#3431 |
Track Rat
Drives: '14 Subaru BRZ
The BRZ manual specifies that any fuel containing more than 10% ethanol is not recommended. I know that E85 is readily available in many US states so what do USDM FA20 engines have (or don't have) that enable them to run E85?
CarGuy
'12 BMW 128i (daily driver) '14 Subaru BRZ (track car) Racing is life. Anything before or after is just waiting. - Steve McQueen |
#3432 | |
The golf course is perfect, not a blade of grass out of place. You would never know that a storm rolled through the day before that closed the golf course. |
| The Following User Says Thank You to jvincent For This Useful Post: | Pbrown (04-15-2014) |
#3433 |
Track Rat
OK I did a bit of research on the Web and E85 fuel can be used in a gasoline (E10 max) engine with an E85 tune. There are no ill effects on any part of the fuel system by using E85 in a gasoline optimized car. It is recommended that the fuel filter be changed if the engine has high mileage or if it has deposits. Apparently the ethanol in E85 has a "cleaning" effect on the fuel system and debris can clog the fuel filter.
CarGuy
#3434 | |
Drives: FR-S Firestorm 6MT
#3435 | |
Drives: asphalt 86
| The Following 2 Users Say Thank You to 86gt? For This Useful Post: | CarGuy (04-16-2014), Mike86CelicaGTS (04-16-2014) |
#3436 | |
Drives: 2013 BRZ Sport-tech
Fumoto drain
#3437 | |
Drives: 2014 BR"ZED" Sport-tech DGM MT
#3438 | ||
Engineer
Drives: WRB 2022 Subaru Brz
But yes, ethanol from a thermodynamics point of view does run cooler and more efficient. But because it has less energy per volume, more e85 is pumped through the injectors to produce same energy level as 91 octane. Because of its efficiency and aggressive tune that you are able to run (e85 is more resistant to knock, so you can run aggressive Ignition timing) you are technically making more power. I believe, ethanol has some side effect with rubber hoses, but nothing particularly running it in the engine. And yes ethanol is natural cleaning agent. Last edited by vignesh; 04-17-2014 at 11:20 AM. |
#3439 |
Also, where do you guys buy plasti dip locally (in Ottawa). The only place I've been able to find is Home Hardware, but I'd rather not spend $20 per can if there's an alternative.
#3440 | |
Drives: Ultramarine Blue FR-S
Sent from my HTC One using Tapatalk
-- Kenny"I don't always use heel/toe, but when I do it's because racecar." |
| The Following User Says Thank You to UMB FR-S For This Useful Post: | FRS_Ken (04-16-2014) |
#3441 |
Drives: FRS
Lowes is $15 per can i think. not really going to find it cheaper then that is Canada...
#3442 | |
((•||=(86)=||•))
Drives: '13 FR-S Ultramarine 6AT; '13 Yaris
Ken
Cusco Suspension Braces | Eibach F & R sway bars | aFe/Takeda Intake | GReddy EVO3 | D2 RS Sport Coil-overs | TSW Interlagos | Centric Front Discs | Hawk HP+ (F) / HPS (R) | Goodrich SS brake lines | TSW & OZ Racing wheels | Continental & Hankook tires | JDP CF Front Lip | Rexspeed CF ground-effects kit | APR CF parts | Winjet headlights & fog lights | Valenti Smoked Reverse | TOM's LED taillights | CF interior upgrades | LED upgrades | and much more
#3443 | |
((•||=(86)=||•))
The spark plug replacement procedure looks hard enough ![]() Just curious since I won't be touching injectors, etc lol
#3444 |
Drives: asphalt 86
[QUOTE=FRS_Ken;1678180]How difficult was it to work on the injectors and such?
The spark plug replacement procedure looks hard enough ![]() Just curious since I won't be touching injectors, etc I've heard they can be tricky on our cars, don't recall why. Mine are still in a box at home. I was about to order my flex fuel kit when people started reporting issues such as this. |
