Old 04-14-2014, 08:15 PM   #1331
Reaper
in orbe terrum non visi
Reaper's Avatar
Drives: violent
I dont know what book time is but I did mine on the monster in 40 minutes. In fact if I cant borrow a trailer again ill just swap my injectors in the parkinglot next to my tuners shop and play it off like I trailered it there again like a boss.
Sent from my SAMSUNG-SGH-I747 using Tapatalk
Old 04-14-2014, 08:17 PM   #1332
Dipstik-sportech
Dipstik-sportech's Avatar
115$ per hour I guess lol
The Frozen North
Old 04-14-2014, 09:42 PM   #1333
Infamous Performance
Infamous Performance's Avatar
Drives: 02 WRX, 05 LGT, 08 LGT, 08 SpecB
Why do you charge $335 when it is a 1 to 2 hour job max?
Because we take up to 4 hours to swap them. We do not "rush" work and we follow all install procedures. We individually test operation of each injector prior to install, we clean the manifold seats as well as the rail, we replace all o-rings and seals (and grease them), we pressure test prior to start up, we replace the blast shields, etc. There is a lot of liability involved in changing fuel related components. Anyone seen a car-b-q? $335 is our standard shop rate for top feed injector installs on EJ255's and 257's so we kept it for FRS/BRZ. Real question is how do we get customers to pay $450 like Mann?
Infamous Performance is offline   Reply With Quote
Old 04-14-2014, 09:52 PM   #1334
Dipstik-sportech
I did all of that when I installed mine short of testing each injector, didn't take 4hrs
The Frozen North
Old 04-15-2014, 05:33 PM   #1335
Its a standard shop rate for us. No one said it was by the hour, I said we can take up to 4 hours. We do not perform work per "book" as ther is no "book rate" for much of what we do.
We are obviously charging too little if Mann is getting $450.
Old 04-15-2014, 06:02 PM   #1336
dabocx
dabocx's Avatar
Drives: Scion FRS
I miss my car
Wheel stud broke today so now im waiting on parts.
dabocx is offline   Reply With Quote
Old 04-15-2014, 06:05 PM   #1337
SmsAlSuwaidi
Boosted
SmsAlSuwaidi's Avatar
Drives: Not a supra....yet
Originally Posted by dabocx View Post
I miss my car
Well, if one stud breaks you can still drive it
Old 04-17-2014, 03:03 PM   #1338
DeliciousTuning
PhoneFlash by EcuTeK
DeliciousTuning's Avatar
Originally Posted by pmccut View Post
Absolutely! I'm not directing the injector issue at Bill at all. All of the tunes I've had on the larger injectors (while the car was functioning ok to my knowledge) have been harsh. They'd start on the first attempt on 91, but have a very rough idle until switching to DI. I'm booked for the 25th with Bill @ Mann to tune with the stock injectors. Mann wants $450 to swap the fuel injectors to stock, so I'm going to bug Bill for a map so I can swap the injectors myself before going to Mann.
Keep bugging. I am finally starting to get myself into my new facility and will start getting updates out to everyone.
As for the injectors, we have been able to get a perfect idle, perfect acceleration, blips and basically perfect function out of larger injectors even on pure speed density but the only problem we currently have is the harsh start which I am still working on correcting. I believe it to be related to just too much fuel as jamesm has eluded to, as the same exact tune on OEM injectors start perfect every time. Makes me think it is an enrichment and low RPM low load mapping error on startup. But we are still working that out.
We did tune a Full Blown kit yesterday with Bosch EV14 1000cc injectors and have to say I prefer these over everything else so far. A very clean and crisp response from these injectors. Makes tuning a little easier and I would expect nothing less from Bosch. Definitely recommended if going larger injectors.
Cheers,
William Knose
Old 04-17-2014, 03:05 PM   #1339
DeliciousTuning
FYI, we are hoping to get going on your car today. Now that the small updates have been addressed on your prototype MAP Turbo kit we will get to spend a little time on it today.
Cheers,
William Knose
The Following User Says Thank You to DeliciousTuning For This Useful Post:
SmsAlSuwaidi (04-17-2014)
Old 04-17-2014, 06:06 PM   #1340
pmccut
Drives: Blue Subarus
Cheers,
William Knose
How harsh was the start on the car (with a working o2 sensor )? No pumping the gas to get it running right?
I'm still having mixed feelings about going back to stock injectors. Besides the cost of swapping, I don't want to tune the car to near 100% PI duty cycle and not hit my goals of around 400whp on 91.
'13 GBS BRZ 6MT | FBM 9:1 w/ GTX3076R| FBM oil cooler + catch-can + radiator + SPAL fans| Rays 57xtreme / PSS | Perrin 2.5" FP | Invidia 2.5" OP | Perrin 3" CBE | RCE T2s | Exedy Stg1
'15 STI LE | Cobb Stg1
pmccut is offline   Reply With Quote
Old 04-17-2014, 06:13 PM   #1341
mashal
DADA
mashal's Avatar
Drives: 2013
Jesus Christ, 400 on 91 ::drool
mashal is offline   Reply With Quote
Old 04-17-2014, 06:14 PM   #1342
SmsAlSuwaidi
Boosted
Fbm did 425 on Canadian 91 which is like 89 + maple syrup mixed in (instead of 10% ethanol )
Sent from my IBrick
The Following 2 Users Say Thank You to SmsAlSuwaidi For This Useful Post:
blackfireball5 (04-17-2014), Dipstik-sportech (04-17-2014)
Old 04-17-2014, 06:17 PM   #1343
pmccut
PTE turbo, not sure how its size compares to the GTX3076R. It was 353 on a GT2871R, so I assume the bigger turbo can get me around 400 (dynojet)
Old 04-17-2014, 06:17 PM   #1344
SmsAlSuwaidi
Boosted
@Dipstik-sportech
Sent from my IBrick
best company ever, big fuck off turbo, blown, bow chicka wow wow, fbm, full, owners, powaaaaaa!, thread, will work for turbo
AVO Turbo Kit Owners Topic Sportsguy83 Forced Induction 1935 02-20-2023 10:46 AM
Full Blown FRS/BRZ Stage 1 Turbo Kit FullBlown Forced Induction 456 09-27-2021 03:10 AM
FA20Club Turbo Kit Owners Topic pixel67 Forced Induction 1531 09-09-2014 12:36 PM
Full Blown Turbo Kit! Unleashed Engine, Exhaust, Bolt-Ons 70 10-09-2013 09:46 AM
WTB: Full Blown turbo kit (used) whitefrs Engine, Exhaust, Bolt-Ons 12 03-29-2013 09:15 PM
