Old 04-13-2014, 01:15 PM   #1317
pmccut
Drives: Blue Subarus
Originally Posted by Sterz View Post
Alright guys so I finally got an appointment in with Bill @DeliciousTuning. The date is Wednesday 4/16
Modlist:
FBM Stage 1 Base Kit
FBM Radiator
FBM Spal 12" Fans
FBM Oil Cooler w/ SS Lines
1000cc Injectors
Testing out Bill's new MAP sensor
ClutchMaster's FX350
E85
Will post up results as soon as I get home, shooting for 16 PSI.
I just picked mine up with a similar config yesterday. ID1000s, new MAP sensor. We're going to switch back to stock injectors since we couldn't get the ID1000s dialed in. Does he want you to stick to the 1000s or try stock injectors first?
'13 GBS BRZ 6MT | FBM 9:1 w/ GTX3076R| FBM oil cooler + catch-can + radiator + SPAL fans| Rays 57xtreme / PSS | Perrin 2.5" FP | Invidia 2.5" OP | Perrin 3" CBE | RCE T2s | Exedy Stg1
'15 STI LE | Cobb Stg1
pmccut is offline   Reply With Quote
Old 04-13-2014, 01:18 PM   #1318
Reaper
in orbe terrum non visi
Reaper's Avatar
Drives: violent
Ill trade you 550s for your 1000s
Sent from my SAMSUNG-SGH-I747 using Tapatalk
The Following User Says Thank You to Reaper For This Useful Post:
Sportsguy83 (04-13-2014)
Old 04-13-2014, 01:19 PM   #1319
Sterz
Great White
Drives: 2013 Whiteout FRS
I mentioned that I had 1000s and he didn't mention anything but I will definitely be bringing the 550s along now!
Sterz' Great White 86
http://www.ft86club.com/forums/showthread.php?t=54533
Invidia Q300 Catback | Invidia Catless Frontpipe | Invidia Overpipe
Sterz is offline   Reply With Quote
Old 04-13-2014, 01:26 PM   #1320
pmccut
I'd bring stock as well, I think he was able to get 350+ whp on E85 (dynojet).
Old 04-13-2014, 02:02 PM   #1321
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Incredible.... I am an average Joe and was able to dial my ID 1000's down (by myself) in four tune changes with one night James explaining me what needed to be done and then a few questions here and there to HRI Tuning @jamesm....
The Following 2 Users Say Thank You to Sportsguy83 For This Useful Post:
jamesm (04-13-2014), Sterz (04-13-2014)
Old 04-13-2014, 02:10 PM   #1322
Sterz
Great White
I also find that extremely odd.
Old 04-13-2014, 02:49 PM   #1323
SmsAlSuwaidi
Boosted
SmsAlSuwaidi's Avatar
Drives: Not a supra....yet
Many odd things
Sent from my IBrick
Old 04-13-2014, 06:42 PM   #1324
jamesm
ID1000's are some of the easiest injectors to calibrate that you'll ever find.
The Following User Says Thank You to jamesm For This Useful Post:
Old 04-14-2014, 02:02 AM   #1325
pmccut
Is there any technical reason why the 1000cc injectors would need to have a harsh start? I've always accepted this from past tunes...harsh starts until switching to DI. You can make it feel identical to stock?
They found the o2 sensor was trashed most likely due to the coolant from the headgasket failure. I'm going to swap that out this week before retuning when @DeliciousTuning flies up in 2 weeks. I'm not sure what impact that has on my start-ups right now. I have to FLOOR the throttle for a few seconds while it's cranking, then continue giving it gas until it's fully warmed.
@Sterz - let's see if they can get your ID1000s dialed in on Wednesday. Maybe it's all O2 sensor for me.
Old 04-14-2014, 09:35 AM   #1326
jamesm
I've had a couple cars have hard cranking issues with the ID injectors, but then the rest behave perfectly normally. Typically they just take a few more cranks to turn over, doesn't effect the actual running of the engine once it's started. There been some success getting them to start on one crank by cutting the enrichment way down, which makes me think they're leaking fuel into the cylinder or something but I really don't know what's causing it.
But to answer your question no, if the injectors are calibrated properly the car should idle like normal regardless of temperature.
pmccut (04-14-2014)
Old 04-14-2014, 01:37 PM   #1327
Infamous Performance
Infamous Performance's Avatar
Drives: 02 WRX, 05 LGT, 08 LGT, 08 SpecB
The failing O2 sensor was the biggest issue with attempting to dial in the fueling. With a wideband swinging 25% up and 25% down, I dont know any tuner in the world that will be able to get that dialed, Lol. With the lowered compression, larger turbo and 1000cc Bill estimated he needed approx 8 hours to get the car dialed in on the SD tune (with a properly functioning O2). We had no access to another O2 so late in the evening Friday/Saturday morning. So, we had to stop. Thankfully Bill is flying up to Mann and is tuning there the 25th, 26th and possibly 27th so you can get dialed in much closer to home.
Infamous Performance is offline   Reply With Quote
The Following 2 Users Say Thank You to Infamous Performance For This Useful Post:
pmccut (04-14-2014), Sportsguy83 (04-14-2014)
Old 04-14-2014, 01:51 PM   #1328
pmccut
Absolutely! I'm not directing the injector issue at Bill at all. All of the tunes I've had on the larger injectors (while the car was functioning ok to my knowledge) have been harsh. They'd start on the first attempt on 91, but have a very rough idle until switching to DI. I'm booked for the 25th with Bill @ Mann to tune with the stock injectors. Mann wants $450 to swap the fuel injectors to stock, so I'm going to bug Bill for a map so I can swap the injectors myself before going to Mann.
The Following User Says Thank You to pmccut For This Useful Post:
DeliciousTuning (04-17-2014)
Old 04-14-2014, 07:52 PM   #1329
$450 is steep to swap injectors. I charge $335.
I was just trying to explain about why there was in issue dialing in the injectors as I know how the interweb blows things WAY out of proportion. I guarentee from this thread/posts I will now have multiple questions about tuning 1000cc. I already had 1 call today from a customer who was already concerned about 1000cc due to mis-reading/not reading all the posts from this thread.
Like I said, no tuner can dial in injectors with an AFR sensor swinging 25% up and 25% down (full 50% swing) erratically. The ECM is reacting to false data.
Old 04-14-2014, 08:06 PM   #1330
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
Why do you charge $335 when it is a 1 to 2 hour job max?
best company ever, big fuck off turbo, blown, bow chicka wow wow, fbm, full, owners, powaaaaaa!, thread, will work for turbo
AVO Turbo Kit Owners Topic Sportsguy83 Forced Induction 1935 02-20-2023 10:46 AM
Full Blown FRS/BRZ Stage 1 Turbo Kit FullBlown Forced Induction 456 09-27-2021 03:10 AM
FA20Club Turbo Kit Owners Topic pixel67 Forced Induction 1531 09-09-2014 12:36 PM
Full Blown Turbo Kit! Unleashed Engine, Exhaust, Bolt-Ons 70 10-09-2013 09:46 AM
WTB: Full Blown turbo kit (used) whitefrs Engine, Exhaust, Bolt-Ons 12 03-29-2013 09:15 PM
