Old 04-16-2014, 06:14 AM   #1233
major quicknap
Drives: blue sardine
Curiosity question.
Why do Tein SRCs have a remote canister on the rear but not on the front?
Captain Snooze sends his regards.
major quicknap is offline   Reply With Quote
Old 04-16-2014, 12:45 PM   #1234
SubieNate
SubieNate's Avatar
Drives: 2013 FR-S Ultramarine
Originally Posted by major quicknap View Post
Curiosity question.
Space. The fronts have enough internal volume (as far as tein is concerned at least) to not need them. The rear shock bodies on our cars are already really short stock. Then you make them shorter to improve performance when lowered and you start cutting into the needed volume of nitrogen/oil for effective operation. So, add a canister for the gas. Makes assembling the adjustment mechanism easier as well.
Cheers
Nathan
SubieNate is offline   Reply With Quote
The Following 3 Users Say Thank You to SubieNate For This Useful Post:
Anthonytpt (04-17-2014), major quicknap (04-16-2014), Roadliner (04-18-2014)
Old 04-17-2014, 02:42 AM   #1235
Panman
Panman's Avatar
Drives: 86 GTS
Maximize that from camber with the bolt. Zero toe front/rear, but you MAY want to consider a tiny bit of toe-out to promote rotation. Try zero toe first; it may already be a bit looser than you're used to.
You won't have any adjustment except toe in the rear.
-Mike
@CSG Mike :
Negative or positive camber at the front? I've gone with the Whiteline/SPC camber bolts.
Panman is offline   Reply With Quote
Old 04-17-2014, 10:58 AM   #1236
Racecomp Engineering
Negative!
- andy
Old 04-17-2014, 11:45 AM   #1237
KKaWing
KKaWing's Avatar
Drives: Nissan Versa
Originally Posted by Panman View Post
@CSG Mike :
Did someone say positive camber?
(taken from: http://blog.axisofoversteer.com/2010...ve-camber.html)
KKaWing is offline   Reply With Quote
The Following 4 Users Say Thank You to KKaWing For This Useful Post:
Anthonytpt (04-17-2014), fooddude (04-17-2014), major quicknap (04-18-2014), wparsons (04-17-2014)
Old 04-17-2014, 12:15 PM   #1238
CSG Mike
CSG Mike's Avatar
@CSG Mike :
Always negative!
Old 04-17-2014, 12:16 PM   #1239
CSG Mike
CSG Mike's Avatar
Curiosity question.
Because the fronts are an inverted strut, while the rear is a traditional layout damper. If the front had an external cannister, you'd need to mount it in the engine bay, but they were able to package everything together without the need for an external.
Remote canisters are nice, but do add to the cost...
major quicknap (04-17-2014)
Old 04-17-2014, 04:20 PM   #1240
mrretep
Drives: '14 Raven FR-S
Awesome thread! thanks for helping out the community like this. I'm picking up an FRS on saturday to replace my current 335i. I AutoX once a month and do track days about every other month so the running costs on the 335i are getting a little excessive to say the least. But thats besides the point my question is with the same track time above on the FRS (dual purpose track/dd) I was wondering what spring rates do you guys thing will be good option? I'd rather focus more on the track aspect than the street aspect.
I was actually looking at the RCE Tarmac 2 Clubsports as in my research those seem to be the best bang for the buck in terms of the track performance I'm looking at. Would I need camber plates for those? I plan on running 18x9.5 for the street and probably 17x8 on track.
Thanks for any advice!
mrretep is offline   Reply With Quote
The Following User Says Thank You to mrretep For This Useful Post:
Racecomp Engineering (04-17-2014)
Old 04-17-2014, 04:37 PM   #1241
First question is what kind and what size tires do you run?
Our T2 Clubsports are a good choice for dual purpose cars. Lots of track, street, and auto-x development and they're being used extensively by FR-S/BRZ guys and girls for all of it.
- Andy
Old 04-17-2014, 05:43 PM   #1242
mrretep
- Andy
I plan on running 265/35/18 Hankook V12 for DD duty and 245/40/17 Hankook RS3 for track/autox.
Old 04-17-2014, 06:14 PM   #1243
smbstyle
smbstyle's Avatar
Drives: 2013 SWP BRZ
- Andy
I can second this. Honestly, I truly forget I'm even running the T2s (400lb springs) when I'm driving around on the street.
It is a night and day difference though on track, I absolutely love them.
2013 SWP BRZ
Build Thread: http://www.ft86club.com/forums/showthread.php?t=38781
smbstyle is offline   Reply With Quote
The Following User Says Thank You to smbstyle For This Useful Post:
Racecomp Engineering (04-18-2014)
Old 04-17-2014, 11:24 PM   #1244
jdmblood
jdmblood's Avatar
Drives: white subaru brz
I already purchased springs and planning on buying struts later on. Is there such thing as a height adjustable strut? And would replacing the OEM struts with aftermarket ones add anymore of a drop or would it be the same as just the springs plus the OEM struts??
jdmblood is offline   Reply With Quote
Old 04-17-2014, 11:45 PM   #1245
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
With a fast and furious avatar to boot. lol Adjustable coilovers fit the bill for being adjustable. Typically changing out the strut does not lower the car any more, but I've seen fixed perch struts that have the perches mounted lower effectively giving you a drop. Bilstein make some I think, not so sure.
Old 04-17-2014, 11:56 PM   #1246
jdmblood
jdmblood's Avatar
hell yea lmao. Got the Tokyo drift avatar and thanks for the advid. The bilstein b6s I believe are the lowering ones.
Air Suspension Discussion Thread - Let's Get Nerdy Andrew@ORT Suspension | Chassis | Brakes -- Sponsored by 949 Racing 174 02-13-2016 03:17 PM
RallySport Directs Everything Suspension thread!! RallySport Direct Brakes, Suspension, Chassis 21 07-02-2014 05:31 PM
The OFFICIAL Ohlins Coilover Suspension thread - High End Competition Suspension ModBargains.com Suspension | Chassis | Brakes -- Sponsored by 949 Racing 63 05-22-2013 08:15 AM
2012 Team USA vs the 1992 Dream Team ERZperformance Off-Topic Lounge [WARNING: NO POLITICS] 1 09-14-2012 06:19 PM
Team build thread; PROJECT.STH trueno86power Other Vehicles & General Automotive Discussions 0 03-02-2010 10:13 AM
