Old 04-16-2014, 02:23 PM   #169
xjohnx
Grip>Slip
xjohnx's Avatar
Originally Posted by Deathalo View Post
Lack of XM doesn't bother me too much since I can use Pandora or something, but would love to know about HD radio, makes listening to talk radio or basketball games much better.
No HD radio, however the reception on this head unit is much better than my stock BRZ unit and my previous pioneer units for one reason or another. my local AM sports radio station that I would occasionally have trouble picking up without static comes in crystal clear now.
DC2R (04-16-2014)
Old 04-16-2014, 03:07 PM   #170
DC2R
Drives: 2014 Scion FR-S
Hmm so only thing you would lose coming from stock radio is HD broadcasts. Good thing I never listen to radio as its all shit down here .
Should be pulling trigger on this. Probably tomorrow after meet whether @SHIFTER shows or not
Sent from my SM-N900T using Tapatalk
DC2R is offline   Reply With Quote
Old 04-16-2014, 03:08 PM   #171
\o/
Drives: 2014 WRB BRZ
Okay, so this will sound silly, but one thing I hate about the stock radio is how hard it to to scan the radio, as it lacks hard buttons for this.
Do the skip forward / back hard buttons on this unit seek up / down the radio stations? Or at a minimum to go through the presets?
\o/ is offline   Reply With Quote
Old 04-16-2014, 03:10 PM   #172
xjohnx
Grip>Slip
xjohnx's Avatar
I'll verify on my drive home, but i believe the seek up/down buttons skip through the presets and the knob on the right will allow you to roll through all the frequencies.
Old 04-16-2014, 07:13 PM   #173
xDBOYx
xDBOYx's Avatar
Drives: 2013 SWP BRZ Limited
awesome, great review. ive been looking for something like this
xDBOYx is offline   Reply With Quote
Old 04-16-2014, 09:08 PM   #174
ir1064
Drives: 6MT, C7P
Anywhere that you have accessory power, so either the orange/black wire (which is where it's designed to go), or the red wire should work.
my system is finally complete!!! big thanks to all of you!!!
ir1064 is offline   Reply With Quote
The Following User Says Thank You to ir1064 For This Useful Post:
Prog (04-16-2014)
Old 04-17-2014, 10:36 AM   #175
Deathalo
Drives: 2013 WR Blue Limited Manual BRZ
So, was anyone able to confirm if a backup camera like the Rydeen Duo will plug in and work the same way as on the Stock BRZ HU? Like, does it automatically come on when you put it into reverse?
Deathalo is offline   Reply With Quote
Old 04-17-2014, 09:23 PM   #176
SHIFTER
SHIFTER's Avatar
Drives: Scion FR-S
Yes it will work, triggered by the reverse gear as you would expect. If you have it wired into the stock radio - the only change you will need to make is to unplug the rca from that harness and plug the rca into the back of the actual stereo on the Dashlinq4
Andrew
2013 Scion FR-S MT (Silver)
2011 Toyota Rav4 Sport V6 4wd (Silver)
SHIFTER is offline   Reply With Quote
The Following User Says Thank You to SHIFTER For This Useful Post:
Deathalo (04-18-2014)
Old 04-17-2014, 09:23 PM   #177
SHIFTER
SHIFTER's Avatar
Drives: Scion FR-S
correct
Andrew
Old 04-17-2014, 09:25 PM   #178
SHIFTER
SHIFTER's Avatar
Drives: Scion FR-S
Originally Posted by AtlasMick View Post
So has anyone gotten the rearview working on the unit?
Is the rear USB, USB 2.0 or 3.0, could you hub it into more USB?
Does the OBDII only work through bluetooth or could you get a converter to feed it directly into the USB input?
Does it read flac files off of a flash drive or external hard drive through the USB?
USB2.0
No
It should - install this app http://lifehacker.com/5805924/the-be...on-for-android
No gaurantees on the Flac playback though - but since its android it SHOULD with a correct app that can decode it.
Andrew
Old 04-17-2014, 09:27 PM   #179
SHIFTER
SHIFTER's Avatar
Drives: Scion FR-S
BTW looks like they have the owners/users manual up http://ca-fi.com/web/downloads/
Andrew
Old 04-18-2014, 11:25 AM   #180
xjohnx
Grip>Slip
xjohnx's Avatar
Originally Posted by SHIFTER View Post
correct
Actually i found both the seek button and the knob both did the same thing (scrolled through presets), neither did a "free-tune" where i could scroll through all frequencies. To do that i need to use the touch screen. Maybe I'm missing a button or setting, not that important to me.
Just wanted to report my experiences so that anyone considering it has as much information as possible.
Old 04-18-2014, 12:52 PM   #181
Deathalo
So what exactly does the right knob do that can't be done with seek buttons?
Old 04-18-2014, 01:17 PM   #182
Deathalo
Ok, one more question regarding backup cameras, does this unit have built in guide lines for the backup cameras that you can adjust like the stock HU?
REVIEW: Ca-Fi Toyota Universal - Stock Fitment ANDROID Stereo SHIFTER Electronics | Audio | NAV | Infotainment 16 06-13-2017 06:23 PM
Android, bluetooth, Music, and the FR-S stock pioneer stereo JayNutter Electronics | Audio | NAV | Infotainment 27 12-18-2014 03:54 AM
How to: Torque on an android powered stereo with no hacking v. Ca-Fi Dashlinq4 SHIFTER Electronics | Audio | NAV | Infotainment 29 04-07-2014 04:58 AM
