#645 | |
Drives: First SWP BRZ-L
Epic. Can I run the 5w20 this track event and switch later, or is the 5w20 a no-go? Planning on running the BMW HPDE May 16th.
First white BRZ in the country
![]() Limited SWP BRZ, 35% tint, clear bra, Nameless Performance downpipe, axelback, headers |
#646 | |
I can only imagine what would have happened without traction control when, on my second day of my first track event, I touched the brakes at the top of turn one at Laguna Seca (basically a panic reflex at seeing the normal line without lifting through the straight (also in my car (civic si) before the BRZ)). That moment when the car got squirrely I knew I was just along for the ride. The traction control got the car stabilized and nothing bad happened but I learned a very major lesson about weight transfer at speed which could have been a very, very expensive lesson without it. going sideways at 95 MPH would not have been fun. Also, I didn't even realize that the track had those dynamics until I saw it at that speed. By all means turn off the traction control once the tunnel vision is gone and you've experienced a few hiccups (and be aware that the amazingly well put together car saved your freshman ass), but don't add more distractions to an already hostile alien environment. I've seen the looks of a driver after they mangled the side of their car on a tire wall in the beginner group; it is better to take a little longer to learn and not go through that than to rush things and go home with your car merely a reflection of its prior glory. It is a fantastic thing that we have cars as forgiving as we do in order to learn with. |
#647 | ||
Drives: Used to Drive:Grand-Am GS #54 E36M3
As many clubs remind you in the AM driver's meeting: you want to drive your car home at the end of the day, so watch out for the red mist. Quote:
I think we should assume that in the case of an on-track incident with another car, each driver is going to be responsible for his or her own repairs. Unless I've done something totally irresponsible, I'm not chipping in to fix a GT3 or any Ferrari. It is worth noting that these incidents are exceedingly rare - virtually all of the bent sheet metal at HPDEs is due to driver error, and it takes place in single-car incidents. Cool. If your BMW club runs its HPDEs anything like the clubs in the Northeast (which I very much suspect it will), you'll get adequate to excellent instruction with an emphasis on learning the basics before focusing on how quickly you can lap the circuit. Of all the clubs in the Northeast, BMW club HPDEs are the most buttoned-down, and for a driver's first ten or so days on-track, I think that's a good thing. As an instructor, I am not thrilled to learn that I'm in the car with a novice or intermediate driver who wants to find out what his car can do. Last edited by dradernh; 04-16-2014 at 05:08 PM. |
#648 | |
Also, make sure you have an instructor for the whole day, they are great at pointing out when you start approaching a limit/doing something not good. |
#649 |
If you're doing your first few HDPE days and the instructor lets you get so far into trouble that you hit something, then they failed you miserably or you weren't listening to them.
If you're just going out onto a new track and driving at 8-10 tenths, then its 100% your fault if you get out of shape. You should ALWAYS take a couple laps at like half speed (and a track walk if you can) the first time on a new track, then build speed as you get comfortable with it.
#650 |
Drives: Raven 6MT
Mike,
I really wore out the outsides of my front tires after two days at Texas World Speedway this weekend and the tires only had ~1500 miles on them before it. Temps were in the high 70s to low 80s and I was trying to maintain hot pressure in the tires at 36 PSI. My mods are: ATE brake fluid, ProjectMu Club Racer pads, SS brake lines, Whiteline camber bolts, Kosei K4R 17x8 wheels and Bridgestone S-04 225/45 tires. With only -1.0 degrees of camber in the front, my guess is that I still do not have enough camber and the extra wear is coming from the tires rolling too much to the outside. I would prefer to stay on the stock suspension as long as possible as I find it quite capable for my abilities; so with that said, what are other routes for me to maximize front camber with the stock suspension? I appreciate the help.
Goodridge SS brake lines//ProjectMu 999's//Motul DOT 5.1 brake fluid//GrimmSpeed master cylinder brace//Jackson Racing Oil Cooler//Whiteline camber bolts//Raceseng CamCas plates//Kosei K4R 17x8//BFGoodrich Rivals 225/45
#651 |
Drives: 86
Camber plates would let you dial in more front camber.
Springs would increase static negative camber all around (how much depends on how low you go), with the benefit of lower cg, less roll.. |
#652 |
Drives: 1990 BNR32 GTR
Hi @CSG Mike,
I just got done with my first AutoX and am looking to run racing slicks like the Hoosier A6's. Is there anything like that for cheaper that is 'good enough' for short AutoX runs? My slowest lap of the weekend was a 50.2, and there is quite a bit of cooldown time between each run. (To give you an idea of the application.) With that said, I do plan on attending a drivers weekend at Portland International in the summer, and I'm betting slicks are the way to go for that. So are the Hoosiers what you would buy? Secondly, I already have a Wilwood BBK that fits under the stock rim, is it a better idea to stay at 17"(17x9, proabably as that is the max in my class) to have the most rubber? Can you recommend a AutoX brake pad? I'm on stock supension.
#653 | |
Drives: 2013 SWP BRZ
My feedback on this, for what it is worth - I have run -1.6* camber up front on Pilot Super Sports using camber bolts on stock suspension, and still corded the shoulders. Using OEM tophats with the RCE T2 coilovers, I was at -2.0* camber up front with Nitto NT01s, and am still scrubbing the outside of the tire. I just bought some Ground Control camber plates and aiming for -3.0* or more camber up front to help with the outside shoulder wear.
2013 SWP BRZ Build Thread: http://www.ft86club.com/forums/showthread.php?t=38781 |
#654 | |
Drives: Raven 6MT
Chin ran a pretty good event! I just joined their club and will be using them a lot when I head back east in a few months. They ran every group on time and they had four sessions of 30 mins each for every group (four groups but only three run groups), plus an additional hour of open track at the end of the day and a short warm up session before things began in the morning so I was not wanting for time. They really only provide enough instructors for the novice group, but that seems to be pretty much par with any club and if you find one, they were definitely willing to go with you. They had a good focus on safety and were not over-aggressive with flags. Overall, it was a good time and I would recommend them. I know they have at least one other TWS event scheduled (maybe two), COTA and I believe one at MSR Houston so they are definitely trying their best to get the track time in. Shame TWS is scheduled for demo, I would totally buy it if I could figure that out
#655 |
Drives: Nevermorange FRS
You'll be just fine. Have fun!
PRO86 | WTCC | STL
#656 |
Drives: Some rust bucket
Might be the tire too. The S04 are rated max performance summer. The extreme performance summer tires (RE11A, AD08R, Direzza II) might have stiffer sidewalls.
#657 |
Drives: Raven 6MT
That was another thought I had but the tires were a great buy on TireRack so I had to go with them this time...it'll definitely be more thought out next time, I was just hoping these tires would last a little longer haha
#658 | |
Good tire buy right now at tirerack- the DZ101s in 225/45/17 are $73 a pop. incredible. I'm struggling on impulse buying them for an upgrade over stock for the rest of the year's track days...
| Simple question, hard to find answer... | Mango22 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 5 | 05-16-2013 06:23 PM |
| Silly question about protecting track rims | sw20kosh | Tracking / Autocross / HPDE / Drifting | 16 | 04-25-2013 12:34 PM |
| Asking the question that I already know the answer to. Are the engines the same? | Bigmaxy | Engine, Exhaust, Transmission | 10 | 01-19-2013 07:47 PM |
| Random dog-related question for those who have their BRZ | GMU-BRZ | BRZ First-Gen (2012+) — General Topics | 11 | 05-31-2012 07:48 AM |
| Got my answer - BRZ comes with HID headlights as STD | Z_Rocks | BRZ First-Gen (2012+) — General Topics | 20 | 01-10-2012 09:54 AM |
