| Southern California SoCal |
Drives: 2020 BRZ PP CWP
Alignment / Corner Balance
Hey folks.
I had a few questions since I'm not so knowledgable about suspension. I am going to have my ST coilovers installed this weekend. The next step would be to have an alignment / Corner Balance. I've read that it's important to have a CB done before an alignment. I'd like to know if this is true? Also, I'm still on stock tires / wheels. I'm waiting for my wheels to become available, which might takes some weeks, even past a month. If I were to get an alignment, or corner balance (or both) and then later change out my wheels and tires, My question is, would I have to have my alignment / CB to be re-done again? Also, the specs on the wheels I'll be getting are 18x8.0 5x100 +40 offset if that helps with anything. Thanks for your input.
#2 |
Drives: FRS
get the corner balancing done after you swap out wheels. waste of money imo to get it on stock wheels/tires unless your race setup is to use stock wheels/tires and you are anal about your car's specifications for the races.
| The Following User Says Thank You to 8R6 For This Useful Post: | mystic (04-17-2014) |
#3 |
Stealth
Drives: Ultramarine FR-S
Coilovers need to settle anyway.
| The Following User Says Thank You to ApolloSki For This Useful Post: | mystic (04-17-2014) |
#4 | |
#5 |
Stealth
#6 | |
Something like this http://tougefactory.com/shop/wp-cont...PoomeFRS_6.jpg |
#7 | |
Stealth
#8 | |
Drives: FRS
#9 | |
| AZP Spring Alignment/Corner Balance Special March 15-April 15 | AZP Installs | Brakes, Suspension, Chassis | 2 | 03-07-2014 05:08 PM |
| AZP Spring Alignment/Corner Balance Special March 15-April 15 | AZP Installs | NY / NJ / CT / PA | 1 | 03-07-2014 10:43 AM |
| AZP Spring Alignment/Corner Balance Special March 15-April 15 | AZP Installs | Coating and Customization Services | 0 | 03-07-2014 08:49 AM |
| Closed | Figo | NY / NJ / CT / PA | 1 | 10-11-2013 04:53 PM |
| corner balance in bay area | garfull | Northern California | 10 | 06-24-2013 10:16 AM |
