- Toan
ptuning is offline   Reply With Quote
The Following User Says Thank You to ptuning For This Useful Post:
andrew20195 (04-03-2014)
Old 04-03-2014, 01:08 PM   #983
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
I'm not sure I understand this. What do you mean "speed density capability?" From what I understand the factory ECM uses MAF for steady state operation, and switches to speed density for load transitions as is common with many modern vehicles. Are you saying the OFT does not have the ability to modify the VE tables, or are you saying you run 100% Speed Density tunes? If the latter is the case, why have a MAF housing at all?
The OEM ECU definitely utilizes the MAP sensor. It wouldn't be there if it wasn't being utilized. The OFT has the ability to modify any of the OEM tables. What it doesn't have is the ability to create custom tables that based off of sensor inputs such as the MAP sensor make changes to the OEM tables allowing the car to run off a pure speed density map when certain conditions are met unlike what the OEM ECU does. I don't think anyone is running a 100% speed density tune at this point. Most are now going to a hybrid that transitions to speed density when the MAF voltage gets near maxing out.
Old 04-14-2014, 04:43 AM   #984
mikepaul21
mikepaul21's Avatar
Any more pictures of the optional oil cooler, I saw a picture of where the lines went but couldn't really see the oil cooler too much.
mikepaul21 is offline   Reply With Quote
Old 04-15-2014, 12:46 AM   #985
ptuning
ptuning's Avatar
Drives: White FR-S
We will post more pics of our oil/water oil cooler system once we have the production pieces completed.
The Following 2 Users Say Thank You to ptuning For This Useful Post:
mikepaul21 (04-15-2014), mnsayer (04-15-2014)
Old 04-17-2014, 03:52 PM   #986
csworldfan
Does this kit fit on an aftermarket header?
csworldfan is offline   Reply With Quote
Old 04-17-2014, 03:54 PM   #987
mkivsoopra
Yes. I'm using the JDL UEL header with mine.
mkivsoopra is offline   Reply With Quote
The Following User Says Thank You to mkivsoopra For This Useful Post:
csworldfan (04-17-2014)
Old 04-17-2014, 03:55 PM   #988
AllDayJonRay
Drives: 2013 Ultramarine FR-S
As long as the aftermarket header keeps the connection to the overpipe in the factory location, yes.
'13 Ultramarine 6MT FR-S || K&N Drop-In, SpeedFactory V1 Cat-Back || Moto-East tuned
Join the 86 Owners Clan on Clash of Clans: "86 Owners" Password: "fa20" || Help us take over the world || Thread
AllDayJonRay is offline   Reply With Quote
The Following User Says Thank You to AllDayJonRay For This Useful Post:
Old 04-17-2014, 04:24 PM   #989
csworldfan
What about front sway bars? Does this work with aftermarket sway bars?
Old 04-17-2014, 04:51 PM   #990
kanundrum
Drives: 2013 Whiteout FR-S
No you would need to use their front sway bar which comes with every kit
The Following User Says Thank You to kanundrum For This Useful Post:
Old 04-17-2014, 06:04 PM   #991
csworldfan
Thanks for the information guys, it's much appreciated. Time to start saving some dough :P.
One more question; Would a bigger intercooler benefit this kit? Seems a little small for gtx3076r.
Old 04-17-2014, 06:33 PM   #992
AllDayJonRay
They selected that size intercooler because [I believe] its the largest size that the stock bumper/crash beam cannot accommodate, without cutting things.
And you likely won't have any issues with heat-soak with this intercooler and this turbo running ~10psi. The GTX3076R is gonna be blowing relatively cool at this output level. It will probably take long sessions of track abuse in high heat to heat-soak this intercooler on this setup.
ptuning (04-18-2014)
Old 04-17-2014, 08:42 PM   #993
csworldfan
I'm moving to the sacramento valley, so heatsoak is something I'm definitely worried about. I also will be tracking the car, so that just compounds the issue. Current plan is ~16 psi on e85. I wonder if they would sell me the kit without the intercooler.
Old 04-17-2014, 08:48 PM   #994
AllDayJonRay
Yea, you're ticking off all the factors that would increase your chances of heatsoak.
But understand that the bumper inlet doesn't really allow for airflow for a larger core, without modification, and in order to fit a larger core you're going to have to modify your crash beam and/or bumper.
The Following 2 Users Say Thank You to AllDayJonRay For This Useful Post:
csworldfan (04-17-2014), MooKz (04-17-2014)
over 9000, ptuning, turbo kit
FA20CLUB.com Turbo Kit Sneak Peek.... FA20Club.com Forced Induction 98 12-14-2013 02:34 PM
Sneak peek at new 57Xtreme? vividracing Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 11 02-07-2013 03:24 PM
Sneak Peek! P&L Motorsports Stg.1 BRZ/FRS Turbo Kit. P&L Motorsports Forced Induction 179 01-31-2013 08:32 PM
AFE PROTOTYPE EXHAUST: SNEAK PEEK! autofashionfred Engine, Exhaust, Transmission 20 08-13-2012 02:22 PM
Tsukuba Circuit BRZ/FRS showdown Sneak Peek AVOturboworld BRZ First-Gen (2012+) — General Topics 19 06-23-2012 12:13 PM
