Old 04-15-2014, 05:32 PM   #253
OoLong
#TeamAURA
OoLong's Avatar
Drives: BRZ Limited Lighting Red '13
Originally Posted by Vis101 View Post
@OoLong, I will be tackling the lip and rear spat install this weekend finally. Because I am doing so in part to cover up some cosmetic issues, I have no problem using screws. Curious to see more pictures, particularly of the spats from various angles. Thanks.
Sent from my HTCONE using Tapatalk
Good thing the only thing I had time for was the front lip and the rear aprons. I will take some pic after work.
OoLong is offline   Reply With Quote
Old 04-15-2014, 06:12 PM   #254
BCooke
BCooke's Avatar
Drives: DGM Subaru BRZ 6MT
Originally Posted by OoLong View Post
So I am done painting all the parts and was install my kit this weekend. This is the only problem I ran into in terms of fitment issue... I took the weather strips off because the one that BaysonR provided was pos... What is the best way for me to hold that flap to the bumper? I was thinking just doing screws on the bottom part but I wanted to hear some 2nd opinions.
Just got this kit in... That worries me. Keep us updated on your solution
BCooke is offline   Reply With Quote
Old 04-15-2014, 06:19 PM   #255
Andrew025
Andrew025's Avatar
Drives: Neptune GR86
What exactly is your issue?
Are you not wanting to use the screws?
That's how mine is installed and have no issues with the fit.
Old 04-15-2014, 07:12 PM   #256
OoLong
#TeamAURA
OoLong's Avatar
My problem is that I did use all the screws on the bottom of the lip but then when I am done screwing, the sides are popping out like they don't close in. I am not totally sure because I think I screwed it in all correctly... I might have to unscrew it and try to move it back towards the car more so there's less tension. I'll update yall when I get a chance.
Old 04-15-2014, 07:17 PM   #257
Andrew025
Andrew025's Avatar
Everything being tightened up might be your issue. Get everything a bit loose and it should line up better.
Old 04-16-2014, 01:46 PM   #258
OoLong
#TeamAURA
OoLong's Avatar
OP Delivers.
The rear aprons fits great.
Old 04-17-2014, 11:30 AM   #259
CarzCarzCarz
CarzCarzCarz's Avatar
Drives: 2014 WRB BRZ
Does anyone know if the rear aprons will fit with RallyArmor mudflaps?
Thanks to all other previous posters, the pics have really helped sell these, and the painting advice is superb.
CarzCarzCarz is offline   Reply With Quote
Old 04-17-2014, 11:54 AM   #260
2point0
2point0's Avatar
Drives: '13 BRZ Ltd WRB
They should. The spats just wrap around flush with the fenderwell. There are lots of GD Subarus with spats and mudflaps.
2013 BRZ Limited - SOLD
2008 Forester XT Sports
1967 Mustang Coupe - 289 V8
2point0 is offline   Reply With Quote
The Following User Says Thank You to 2point0 For This Useful Post:
CarzCarzCarz (04-17-2014)
Old 04-17-2014, 01:40 PM   #261
CarzCarzCarz
Cool, thanks for the info.
Old 04-18-2014, 12:06 AM   #262
Vis101
Vis101's Avatar
Drives: 2013 Limited BRZ
OP Delivers.
Yeah baby. Can't wait for the weekend. By the way, what screws did you use?
Vis101 is offline   Reply With Quote
Old 04-18-2014, 12:10 AM   #263
OoLong
#TeamAURA
OoLong's Avatar
I used whatever that came with the rear aprons. It came with 2 self screw clips and 2 black screws. Your best bet is either remove the tires and then screw the screw in or use a 90 degrees screw driver.
Old 04-18-2014, 12:18 AM   #264
Vis101
Vis101's Avatar
@OoLong, thanks again.
Old 04-20-2014, 10:08 PM   #265
OoLong
#TeamAURA
OoLong's Avatar
FINALLY got everything installed. This took me a month of prepping, painting and installing...
and here is my front lip fitment solution:
The Following 6 Users Say Thank You to OoLong For This Useful Post:
cslntuee (04-21-2014), ericmpena (06-04-2014), Kostamojen (04-20-2014), MooseWRX (04-20-2014), unsurety (07-26-2014), Vis101 (04-20-2014)
Old 04-20-2014, 10:45 PM   #266
Kostamojen
Wow, looks fantastic. They should totally sell thr tS in Red after seeing how good it looks!
STi Style Carbon Fiber Front Lip/Side Skirts/Rear [BRZ] JPxM0Dz Cosmetic Modification (Interior/Exterior/Lighting) 31 12-03-2013 10:57 PM
CS Style Polyurethane Side Skirts Jive Turkey Exterior Parts (Aero, Lighting, Etc.) 14 11-04-2013 09:49 PM
WTB CHARGESPEED STYLE SIDE SKIRTS. bahanii Want-To-Buy Requests 1 10-18-2013 02:06 PM
FS: CS Style Side Skirts and Rear Spats FRS2000 Exterior Parts (Aero, Lighting, Etc.) 4 09-23-2013 12:15 PM
2013 SUBARU BRZ J STYLE PU SIDE SKIRTS JPxM0Dz Cosmetic Modification (Interior/Exterior/Lighting) 7 05-10-2013 11:29 AM
