Old 02-09-2014, 05:15 AM   #267
Bongertz
Drives: Brz
Sorry for reviving this thread but, sound wise. is it worth the extra 100 bucks to get the 3" perrin catback?
Bongertz is offline   Reply With Quote
Old 02-09-2014, 09:40 AM   #268
s14sleepyeyez
Drives: 2013 Argento Scion FR-S
If you are going down a FI route later on then yes. Or perhaps looking for an exhaust a tad bit louder than the 2.5". I've got the 2.5" resonated and extremely happy with the quality overall.
s14sleepyeyez is offline   Reply With Quote
Old 04-01-2014, 06:54 PM   #269
Juanito08
Juanito08's Avatar
Drives: Scion Fr-s
Can some one please tell me the length of the resonator? I would really appreciate it. Thanks
Juanito08 is offline   Reply With Quote
Old 04-01-2014, 08:39 PM   #270
Sony
Sony's Avatar
Drives: 2013 Subaru BRZ MT Limited
I wish I had seen this earlier, as I was just under the BRZ installing the Perrin Shifter Bushing and I could have measured it easily.
If you need an approximate and not an exact, the Resonator is about 30" long, it's pretty big compared to others, it's also probably 4" in diameter.
Dark Blue 2020 Subaru Forester Sport, Name: Apollo - God of Music
WRB 2013 Subaru BRZ Limited MT, Name: Zeus - Father of all God's and God of Sky and Thunder
Perrin Cat-Back, ECUTek Tune by Kaizen Tuning, Perrin Silicone Radiator Hoses, Perrin Master Cylinder Brace, Perrin True Cold Air Intake
Sony is offline   Reply With Quote
Old 04-01-2014, 08:44 PM   #271
leicaboss
Coffee Snob
leicaboss's Avatar
Drives: '14 SWP BRZ Limited
I can confirm this!
Good estimation.
leicaboss is offline   Reply With Quote
Old 04-02-2014, 03:22 PM   #272
Juanito08
Juanito08's Avatar
Drives: Scion Fr-s
Originally Posted by leicaboss View Post
I can confirm this!
Good estimation.
Thanks guys!
Old 04-16-2014, 10:10 PM   #273
oldlostcory
oldlostcory's Avatar
Drives: 2013 WRB BRZ Limited
I have a stupid question. How can I tell if I have a leak on one of the clamps? The exhaust is fairly loud between 1-3k rpm. I tightened the vclamps to within a half inch of each of those metal parts. They aren't touching like in the pictures here but I'm worried I'll break them if I tighten them anymore. It is a 2.5 resonated so I dont think it should be this loud. At 4k and above it doesn't sound loud.
oldlostcory is offline   Reply With Quote
Old 04-16-2014, 10:48 PM   #274
RacerX
Drives: Subaru BRZ
When I installed mine I had the car up on 4 jackstands. I let it idle for about 10 minutes while still on the jacks. I crawled underneath the car while it was running and listened/looked for leaks. I could not hear any over the noise of the engine but I could certainly see water and condensation forming around the rearmost V-band clamp. I tightened it up a couple more turns and the drips stopped.
So to look for leaks I would park your car over some cardboard and let it idle for a few minutes or so. If you see and water marks on the cardboard you probably have a leak, at least at idle speeds. Even so I don't think it's an issue if its just a pin-hole leak south of the cat.
RacerX is offline   Reply With Quote
Old 04-16-2014, 10:51 PM   #275
Sony
Sony's Avatar
The ends of the V-Band Clamp should be touching or VERY close to touching...half an inch is an enormous Gap and would definitely be too loose.
The following quote about the clamps is from Chris Perrin himself.
Originally Posted by PERRIN_Chris View Post
The clamp should only be tightened down to 70in lbs. The V band squeezes the pipes together so they shouldn't be leaking exhaust, they might leak a little water when the exhaust is cold though. The pipes shouldn't be able to move independently when they're clamped down.
When the V band is clamped down all the way, both the ends will be touching.
Old 04-16-2014, 11:58 PM   #276
6speed_Sam
Thumper
6speed_Sam's Avatar
Drives: 2013 FRS
I just crawled under the car tonight to check my driveshaft bolts. I believe I saw that my clamps had ~1/4 in gap.
Car is gone - parts for sale
6speed_Sam is offline   Reply With Quote
Old 04-17-2014, 12:16 AM   #277
Xerious
Speed Chaser Thrill Seekr
Xerious's Avatar
Drives: 2014 Asphalt Monogram FR-S 6MT
Did the Perrin guys post the data they promised for the 3" system? I know it's shipping as I just ordered one.
Sent from my SAMSUNG-SM-N900A using Tapatalk
Performance: Jackson Racing SC & Oil Cooler, 18x9.5 Gram Lights 57Xtreme Wheels, 255/35 Yokohoma Tires, Rays Volk Racing Black 17hex 12x1.25 lugs, KW V3 C/O, Stance Control Arms
Exterior: LED DRL MOD Kit, Tom's Tail-lights, 5%/40% tint
My Build
Xerious is offline   Reply With Quote
Old 04-17-2014, 09:40 AM   #278
oldlostcory
You guys were right it did need tightened down more. Although not as tight as I made the one near the muffler, yeah I broke it. Thankfully I managed to find a replacement at the local Advanced auto. Now it sounds like it should. The drone is gone and it is just a bit louder than stock. Thanks again for those that gave me tips.
Old 04-17-2014, 11:58 PM   #279
RacerX
Drives: Subaru BRZ
hmmm... I think I'll crawl under mine and check them. I'm pretty sure they're tight but I don't think mine are touching. I wouldn't have thought that a small leak would cause drone. I'm not so sure about that.
Old 04-18-2014, 02:12 PM   #280
PERRIN_Chris
Drives: 2014 Subaru BRZ
Send a message via AIM to PERRIN_Chris
Sorry guys, I'm not sure why I said that, actually the V band end should not be touching, there should be a gap, about even with the gaps around the V band, but most important, 70 in lbs, not ft lbs!
PERRIN_Chris is offline   Reply With Quote
Perrin Catback Exhaust vs Nameless Performance Exhaust. vignesh Engine, Exhaust, Transmission 201 06-05-2013 09:47 PM
NEW! Perrin SS Catback Exhaust System Up to +9rwhp | In-Stock| FREE S&H! AJ@ECSMotorsports Engine, Exhaust, Bolt-Ons 31 04-06-2013 09:05 AM
Review of ISIS Street Catback exhaust sirhc Engine, Exhaust, Transmission 24 10-29-2012 04:57 AM
