#43 | |
Drives: Moped
That is exactly the type of info that I was looking for...thank you :happy0180: |
#44 |
Undecided Color for FR-S
Drives: Jeep Liberty, Scion xA
#45 |
Drives: '06 AM V8V Coupe
Okay, it's like this. An automatic transmission these days controls the engine and gearbox together, so the gearbox can shift up very early and operate the engine more efficiently in the EPA test, where a car is required to accelerate at a predetermined rate at any given time. The manual transmission however is to be kept in the same gear until some speed, which could be much less efficient. Thus an automatic wins out in the EPA test, while in the real world normal drivers can do just as well with a manual transmission typically speaking.
Basically what it comes down to is, a manual transmission's fuel economy depends more on the driver. The computer is not necessarily "better" at shifting the gears for you (aside from the fact that it shifts faster), since the way it's programmed is a compromise. |
#46 |
Drives: 1986 AE86 GT-S, 2011 Lexus IS250 6M
Auto and manual have the same final drive ratios (4.10:1).
Jeff
![]() 2011 Lexus IS350 F-Sport 6MT with LSD 1986 Toyota Corolla GT-S Supercharged |
#47 | |
Drives: N/A
I don't know about the typical driver but ecomodders and hypermilers tend to do better with the manual, despite the gearing disadvantage. For MPG, control is huge. Which is also why the autos get better scores on the EPA cycle. Thanks for the writeup arghx7. |
#49 |
Drives: BRZ(sold), STI
#50 |
Common terminology refers to Final Drive Ratio as the Axle Ratio, it applies to all gears.
Effective 6th gear is what you are referring to, as that multiplies transmission/axle ratio. Jeff
#51 | |
Drives: N/A
I misspoke. Must have been an off day. <.> *derp* |
#52 |
Well well well, Pekingduck has finally got us some real numbers to play with!
He said he averaged 29.5mpg on a mostly highway at 85-90mph (holy shit) trip, and 39mpg on a mostly highway 70mpg trip. Put through the ecomodder calculator, these points basically match the 1NZ-FXE's equivalent load BSFC points, and considering that his car is brand new and will probably pick up a few percent higher efficiency as he drives it, I think this is reason to celebrate Going off the 1NZ, 65mph should give 42mpgish, but it could be even better than that :OThe real interesting thing will be to see how this engine behaves under very low load, but I feel like they're never going to release a BSFC map ![]() I think a 6th gear right in between the manual and auto 6th gears would be worth trying, with 15% longer 6th gear and looking at the same range of points that apparently approximately match the 1NZ-FXE, we can expect the difference to close to within 7% at the engine, 6% minus AT parasitic load 46mpg 65mph cruise anyone?
#53 |
Hot Dog
Drives: quicker than arghx7
Very interesting indeed. Hopefully his numbers are typical, and the EPA estimates are very pessimistic [as I was hoping].
"Wisdom is a not a function of age, but a function of experience."
Just Say No to unqualified aftermarket products. |
#54 |
Drives: Scion FRS
Throttle accelerator modules
Anybody ever try or using an aftermarket throttle accelerator module?
#55 |
Rust bucket enthusiast
#56 |
Drives: 2014 GT86
You shouldn't. If you want more performance, see some ecu tuning solution (eg. OFT or Ecutek) (and throttle pedal mapping even stock is not too linear to open throttle much more in initial travel. Not sure it's worth to make it even less linear and further rob throttle fine control by those .. "modules").
| Tags |
| auto, consumption, manual, mpg, transmition |
| FR-S to BRZ Ratio | MannyO | New England | 11 | 03-08-2012 03:23 AM |
| Brz Production Numbers | WRB Bandit | BRZ First-Gen (2012+) — General Topics | 29 | 03-07-2012 10:53 PM |
| Any Idea of U.S. Pre-Order Numbers? | markemark24 | Scion FR-S / Toyota 86 GT86 General Forum | 1 | 02-21-2012 01:29 PM |
| Reverse gear on the first and second gear side | randytindoggy | Scion FR-S / Toyota 86 GT86 General Forum | 50 | 01-29-2012 02:21 PM |
| 86,BRZ MT gear ratio | Yobiwan | Engine, Exhaust, Transmission | 1 | 01-26-2012 03:40 AM |
