Old 04-12-2014, 03:12 PM   #99
xjohnx
Grip>Slip
xjohnx's Avatar
@SHIFTER - any chance you've tried hooking up a USB tv tuner to the head unit to see if that works?
Old 04-12-2014, 03:24 PM   #100
XanRules
A Very Powerful Wizard
XanRules's Avatar
Drives: 2014 BRZ LTD WRB (RIP), 2017 FiST
Does it use Google Maps, and can it read data from a USB drive like any other HU?
XanRules is offline   Reply With Quote
Old 04-12-2014, 07:50 PM   #101
ir1064
Drives: 6MT, C7P
Originally Posted by SHIFTER View Post
Compared to the stock stereo - vastly superior, mainly due to a better internal amp in this stereo and better control over the sound with the equalizer.
the stock speakers actually sound fairly good with just a stereo change!
i've completely different result than you no matter how i try, i couldn't get the door speaker bass working, it almost sounds exactly like when dealer set the wrong car type on the stock HU, when i increase the bass, i can totally here it come from the back speaker (which is totally distort) and absolutely nothing from the door panel. i tried different EQ setting and play with the balance and fade setting. someone please help.... btw, my iPod connection also not working, i tried iPod classic, iPod nano and iPhone, software crash during connection and go back to home page....
ir1064 is offline   Reply With Quote
Old 04-12-2014, 11:12 PM   #102
Prog
Prog's Avatar
Drives: 2016 Cadillac CTS
I don't know what the harness on the Dashlinq looks like since I don't have one yet, but did you wire tap the stock amp's power on cable into the right wire on the unit's wire harness?
Prog is offline   Reply With Quote
The Following User Says Thank You to Prog For This Useful Post:
ir1064 (04-13-2014)
Old 04-12-2014, 11:45 PM   #103
ir1064
Drives: 6MT, C7P
i DIDN'T and have no idea!!! can you point me where i can get the wiring information
thanks
Old 04-13-2014, 11:33 AM   #104
Prog
Prog's Avatar
thanks
If you can wait until I get mine in, I'll take pictures for you.
Old 04-13-2014, 11:51 AM   #105
SHIFTER
SHIFTER's Avatar
Drives: Scion FR-S
Yes and Yes.
Andrew
2013 Scion FR-S MT (Silver)
2011 Toyota Rav4 Sport V6 4wd (Silver)
SHIFTER is offline   Reply With Quote
Old 04-13-2014, 11:52 AM   #106
SHIFTER
SHIFTER's Avatar
Drives: Scion FR-S
I don't have one to try - otherwise i would.
Andrew
Old 04-13-2014, 11:53 AM   #107
SHIFTER
SHIFTER's Avatar
Drives: Scion FR-S
Shit I forgot ALL about that - yes you need to wire up the stock amp otherwise your door speakers won't work.
Sorry about forgetting that - I installed it in such a rush I forgot I had done that.
Andrew
Old 04-13-2014, 12:00 PM   #108
SHIFTER
SHIFTER's Avatar
Drives: Scion FR-S
See my post before this about the door speakers - its totally because you need the stock amp to be given power. There is a lone wire on the accessory harness that is labeled AMP. Wire that to pin #9 on the 10 pin factory harness that looks like this:
4 3 2 1
10 9 8 7 6 5
More info about the amp here: http://www.ft86club.com/forums/showthread.php?p=610948
About the ipod - make sure the harness plugging into the stereo for the ipod is pushed in tight. I had the same issue - it just wasn't 100% securely installed. WORST case - if it still doesnt work, take a video of it and email them - they will give you updated firmware or an updated app to correct it. If thats the case - email Will at will@innotrends.com and he will help you. Their support is fast and very good, so they will for sure help you
Otherwise PM me if you have any more troubles!
Andrew
Old 04-13-2014, 12:01 PM   #109
SHIFTER
SHIFTER's Avatar
Drives: Scion FR-S
thanks
See above - sorry again guys! Forgot all about that
Andrew
Old 04-13-2014, 02:25 PM   #110
Deathalo
Drives: 2013 WR Blue Limited Manual BRZ
So, I'm trying to sell my BRZ HU to get this, I know there's a GPS antenna behind my current HU, will I need that for this new HU or does this one come with it's own GPS antenna? I figure I need to include the GPS antenna with the sale of my HU.
Deathalo is offline   Reply With Quote
Old 04-13-2014, 02:33 PM   #111
kberkel
kberkel's Avatar
How many RCA preouts are there? Does it have a remote wire? I heard the stock amp doesn't use a remote wire.
Any pictures of the backside?
The specs are so minimized on their site. I'm sure they'd sell more if they were a little more thorough.
kberkel is offline   Reply With Quote
Old 04-13-2014, 04:14 PM   #112
xjohnx
Grip>Slip
xjohnx's Avatar
I'll probably snag one and give it a try once my head unit arrives.
Can you post a photo of your harness so we can see what you did for wiring in the amp power?
REVIEW: Ca-Fi Toyota Universal - Stock Fitment ANDROID Stereo SHIFTER Electronics | Audio | NAV | Infotainment 16 06-13-2017 06:23 PM
Android, bluetooth, Music, and the FR-S stock pioneer stereo JayNutter Electronics | Audio | NAV | Infotainment 27 12-18-2014 03:54 AM
How to: Torque on an android powered stereo with no hacking v. Ca-Fi Dashlinq4 SHIFTER Electronics | Audio | NAV | Infotainment 29 04-07-2014 04:58 AM
