#71 |
A Demon
Drives: Raven GT86
#72 |
Drives: 2013 Raven Fr-s, 2013 Versa Sedan
you get cock Blocked if You stand next to the Car with your date and a Car Person sees you .
#73 | |
Drives:
#74 |
Drives: Scion FR-S Whiteout
Because.
2013 Scion FR-S
#75 |
Drives: 4 wheels
#76 |
Drives: 2013 GBS BRZ Limited
It DOES have to be warmed up (fully is how much?).
It is part of the conditions to be met for the car to enter diagnostic mode (what you are in if you successfully execute the 'pedal dance'). Why? Who knows. Maybe it was to minimize the chance that someone stumbles across it messing with their car in the driveway? |
#77 |
Drives: ZC6, Junk of ALL sorts
I believe some Scions will apply to this.
At least the ones with door handle lock unlock sensors. On Limited BRZ's Factory settings: When you touch the inside of the handle to unlock the door, it unlocks the drivers side only. If you want both driver and passenger side to unlock with a single touch of the handle, do as follows. Open The driver door, Leave the car off, On the key fob Hold down both Panic and Lock buttons for ~5secs. When you let off you should hear a beep.
# 1. Always know where your towel is.
ZC6-CBS, is home |
#78 |
#79 |
So elite I'm 1338
Drives: WRB Subaru BRZ
Operating temp
#80 |
Drives: frs
- You can also set the gear indicator (Google it!), but it's not "real-time" that it needs a couple seconds to register.
The gear indicator displays the gear number selected when the clutch pedal is released. It is real time if you aren't on the clutch pedal. |
#81 |
Drives: 2013 Premium White, 2006 TL
Great thread. I really didn't know some of this stuff. Thanks. Now I know what gear I'm in just by looking at the tach.
Here is a small thing. The glow in the dark trunk release inside the truck (just in case you forgot you put someone back there, or it closed on you while you were in there) has a way to be attached so it isn't dangling. Make sure that you flip it so you can see the writing on it, and then snap it into place. Sent from my iPhone using Tapatalk |
#82 | |
Drives: Monogram Firestorm
#83 |
Drives: Raven FR-S MT
The FR-S comes with bandaids. You can patch yourself up when you cut yourself on the piece of plastic right next to the oil filter... trying to take out the oil filter. Or putting it back on.
2013 Scion FR-S - Build Thread
2015 Ford Mustang GT 1978 Triumph Spitfire 1500 ---------------------------------------------- ![]() |
#84 |
Drives: Ultramarine FR-S
helpful info...thx.
| Tags |
| scion brz hidden features |
| Ideas for a hidden magnetic phone-mount. | MmmDieselFumes | Cosmetic Modification (Interior/Exterior/Lighting) | 40 | 05-09-2016 01:14 PM |
| Bespoke A/V Hidden Option | UbSaMrC | Electronics | Audio | NAV | Infotainment | 58 | 12-13-2015 11:14 PM |
| FS: Custom Stainless Lightweight Hidden Hitch | that_guy | Canada Classifieds | 3 | 06-11-2014 07:13 PM |
| Hidden Rusting issue | FRSHunter | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 1 | 04-07-2014 05:02 PM |
| DIY: access hidden menus on BRZ head unit | robot | DIY (Do-It-Yourself) Guides | 0 | 10-22-2013 11:59 PM |
