Old 04-15-2014, 02:15 PM   #15
FullTuneZN6
Novice Drifter
FullTuneZN6's Avatar
Drives: 2013 Asphalt FR-S
Originally Posted by OjiGeorge View Post
Had staggered 235f 255r, and then switched to square, 255 all around with same tire. Square has my vote by a long shot.
did the 255s rub up front?
FullTuneZN6 is offline   Reply With Quote
Old 04-15-2014, 02:19 PM   #16
Brick
Drives: White 2013 FRS
I have some rub on my 255s up front that's with a 9.5 " rim with a +45 offset
Brick is offline   Reply With Quote
The Following User Says Thank You to Brick For This Useful Post:
FullTuneZN6 (04-15-2014)
Old 04-15-2014, 07:17 PM   #17
FullTuneZN6
Novice Drifter
so do you think a 245/35 tire with a 9.5" wheel up front would clear with offset of +38? and dialed in some neg camber around 1.5-2*?
Old 04-15-2014, 08:20 PM   #18
Brick
I can't tell you definivetly as I haven't tracked down the source of my rubbing. It's only at full lock. Someone with firsthand expierence with that offset can help you out. Even if you clear the inside of everything the change in offset compared to the +45 moves you closer to the fender.
Old 04-15-2014, 09:26 PM   #19
FullTuneZN6
Novice Drifter
yeh i think im going to go with square 8.5"s...but heres my dumb question, just so i make sure i understand, if i used a spacer of say 5mm in the rear that would have a similar impact on the wheel's "flushness" poke whatever as a lower offset? the spacer basically pushes the wheel out more based on size of spacer? thanks and i apologize for my ignorance
i ask only because the 8.5 in the rear is going to be tucked a little more than the front and i want to try to have it a little more flush thanks
Old 04-15-2014, 09:39 PM   #20
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
Originally Posted by FullTuneZN6 View Post
thanks for the input, i think square is going to be the way to go and if i need a little more traction when i go FI ill just use a wider tire... @King Tut u think 255s square will fit up front with no rub?
Depends on wheel width and offset.
Have you tried a 5mm spacer? I think that will fix the rub in the front.
Old 04-15-2014, 11:13 PM   #21
Brick
I was only able to drive the car with the new rims and tires for a day before work had me leave home for awhile so i don't know where it's rubbing yet. If it's rubbing on the inside then a spacer is a no brainer.
Old 04-16-2014, 12:24 AM   #22
King Tut
NASA SpecE30 Racer
King Tut's Avatar
I had 9.5 +40 265 width and rubbed the frame at full lock in the front.
hmong337 (04-16-2014)
Old 04-16-2014, 01:39 AM   #23
OjiGeorge
OjiGeorge's Avatar
Originally Posted by Tye300 View Post
How did the car feel when square and staggered? I'm running 235 square for my track days and I'm curious what benefits going staggered to a 265 rear would get me. I'm using Achilles 123s for track. As of now, at 270whp, powering out of corners makes the rear step out easily than when I was NA.
Personally I'd keep the 235 square set-up over a wider rear tire until you wear those down, and then upgrade all four corners if you want more grip.
Could you run a slightly faster time with a wider rear tire? Probably. But the car wont be as fun, AND wont be as predictable if you are not experienced = double negative. That said, the 86 is still very predictable with a staggered setup~ it's just not as fun, and the balance is off, and you can't push it quite as much... yadda yadda square ftw
OjiGeorge is offline   Reply With Quote
The Following User Says Thank You to OjiGeorge For This Useful Post:
Tye300 (04-16-2014)
Old 04-16-2014, 01:41 AM   #24
OjiGeorge
OjiGeorge's Avatar
255 Hankook V12's, on a +40, 9" rim with -2.5 camber, have zero rubbing issues.
FullTuneZN6 (04-21-2014)
Old 04-16-2014, 02:07 PM   #25
Vis101
Vis101's Avatar
Drives: 2013 Limited BRZ
@OjiGeorge, how much drop do you have from the stock suspension system?
Vis101 is offline   Reply With Quote
Old 04-17-2014, 05:24 AM   #26
OjiGeorge
OjiGeorge's Avatar
It's a good question. TBH I haven't measured it, just had a local shop install the T2's and set it to how they recommended it. After having them on there for a year it's a bit too low for my use. Looks great, but it's not ideal if I'm really on it. I'm planning to raise it some next week when I go in for an alignment.
Here's a pic to show you. No finger gaps. The silver lining is that even with this low I'm not experiencing any rubbing issues.
http://www.ft86club.com/forums/pictu...pictureid=6921
http://www.ft86club.com/forums/pictu...pictureid=7447
The RT5's +44 are with a staggered setup, the Bremmer's +40 are square.
Old 04-18-2014, 08:53 PM   #27
FullTuneZN6
Novice Drifter
@King Tut, if i run a square setup with staggered offsets it should have a major impact on performance/balance?
specifically 18x8.5 +47 Front ; 18x8.5 +38 rear? my only concern with th + 47 upfront is brake clearance with the wilwood BBK. but with staggered offset- the mm from flush is almost identical which mirrors stock setup(STOCK 42.5mm from flush F/R; THIS 22.5mm FR/20.5mm Rear). thanks
Old 04-21-2014, 02:59 PM   #28
FullTuneZN6
Novice Drifter
i found some 18x9 wheels but they have a super high offset of +52, that helps with the poke but im worried if the wheels will be able to clear the calipers of a BBK...any thoughts on this?
Advan RGD 18 x 8.5" (33) offset squared, no one? OICU812 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 17 11-14-2014 10:35 PM
FS> SSR VIENNA 18X7.5 48 squared size kervin2004 Wheels and Tires 0 12-13-2013 03:01 PM
[SQUARED] Photo connor_lol FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 17 10-10-2013 11:37 PM
Scion FR-S on Squared 18x9.5 Drzdude Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 15 07-09-2013 11:49 AM
Ok to have non staggered wheels but staggered tires? taimysho0 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 05-21-2013 11:57 PM
