Old 04-16-2014, 02:41 PM   #2157
Luis_GT
I need some dark purple wheels...
Old 04-16-2014, 03:12 PM   #2158
jamesm
Fuel Fix??? Splain
Injection limitation in the stock rom. Not much is known about what exactly happens internally within the code to cause it, but suffice to say there is a hard limit that needs to be overcome.
The Following 2 Users Say Thank You to jamesm For This Useful Post:
Luis_GT (04-16-2014), Sportsguy83 (04-16-2014)
Old 04-16-2014, 03:31 PM   #2159
sklimo
You said hard
The Following 3 Users Say Thank You to sklimo For This Useful Post:
ftc~brz (04-17-2014), Luis_GT (04-16-2014), Sportsguy83 (04-16-2014)
Old 04-16-2014, 03:36 PM   #2160
OrbitalEllipses
Drives: Attitude
Socilalites say any kind of attention, good or bad, is GREAT. So there you have it, you got the attention you wanted
Actually that was Oscar Wilde, paraphrased: there's only one thing worse than being talked and that's not being talked about.
Old 04-16-2014, 03:53 PM   #2161
mkivsoopra
Who's tuning his car? What software? Ecutek RaceRom 7 or earlier? Speed Density? E85? What PSI?
How do I determine the version? I think it was the old one.
And yes, Speed Density + E85. 6.2 psi was fine, but 9.2 psi leaned out horribly, according to the Ecutek log (up to 17:1). Can be seen on the dyno chart too, where torque falls off after 6000 RPM. Red = 6.2 psi, Green = 9.2 psi, Blue = NA
mkivsoopra is offline   Reply With Quote
The Following User Says Thank You to mkivsoopra For This Useful Post:
Old 04-16-2014, 04:02 PM   #2162
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Your Access Hollywood of the day provided by Orbz the fellow with degree and superior.
Sent from my SM-N900A using Tapatalk
The Following 2 Users Say Thank You to Sportsguy83 For This Useful Post:
Old 04-16-2014, 04:03 PM   #2163
Sportsguy83
Drives: Limited BRZ
A those PSI your issue should be proper fuel pump install.
The Following User Says Thank You to Sportsguy83 For This Useful Post:
mkivsoopra (04-16-2014)
Old 04-16-2014, 08:21 PM   #2164
whitefrs
Love Boost!!!!!!!!
whitefrs's Avatar
Drives: Whiteout Scion FR-S
and Sportsguy83 is right...
make sure u have the right amount of o rings too...
who's your tuner?
The Following User Says Thank You to whitefrs For This Useful Post:
Old 04-16-2014, 08:50 PM   #2165
mkivsoopra
who's your tuner?
I believe I used the spacer + 2 o-rings, since I followed these instructions: http://www.ft86club.com/forums/showthread.php?t=41770
I guess I'll have to pull out the pump and double check. @DeliciousTuning is my tuner. I've sent him the logs, but he hasn't had a chance to review them yet.
Old 04-16-2014, 09:24 PM   #2166
Sportsguy83
Drives: Limited BRZ
Do you see the fuel pressure drop at the time it goes lean in the logs?
That's clear sign of problem with FP.
Old 04-16-2014, 10:15 PM   #2167
mkivsoopra
Ooh, good point. Let me check that tonight. I'll check the wire routing too. Thanks!
The Following 2 Users Say Thank You to mkivsoopra For This Useful Post:
pmccut (04-17-2014), Sportsguy83 (04-16-2014)
Old 04-17-2014, 03:34 AM   #2168
mkivsoopra
Do you mean the direct injectors' fuel pressure? That one seems to be stable throughout:
Sorry for cluttering your thread... I can start a new one.
Old 04-17-2014, 08:51 AM   #2169
Sportsguy83
Drives: Limited BRZ
No worries man. This thread has gone from build, to chat, to technical, to off topic and back a few times, its all good.
Can you send me the log via email?
Bee aReee Zeeee miami AT gmail dot com
capital letters, follwed by miami (no spaces), gmail service.
mkivsoopra (04-17-2014)
Old 04-17-2014, 01:18 PM   #2170
Sportsguy83
Drives: Limited BRZ
PM me your phone, I have a few general questions.
alpinewuzhere, better than sti, custom turbo kit ftw, epic brz build, ftc~brz, gtx30 goodness, its certainly a car, king tut, nocornnocare, sportsguy83, superior orbital fellow, thewheelsonthebusgo
Volk Racing TE37SL - Mag Blue/ Hyper Blue/ Flat Black/ Red/ Gold IN STOCK!!! Speed Element Wheels and Tires 151 09-26-2013 04:56 PM
Dream Mod For FR-S/BRZ JPxM0Dz Other Vehicles & General Automotive Discussions 22 03-08-2013 10:35 PM
Have You Had A Dream About Your Car? chanomatik Scion FR-S / Toyota 86 GT86 General Forum 7 01-29-2013 02:38 AM
Sonic Blue 86, Galaxy Blue deleted? 450hp/tonne AUSTRALIA 14 09-01-2012 07:10 PM
I had a dream... ashtray Off-Topic Lounge [WARNING: NO POLITICS] 1 03-12-2012 11:35 PM
